    [Plugin] Transformation Inspector
    15 Posts 9 Posters 19.6k Views 9 Watching
      Overview
      Debugging utility to visualize and edit the transformation matrix of groups and components.
      Access
      Plugins > Transformation Inspector
      Usage
      Top matrix is the entity matrix.
      Middle matrix allows you to make changes relative to the entity matrix. This can be reset or applied to the entity.
      Bottom matrix is the compound result.
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2 (v2.6.0)
      http://forums.sketchucation.com/download/file.php?mode=view&id=86938
      [attachment=0:2nw6b8to]<!-- ia0 -->Transformation Inspector - 1.0.1.rbz<!-- ia0 -->[/attachment:2nw6b8to]
      Plugin Installation Guide
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_transformation.rb
      TT_Transformation
      Source Code
      https://bitbucket.org/thomthom/transformation-inspector/
      http://forums.sketchucation.com/download/file.php?id=53761
        Does this works for any volumes ? Cylinders etc.. 😳
          πŸ‘
          Go get some beer πŸ˜‰
            It works on Groups and Components - doesn't care for the content.
            πŸ‘ πŸ‘
            Will do! πŸ˜„ And I promise there will be a new toy for you soon*!
            *soon being relative to infinite time.
              Enjoy
                It would be more 'intuitive' if there was some guidance about which bits of the transformation matrix did what, and how they interact [especially rotation/scaling/handing] etc
                http://www.martinrinehart.com/models/tutorial/tutorial_t.html
                trans=trans.to_a
                        scalex=Math.sqrt(trans[0]**2+trans[1]**2+trans[2]**2)
                        scaley=Math.sqrt(trans[4]**2+trans[5]**2+trans[6]**2)
                        scalez=Math.sqrt(trans[8]**2+trans[9]**2+trans[10]**2)
                        scale=scalex
                        scale=scaley if scaley>scale
                        scale=scalez if scalez>scale
                        puts "         <pos>#{trans[12]} #{trans[13]} #{trans[14]}</pos>\n"
                        puts "         <scale>#{scale}</scale>\n"
                        puts "         <rotation>\n"
                        puts "            <matrix>\n"
                        puts "               #{trans[0]/scalex} #{trans[4]/scaley} #{trans[8]/scalez} #{trans[1]/scalex} #{trans[5]/scaley} #{trans[9]/scalez} #{trans[2]/scalex} #{trans[6]/scaley} #{trans[10]/scalez}\n"
                        puts "            </matrix>\n"
                        puts "         </rotation>\n"
                  Yea - that is my plan as well. And I want to be able to create matrices from the Geom::Transformation helper methods so one can visualize what they do.
                  I started adding tooltips for scaling and translation - but the rotation turned out to be more complex so I put it on hold until I better understood what it did - as RS for the whole 3x3 matrix felt a bit too generic.
                  • PixeroP Offline
                    Pixero
                    This is great! πŸ‘
                    Actually I have though for some time to do a port of one of my MentalRay plugins that does pretty much the same.
                    Now I don't have to.
                    What I would like is a more user friendly GUI.
                    Something like this:
                    Translate  X  Y  Z
                    Rotate     X  Y  Z
                    Scale      X  Y  Z
                    Shear      X  Y  Z
                    Rotate Order  (dropdown with; 1; XYZ, 2; YZX, 3; ZXY, 4; XZY, 5; YXZ, 6; ZYX
                    Rotate Axis   X  Y  Z
                    World Rotate Pivot   X  Y  Z
                    World Scale Pivot    X  Y  Z
                    Edit: I just realised that you can easily go back to a undeformed state simply by doing a negative transform of the applied one.
                    Thats even better...
                    • F Offline
                      function
                      Thanks TT - I'd grown so used to the Maya channel box that I was making dyna-components that do this - cept I had to make one for every object! 😒 This is so useful.
                      I'd love to see units incorporated and that slick java UI you do. Some sort of mini-icon for the rows might be helpful, too.
                      this is the maya channel box
                      http://i.imgur.com/wTUhE.png
                        mattao
                        I'd like a contextual to "reset" a component position.
                        I'd like to be sure my component origin is truly at a 0.0.0 position.
                        Transformation inspector is able to help me to do this ( and it's very efficient and I thank you )
                        By the way I can mount complex scene using External sketchup files as reference, and thanks to you they are perfectly well located in the main scene.
                        Could you help me get a right click substitute for transformation inspector.
                        I'd like to select a component and right click to :
                        TransfoMenu -> reset position
                        TransfoMenu -> reset scale
                        TransfoMenu -> reset rotation
                        TransfoMenu -> reset all
                        thanks
                        • Bob JamesB Offline
                          Bob James
                          Off Subject
                          Speaking of "new toy", what ever happened to the gizmo for Vertex Tools? πŸ˜’
                            Summer happened. 😞 And life in general. Sorry it's taking so long.
                              Reset position would place it at 0,0,0?
                              Reset rotation would align it to the axis of the parent context?
                              • G Offline
                                glro
                                transf inspector outputi am trying to understand how the transformation matrix works, and i notice a difference between what is shown in the matrix using your plugin, and what is supposed to be shown refering to http://www.martinrinehart.com/models/tutorial/tutorial_t.html
                                i took a component, rotated it 45 degrees, and this is what "transformation inspector" shows
                                However, according to martinrinehart, i would expect the negative value to be first line second row
                                I am surely missing something; but can you explain the differrence?
                                rotation matrix
                                • G Offline
                                  glro
                                  i found the reason
                                  http://www.ruthless.zathras.de/facts/apps/polygonesia/3d-transformation-matrix.php
                                  seems that martinrinehart put the minus sign in the wrong place
                                  rot z
