    [Plugin] Transformation Inspector
    15 Posts 9 Posters 19.6k Views 9 Watching
      Does this works for any volumes ? Cylinders etc.. 😳
      It works on Groups and Components - doesn't care for the content.
      Go get some beer πŸ˜‰
      πŸ‘ πŸ‘
      Will do! πŸ˜„ And I promise there will be a new toy for you soon*!
      *soon being relative to infinite time.
      • Rich O BrienR Online
        Enjoy
          It would be more 'intuitive' if there was some guidance about which bits of the transformation matrix did what, and how they interact [especially rotation/scaling/handing] etc
          http://www.martinrinehart.com/models/tutorial/tutorial_t.html
          trans=trans.to_a
                  scalex=Math.sqrt(trans[0]**2+trans[1]**2+trans[2]**2)
                  scaley=Math.sqrt(trans[4]**2+trans[5]**2+trans[6]**2)
                  scalez=Math.sqrt(trans[8]**2+trans[9]**2+trans[10]**2)
                  scale=scalex
                  scale=scaley if scaley>scale
                  scale=scalez if scalez>scale
                  puts "         <pos>#{trans[12]} #{trans[13]} #{trans[14]}</pos>\n"
                  puts "         <scale>#{scale}</scale>\n"
                  puts "         <rotation>\n"
                  puts "            <matrix>\n"
                  puts "               #{trans[0]/scalex} #{trans[4]/scaley} #{trans[8]/scalez} #{trans[1]/scalex} #{trans[5]/scaley} #{trans[9]/scalez} #{trans[2]/scalex} #{trans[6]/scaley} #{trans[10]/scalez}\n"
                  puts "            </matrix>\n"
                  puts "         </rotation>\n"
            Yea - that is my plan as well. And I want to be able to create matrices from the Geom::Transformation helper methods so one can visualize what they do.
            I started adding tooltips for scaling and translation - but the rotation turned out to be more complex so I put it on hold until I better understood what it did - as RS for the whole 3x3 matrix felt a bit too generic.
            • PixeroP Offline
              Pixero
              This is great! πŸ‘
              Actually I have though for some time to do a port of one of my MentalRay plugins that does pretty much the same.
              Now I don't have to.
              What I would like is a more user friendly GUI.
              Something like this:
              Translate  X  Y  Z
              Rotate     X  Y  Z
              Scale      X  Y  Z
              Shear      X  Y  Z
              Rotate Order  (dropdown with; 1; XYZ, 2; YZX, 3; ZXY, 4; XZY, 5; YXZ, 6; ZYX
              Rotate Axis   X  Y  Z
              World Rotate Pivot   X  Y  Z
              World Scale Pivot    X  Y  Z
              Edit: I just realised that you can easily go back to a undeformed state simply by doing a negative transform of the applied one.
              Thats even better...
              • F Offline
                function
                Thanks TT - I'd grown so used to the Maya channel box that I was making dyna-components that do this - cept I had to make one for every object! 😒 This is so useful.
                I'd love to see units incorporated and that slick java UI you do. Some sort of mini-icon for the rows might be helpful, too.
                this is the maya channel box
                http://i.imgur.com/wTUhE.png
                  mattao
                  I'd like a contextual to "reset" a component position.
                  I'd like to be sure my component origin is truly at a 0.0.0 position.
                  Transformation inspector is able to help me to do this ( and it's very efficient and I thank you )
                  By the way I can mount complex scene using External sketchup files as reference, and thanks to you they are perfectly well located in the main scene.
                  Could you help me get a right click substitute for transformation inspector.
                  I'd like to select a component and right click to :
                  TransfoMenu -> reset position
                  TransfoMenu -> reset scale
                  TransfoMenu -> reset rotation
                  TransfoMenu -> reset all
                  thanks
                  • Bob JamesB Offline
                    Bob James
                    Off Subject
                    Speaking of "new toy", what ever happened to the gizmo for Vertex Tools? πŸ˜’
                      Summer happened. 😞 And life in general. Sorry it's taking so long.
                        Reset position would place it at 0,0,0?
                        Reset rotation would align it to the axis of the parent context?
                          glro
                          transf inspector outputi am trying to understand how the transformation matrix works, and i notice a difference between what is shown in the matrix using your plugin, and what is supposed to be shown refering to http://www.martinrinehart.com/models/tutorial/tutorial_t.html
                          i took a component, rotated it 45 degrees, and this is what "transformation inspector" shows
                          However, according to martinrinehart, i would expect the negative value to be first line second row
                          I am surely missing something; but can you explain the differrence?
                          rotation matrix
                            glro
                            i found the reason
                            http://www.ruthless.zathras.de/facts/apps/polygonesia/3d-transformation-matrix.php
                            seems that martinrinehart put the minus sign in the wrong place
                            rot z
