    Diameter instead of radius
    19 Posts 12 Posters 5.9k Views 12 Watching
    • ipsketchpiI Offline
      ipsketchpi
      There are no silly questions:)
      These tease me all the time. When I draw circle with standard SU circle tool I must write radius, but I would like to write in diameter. Is it possible?
      /IP
        No, but the radius is always half the diameter πŸ˜‰
        However there are 'alternative' ways to draw circles [and arcs etc] - see 2dTools - here you get the circle-through-3-points, circle-by-center-radius and circle-by-start-diameter etc
          Take a look to this post πŸ˜‰
            So you can always enter diameter/2 into the Measurement box...
            Therefore no need for any plugin at all... πŸ˜‰
              ArCAD-UK
              Thought I was having a Doh moment but this only seems to work with the division operator. I was beginning to think we had a discrete calculator available πŸ˜’
                Yes, Pilou, but that was not the question on one hand and again, we are in the Newbie forum on the other so let's keep it simple at the beginning...
                πŸ˜‰
                  Yes but how you draw a circle between 2 objects ? (in the easy case horizontal or vertical)
                  You must first draw a line for have the middle of them and then the center! πŸ˜‰
                  And the best will be a plug for that!
                  Because even the Circle by Diameter don't work in this case!
                  Just 2 points to click
                  http://forums.sketchucation.com/download/file.php?id=68678
                  else you must without plug make some tricky align views/ axes etc... πŸ˜„
                  The more easy seams to draw a line between the corners, then a rectangle
                  then the circle
                  Then kill line, rectangle
                  πŸ˜„
                    What's no more simple to draw a circle ? πŸ˜‰
                    It's like that i have understood the question of the first post! πŸ˜„
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi Pilou, hi folks.
                      There is an infinite number of circles between two points since there is an infinite number of planes around a line (the diameter).
                      Just ideas.
                        In the case of the inclined circle above
                        But only one with a diameter // to the ground ! πŸ˜‰ (i believe that will be a tricky plug πŸ˜‰
                        (in fact 2 if your circle has a color different recto verso πŸ˜„
                          ipsketchpi
                          Cool, I like that 100/2 option. Exactly what I am looking for when I am too lazy to divide D to get R πŸ˜„
                          Thanks!
                          /IP
                          • N Offline
                            namuh1
                            Silly question: Why does Layout let you set a circle by diameter... namely typing for exampe: 5" d in the toolbar to get a 5" diameter circle and Sketchup itself does not?
                              Two different programs.
                                It does allow - with a bit of basic calculation input - except when you also want to use the unit (it seems). I use a (centi)metric template and I can enter (say) 100/2 and it will draw a circle with an 50cm radius (i.e. 100cm dia).
                                I guess this does not help much with architectural imperial template for instance...
                                  chmedly
                                  I too would like this. It takes too much time to switch to a separate calculator to figure out a complex circle's radius. I thought the /2 idea would work but it doesn't I have a Sketchup model that is set to decimal inches. I keep trying to draw a circle with a 1.25" diameter. If I type 1.25/2 in the box I get a circle with a radius of 1.25. I've tried a number of different ways of typing this to no avail.
                                  • F Offline
                                    Futurepast
                                    I use the scale tool. I draw the circle, use the scale tool by clicking on corner holding cntl key. Start the move and type in 2 or .5 to double or halve the circle
                                      I've just practiced doing the math in my head. I must say I've gotten faster at it with practice. It really isn't a big problem for me.
                                      I would find scaling a circle after I've drawn it kind of a pain especially if it is drawn on something else in a location where the larger circle would have to cross other geometry.
                                        mm0063
                                        So try 125/200 instead of 1.25/2 . 😎
                                        See https://www.youtube.com/watch?v=crY8SVypzMQ
                                          slbaumgartner
                                          The technique of entering n/m works only because SketchUp's measurements box accepts fractions, not because it implements a divide operator as such. In a fraction both n and m must be integers. Any other type does not get treated as a numerator or denominator of a fraction.
