    Diameter instead of radius
    19 Posts 12 Posters 6.0k Views 12 Watching
      ArCAD-UK
      @gaieus said:
      So you can always enter diameter/2 into the Measurement box...
      Therefore no need for any plugin at all... πŸ˜‰
      Thought I was having a Doh moment but this only seems to work with the division operator. I was beginning to think we had a discrete calculator available πŸ˜’
        Yes, Pilou, but that was not the question on one hand and again, we are in the Newbie forum on the other so let's keep it simple at the beginning...
        πŸ˜‰
          Yes but how you draw a circle between 2 objects ? (in the easy case horizontal or vertical)
          You must first draw a line for have the middle of them and then the center! πŸ˜‰
          And the best will be a plug for that!
          Because even the Circle by Diameter don't work in this case!
          Just 2 points to click
          http://forums.sketchucation.com/download/file.php?id=68678
          else you must without plug make some tricky align views/ axes etc... πŸ˜„
          The more easy seams to draw a line between the corners, then a rectangle
          then the circle
          Then kill line, rectangle
          πŸ˜„
            What's no more simple to draw a circle ? πŸ˜‰
            It's like that i have understood the question of the first post! πŸ˜„
            • Jean LemireJ Offline
              Jean Lemire
              Hi Pilou, hi folks.
              There is an infinite number of circles between two points since there is an infinite number of planes around a line (the diameter).
              Just ideas.
                In the case of the inclined circle above
                But only one with a diameter // to the ground ! πŸ˜‰ (i believe that will be a tricky plug πŸ˜‰
                (in fact 2 if your circle has a color different recto verso πŸ˜„
                • ipsketchpiI Offline
                  ipsketchpi
                  Cool, I like that 100/2 option. Exactly what I am looking for when I am too lazy to divide D to get R πŸ˜„
                  /IP
                  • N Offline
                    namuh1
                    Silly question: Why does Layout let you set a circle by diameter... namely typing for exampe: 5" d in the toolbar to get a 5" diameter circle and Sketchup itself does not?
                      Two different programs.
                        It does allow - with a bit of basic calculation input - except when you also want to use the unit (it seems). I use a (centi)metric template and I can enter (say) 100/2 and it will draw a circle with an 50cm radius (i.e. 100cm dia).
                        I guess this does not help much with architectural imperial template for instance...
                          chmedly
                          I too would like this. It takes too much time to switch to a separate calculator to figure out a complex circle's radius. I thought the /2 idea would work but it doesn't I have a Sketchup model that is set to decimal inches. I keep trying to draw a circle with a 1.25" diameter. If I type 1.25/2 in the box I get a circle with a radius of 1.25. I've tried a number of different ways of typing this to no avail.
                          • F Offline
                            Futurepast
                            I use the scale tool. I draw the circle, use the scale tool by clicking on corner holding cntl key. Start the move and type in 2 or .5 to double or halve the circle
                              I've just practiced doing the math in my head. I must say I've gotten faster at it with practice. It really isn't a big problem for me.
                              I would find scaling a circle after I've drawn it kind of a pain especially if it is drawn on something else in a location where the larger circle would have to cross other geometry.
                                mm0063
                                So try 125/200 instead of 1.25/2 . 😎
                                See https://www.youtube.com/watch?v=crY8SVypzMQ
                                  slbaumgartner
                                  The technique of entering n/m works only because SketchUp's measurements box accepts fractions, not because it implements a divide operator as such. In a fraction both n and m must be integers. Any other type does not get treated as a numerator or denominator of a fraction.
