    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 586.6k Views 102 Watching
    • P Offline
      Pherim
      Note you can also change the material definition (i.e. the dimensions).
      Of course you can but often enough I have a model where I wish to use the same material in different scales and having an option to choose a different scale before applying a material would be great!
      • KrisidiousK Offline
        Krisidious
        Remembering of last scaling and rotation factors by material.
        OH MY... AWESOMENESS....
        By: Kristoff Rand
          About the first option
          Yet existing for a multiple selection with normal use of SU?
            jorge2011
            fredo, thank you very much for this new update.
            A query. Is possible to copy the material properties (rotation, scale, etc ...) and paste those properties to other faces?
            • EarthMoverE Offline
              EarthMover
              Great update Fredo! This was my only issue with the tool. Now it is perfection!
              Content Creator at Skapeup
              • fredo6F Offline
                fredo6
                You have the transfer UV mode, which allows to substitute a texture by another without changing the UVs.
                Otherwise, if the faces are adjacent to the painted faces, just click and drag to extend the painting.
                Fredo
                  If the mesh is made out of Quads you can use QuadFace Tools to copy and paste UV mapping.
                    jorge2011
                    thank you very much
                      jorge2011
                      can be applied a methodology similar to native sketchup materials, using the "Alt" to copy the properties of a material?
                      • fredo6F Offline
                        fredo6
                        We cannot use ALT in scripts because when the key is UP it gives focus to the main Sketchup menu.
                        But I can do it on Shift
                        Note that you can also press the Enter key to sample the material under the mouse
                        Fredo
                        • kenK Offline
                          ken
                          Fredo
                          I have updated as required Fredo Tools to 1.1n and Thru:Paint to 1.0n, however the Check Plugin for Updates still list the two programs as Fredo Tools as 1.1m and Thru:Paint as 1.0m.
                          Am I making a mistake, or is the new programs not registering correctly?
                          Ken
                          • OxerO Offline
                            Oxer
                            Hi Fredo, i'm testing the last revision of ThruPaint 1.0n on Mac (OSX 10.6.8 & SU8) all works fine except that you say in the main post about Material Selector but i have found other problem the arrows don't work on Mac, it is not a big problem because i can introduce the values through the Measures or Visual Edition Mode.
                            Thanks for this great plugin!! πŸ‘
                            [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                            • fredo6F Offline
                              fredo6
                              Oxer,
                              Did it work in previous versions?
                              Or other Mac OS versions?
                              Fredo
                              • OxerO Offline
                                Oxer
                                Oxer,
                                Fredo
                                No, it doesn't work in previous version.
                                I haven't probed other Mac OS versions.
                                • P Offline
                                  Pherim
                                  This is really great, thank you for fulfilling my request!
                                  It works great, just how I wanted it to. [[Just one small thing: It would be perfect to me if the "sample material" tool could also adopt the scale of the sampled material.
                                  I hope I don't bother you with my daydreams... πŸ˜’]] edit: never mind, it works perfectly! πŸ‘
                                  • fredo6F Offline
                                    fredo6
                                    Oxer,
                                    Strange because it works for some other Mac users
                                    Could you type in the Ruby Console
                                    • VK_DOWN
                                    • VK_UP
                                    • VK_LEFT
                                    • VK_RIGHT
                                    Fredo
                                    • OxerO Offline
                                      Oxer
                                      This is the result in the Ruby Console:
                                        moghamdi
                                        Thank you Fredo for this nice Plugin.
                                        I have a problem
                                        I have a Mac 10.6.8 and I cannot transform the texture. I tried all 3 ways you mentioned but they did not work.
                                        • fredo6F Offline
                                          fredo6
                                          I have a problem
                                          Could you open the Ruby console and see if something is displayed.
                                          It seems that the Arrows don't work on all Mac, but the VCB and Visual Editor should normally function correctly.
                                          Fredo
                                          • fredo6F Offline
                                            fredo6
                                            [attachment=0:23qhhc8q]<!-- ia0 -->Ruby Console.jpg<!-- ia0 -->[/attachment:23qhhc8q]
                                            Oxer,
                                            Thanks. Interesting to see that the value may be different depending on the Mac versions (on the Mac I have access to, VK_DOWN = 63233
                                            Anyway, ThruPaint only use the symbolic constant value VK_DOWN and therefore should not be impacted by the internal value of the Arrows constants.
                                            It seems also that several Mac users don't have any problem with the Arrows on Mac.
                                            Just in case, could you type in the Ruby Console Traductor.new_check_key(VK_DOWN, 0, 0).
                                            Also, when you try to exercise transformation by arrows on texture, could you leave the Ruby console open to see if an error message is displayed. Also, make sure that the focus is on the Sketchup window when typing the arrows.
                                            Fredo
                                            • 6
                                            • 16
                                            • 17
                                            • 4 / 17
