    [Plugin] SketchUV - now free
    176 Posts 62 Posters 159.0k Views 62 Watching
    • McGyverM Offline
      McGyver
      Hi there, sorry to a bother...
      I just purchased and installed SketchUV and I can not find it anywhere in SU... No toolbar, no listing in the plugins menu.
      It has been placed correctly in the plugins folder as far as I can tell... Macintosh HD/Library/Application Support/Google Sketchup 6 /SketchUp/Plugins.
      I tried it in SU 6 and 8 and it does not show up.
      The downloaded file was SketchUV.rbz
      I have never installed a RBZ file so far, could this be a problem? Does this require a password or some other method of activation?
      Is this a PC only plugin?
      In case you need to know: 2 GHz Intel Core 2 Duo running OS 10.5.8
      Thank you for any assistance in this matter.
      Visit My ShareCG Freebie Gallery
      • Rich O BrienR Online
        Check the preferences panel for install extension
        Or rename .rbz to .zip and extract
        Download the free D'oh Book for SketchUp šŸ“–
        • W Offline
          Whaat
          Hello! I think you will find all of your answers in the manual:
          http://dl.dropbox.com/u/22333105/SketchUV%20Tutorials/SketchUV%20Manual.pdf
          Let me know if you need further assistance.
          Thanks for purchasing!
          • W Offline
            Whaat
            Absolutely no bother! We've all had those moments. RBZ is a still a very new thing.
            • McGyverM Offline
              McGyver
              Thank you Whaat, you are VERY quick to respond!
              Sorry to have bothered you...
              Apparently I just had a "DOH!" Homer Simpson moment... The rb part of rbz threw me off and I thought it was a different version of .rb.... like .rbs.
              I've actually had this problem before (and apparently totally erased it from my tiny memory)... I googled the problem right after the post and when I realized I've had this problem before, I wanted slap my brain... sorry to bother you.
              I used stuffit expander and now I see the appropriate files.
              Once again, thank you for the quick response.
              Edited to add- Thank you Rich O'Brien too... I just noticed your reply!
                You can use this utility to help you install plugins, either in RB, RBS, RBZ or ZIP format: http://forums.sketchucation.com/viewtopic.php?f=323&t=42315
                • N Offline
                  nektares
                  You have no idea how happy i was when i saw this on my tablet. Rushed to my office and bought it right away.
                  I wated for this for ages, no joke. I have no words to describe how happy i am with this. Thanks!
                  in 3 mins i was already getting what i expected, between this and the two venti“s i drank today i“m sure i will not be able to sleep tonight. This is fantastic
                  first test
                  here“s a link to a higher res image of the quick Thea render test of the UV mapping.
                  http://i249.photobucket.com/albums/gg239/nektares/Sketchuvtest1.jpg
                  • W Offline
                    Whaat
                    Great to read your enthusiasm! Nice render! (Hope you got some sleep šŸ˜† )
                    • HieruH Offline
                      Hieru
                      Really loving this plugin and what I can now do inside SU with UVs.
                      I do however have a small problem when it comes to exporting UVs for more complex shapes. I accidentally chose a project specific location for the exported OBJ file. Is there a way to reset this?
                      www.davidhier.co.uk
                        Plugins > SketchUV > Set Export Path
                        • HieruH Offline
                          Hieru
                          Doh!
                          Thanks Rich 😳
                          www.davidhier.co.uk
                          • brodieB Offline
                            brodie
                            Great job Whaat. I've only used it a bit but the Loop tool alone is worth the cost of admission. I've tried some alternatives with no success.
                            And the Tube mapping works brilliantly. Absolutely on my 'must have' list. As far as I can tell this pretty much solves SU's lack of UV functionality. And what's more, it seems to work in a very SU like way, very intuitive, just a couple buttons and pretty easy to figure out after skimming through the youtube tutorials.
                            I can't recommend it highly enough. Let me know if you ever need a kidney.
                            -Brodie
                            • W Offline
                              Whaat
                              -Brodie
                              Thanks Brodie, that made my day! šŸ˜„
                                redlerred7
                                @whaat said:
                                Super impressive!!
                                I have a question in regards to exporting a finished model (to OBJ or DAE)...
                                With some plugins that allow you to modify, or reposition a texture, when the finished model is exported, multiple copies of the texture image are generated (or in some cases, copies of parts of the image)... does this occur with SketchUV?
                                Thank you in advance for any info.
                                Hi. Your question is answered in this tutorial:
                                [flash=560,315:vj7sa93i]http://www.youtube.com/v/baQwxL6mgMQ[/flash:vj7sa93i]
                                That saved my computer's life when it came to the number of files SU used the chuck at me when I exported
                                • MasterhandM Offline
                                  Masterhand
                                  Hey guys, I'm new in participation but not in the forum, besides I like to follow the forum by the tremendous training has published its knowledge is almost unnecessary to ask.
                                  I do not possess a card or even payment method, not to mention that in my country 15 dollars (a price more than cheap), multiplies by 5.
                                  So the question is: is there any free alternative or method that allows me to export all the textures used as one as shown in the video?
                                    Well, there is the old UVTools 0.2 by Whaat: http://forums.sketchucation.com/viewtopic.php?t=23725
                                    Though, it is not by near as good as this one.
                                      Masterhand
                                      Thom thank you very much for the quick reply, I have lowered that UVTools but has no option to export the texture as one.
                                      Is there a procedure I am ignorant to do so? or UVtools.rb which one should I download?
                                        There is not a plugin which exports all mapped textures in a model to one texture file.
                                        Ultimate Unwrap 3D can do this with imported .skp files but I haven't tried it yet. It's also about $50 so more expensive than this plugin.
                                        • I Offline
                                          iwayan.ekadiana
                                          Hi, Is there any one can help me with the problem: I have bought and downloaded the sketchUV plugin then following the standard installation instruction, but when I run my sketchup i cannot locate where the toolbar is. How to show the tool bar? I tried to find them in the view/tool bar menu, tools, plugins, but it's seems no where to find. Is there anything that i missed when installing maybe? šŸ˜•
                                            agrazdi
                                            Smustard guide
                                            • 8
                                            • 9
                                            • 3 / 9
