    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 100.7k Views 23 Watching
    • guanjinG Offline
      guanjin
      @sdmitch said:
      Another day, another update!
      Hallo sdmitch
      Freedom to change the size is too important!
      But still quite useful
      I come from China, is to learn
      • mitcorbM Offline
        mitcorb
        Hi.
        Guanjin is suggesting what sounds like a Dynamic Component? Adjust the component with change in room size and the tool inserts additional tees as required, as well as stretches tees and angles. Seems pretty involved, but maybe not.
        • sdmitchS Offline
          sdmitch
          @guanjin said:
          Hallo sdmitch
          If you have other standard sizes you would like to use, simply add them to the code. If you don't feel capable of doing that, tell me what you would like to have as size options.
          http://sdmitch.blogspot.com/
          • sdmitchS Offline
            sdmitch
            Yes, yet another update incorperating two suggested inhancements.
            • RonSR Offline
              RonS
              Thank You Sam. Great plugin
              Design is not just what it looks like and feels like. Design is how it works.
              Steve Jobs
              RonS
              • massimoM Offline
                massimo Moderator
                Thanks for the very useful plugin Sam. 👍
                It would be even more useful if you could select an edge as orientation of the grid and maybe if you could have the possibility to choose the corner wich you want the grid to start from. Now it produces incorrect results with not conventional shapes.
                  tomot
                  Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! 🎉
                  my plugins
                  tomot
                    SUFractal
                    Beautiful! Thanks sdmitch.
                    • sdmitchS Offline
                      sdmitch
                      One last update I hope.
                      • mitcorbM Offline
                        mitcorb
                        "Hope springs eternal"
                          SUFractal
                          tomot, since you appear to be savvy creating plugins, I'm guessing you might be able to add in the ceiling tiles as a component? 😄
                          • guanjinG Offline
                            guanjin
                            Can realize the filling choice? 👍 in time of need
                              tomot
                              With all due respect, I think sdmitch should do this, after all its his code, and he is much more Ruby skilled than I am.
                              my plugins
                              tomot
                                SUFractal
                                You're right ... that makes perfect sense tomot ... my bad.
                                • sdmitchS Offline
                                  sdmitch
                                  Other than tomot, anyone else interested in having the option to add the ceiling tiles?
                                    SUFractal
                                    Yes please.
                                    • RonSR Offline
                                      RonS
                                      I would be interested. That would top off the plugin. This will be a big time saver.
                                      Steve Jobs
                                      RonS
                                      • gullfoG Offline
                                        gullfo
                                        yes, please.
                                        Glenn
                                        http://www.runnel.com
                                        • sdmitchS Offline
                                          sdmitch
                                          Yet another final update with the option to add tiles to the grid.
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks Sam. 👍
                                            Two little things after a very quick test:
                                            -the faces of the tiles pointing inside the room are back-faces. This could be a problem if you want to do a render;
                                            -would be possible that the tiles were components? I mean in that way you could easily change the texture for example and the model would be lighter.
                                            • 2 / 5
