    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 110.7k Views 23 Watching
      SUFractal
      Beautiful! Thanks sdmitch.
      • sdmitchS
        sdmitch
        One last update I hope.
        http://sdmitch.blogspot.com/
        • mitcorbM
          mitcorb
          "Hope springs eternal"
            SUFractal
            @tomot said:
            Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! πŸŽ‰
            tomot, since you appear to be savvy creating plugins, I'm guessing you might be able to add in the ceiling tiles as a component? πŸ˜„
            • guanjinG
              guanjin
              @sdmitch said:
              Yes, yet another update incorperating two suggested inhancements.
              Can realize the filling choice? πŸ‘ in time of need
              • T
                tomot
                With all due respect, I think sdmitch should do this, after all its his code, and he is much more Ruby skilled than I am.
                my plugins
                tomot
                  SUFractal
                  You're right ... that makes perfect sense tomot ... my bad.
                  • sdmitchS
                    sdmitch
                    Other than tomot, anyone else interested in having the option to add the ceiling tiles?
                      SUFractal
                      Yes please.
                      • RonSR
                        RonS
                        I would be interested. That would top off the plugin. This will be a big time saver.
                        Design is not just what it looks like and feels like. Design is how it works.
                        Steve Jobs
                        RonS
                        • gullfoG
                          gullfo
                          yes, please.
                          Glenn
                          http://www.runnel.com
                          • sdmitchS
                            sdmitch
                            Yet another final update with the option to add tiles to the grid.
                            • massimoM
                              massimo Moderator
                              Thanks Sam. πŸ‘
                              Two little things after a very quick test:
                              -the faces of the tiles pointing inside the room are back-faces. This could be a problem if you want to do a render;
                              -would be possible that the tiles were components? I mean in that way you could easily change the texture for example and the model would be lighter.
                              • sdmitchS
                                sdmitch
                                I beg to differ. The faces pointing into the room are front faces. I only apply material to the front face so, if they were back faces, you would not be able to see it.
                                Making the tiles components is impractical. Yes, all the full tiles could be a single component, but any and all partials would have to be unique components. You could not edit one and affect them all.
                                • massimoM
                                  massimo Moderator
                                  Then I'm probably doing something wrong. It's the same starting with a back or a front face.
                                  That's why it would be really useful. πŸ˜‰
                                  • guanjinG
                                    guanjin
                                    Same face of the front are generally below, upside down is a problem
                                    • sdmitchS
                                      sdmitch
                                      Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
                                        Mra
                                        The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
                                        One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
                                        • sdmitchS
                                          sdmitch
                                          mra, you are right. Don't know why I thought that actual tiles were necessary.
                                          massimo, It seems you were right also. It seems that the pushpull operation "flips" the face and apparently moves the texture to the back. How weird is that.
                                          • Z
                                            ZFRPS
                                            Hi:
                                            Dear sdmitch,your plugin nice,maybe have little need to change:
                                            sketchup is bim
                                            • 2 / 5
