    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 106.1k Views 23 Watching
    • massimoM
      massimo Moderator
      Thanks for the very useful plugin Sam. πŸ‘
      It would be even more useful if you could select an edge as orientation of the grid and maybe if you could have the possibility to choose the corner wich you want the grid to start from. Now it produces incorrect results with not conventional shapes.
      • T
        tomot
        Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! πŸŽ‰
        my plugins
        tomot
          SUFractal
          Beautiful! Thanks sdmitch.
          • sdmitchS
            sdmitch
            One last update I hope.
            http://sdmitch.blogspot.com/
            • mitcorbM
              mitcorb
              "Hope springs eternal"
                SUFractal
                tomot, since you appear to be savvy creating plugins, I'm guessing you might be able to add in the ceiling tiles as a component? πŸ˜„
                • guanjinG
                  guanjin
                  @sdmitch said:
                  Yes, yet another update incorperating two suggested inhancements.
                  Can realize the filling choice? πŸ‘ in time of need
                  • T
                    tomot
                    With all due respect, I think sdmitch should do this, after all its his code, and he is much more Ruby skilled than I am.
                    my plugins
                    tomot
                      SUFractal
                      You're right ... that makes perfect sense tomot ... my bad.
                      • sdmitchS
                        sdmitch
                        Other than tomot, anyone else interested in having the option to add the ceiling tiles?
                          SUFractal
                          Yes please.
                          • RonSR
                            RonS
                            I would be interested. That would top off the plugin. This will be a big time saver.
                            Design is not just what it looks like and feels like. Design is how it works.
                            Steve Jobs
                            RonS
                            • gullfoG
                              gullfo
                              yes, please.
                              Glenn
                              http://www.runnel.com
                              • sdmitchS
                                sdmitch
                                Yet another final update with the option to add tiles to the grid.
                                • massimoM
                                  massimo Moderator
                                  Thanks Sam. πŸ‘
                                  Two little things after a very quick test:
                                  -the faces of the tiles pointing inside the room are back-faces. This could be a problem if you want to do a render;
                                  -would be possible that the tiles were components? I mean in that way you could easily change the texture for example and the model would be lighter.
                                  • sdmitchS
                                    sdmitch
                                    I beg to differ. The faces pointing into the room are front faces. I only apply material to the front face so, if they were back faces, you would not be able to see it.
                                    Making the tiles components is impractical. Yes, all the full tiles could be a single component, but any and all partials would have to be unique components. You could not edit one and affect them all.
                                    • massimoM
                                      massimo Moderator
                                      Then I'm probably doing something wrong. It's the same starting with a back or a front face.
                                      That's why it would be really useful. πŸ˜‰
                                      • guanjinG
                                        guanjin
                                        Same face of the front are generally below, upside down is a problem
                                        • sdmitchS
                                          sdmitch
                                          Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
                                            Mra
                                            The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
                                            One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
                                            • 2 / 5
