    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 101.5k Views 23 Watching
    • sdmitchS Offline
      sdmitch
      juanjin, I didn't really choose the negative view. As you know when you draw a shape on the xy plane, its' face down and so that how the plugin was created and tested.
      SUFractal, I chose starting in a corner to limit the number of partial tiles but there is no reason that the origin counldn't be in the center of the face.
      http://sdmitch.blogspot.com/
      • sdmitchS Offline
        sdmitch
        Another day, another update!
          SUFractal
          Excellent sdmitch!
          As you probably know, that is how grids are generally laid out (design and construction). 😄
          • guanjinG Offline
            guanjin
            Hallo sdmitch
            Freedom to change the size is too important!
            But still quite useful
            • mitcorbM Offline
              mitcorb
              Hi.
              Guanjin is suggesting what sounds like a Dynamic Component? Adjust the component with change in room size and the tool inserts additional tees as required, as well as stretches tees and angles. Seems pretty involved, but maybe not.
              • sdmitchS Offline
                sdmitch
                @guanjin said:
                Hallo sdmitch
                If you have other standard sizes you would like to use, simply add them to the code. If you don't feel capable of doing that, tell me what you would like to have as size options.
                • sdmitchS Offline
                  sdmitch
                  Yes, yet another update incorperating two suggested inhancements.
                  • RonSR Offline
                    RonS
                    Thank You Sam. Great plugin
                    Design is not just what it looks like and feels like. Design is how it works.
                    Steve Jobs
                    RonS
                    • massimoM Offline
                      massimo Moderator
                      Thanks for the very useful plugin Sam. 👍
                      It would be even more useful if you could select an edge as orientation of the grid and maybe if you could have the possibility to choose the corner wich you want the grid to start from. Now it produces incorrect results with not conventional shapes.
                        tomot
                        Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! 🎉
                        my plugins
                        tomot
                          SUFractal
                          Beautiful! Thanks sdmitch.
                          • sdmitchS Offline
                            sdmitch
                            One last update I hope.
                            • mitcorbM Offline
                              mitcorb
                              "Hope springs eternal"
                                SUFractal
                                tomot, since you appear to be savvy creating plugins, I'm guessing you might be able to add in the ceiling tiles as a component? 😄
                                • guanjinG Offline
                                  guanjin
                                  Can realize the filling choice? 👍 in time of need
                                    tomot
                                    With all due respect, I think sdmitch should do this, after all its his code, and he is much more Ruby skilled than I am.
                                    my plugins
                                    tomot
                                      SUFractal
                                      You're right ... that makes perfect sense tomot ... my bad.
                                      • sdmitchS Offline
                                        sdmitch
                                        Other than tomot, anyone else interested in having the option to add the ceiling tiles?
                                          SUFractal
                                          Yes please.
                                          • RonSR Offline
                                            RonS
                                            I would be interested. That would top off the plugin. This will be a big time saver.
                                            Steve Jobs
                                            RonS
                                            • 2 / 5
