    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 107.2k Views 23 Watching
    • sdmitchS
      sdmitch
      Another day, another update!
      http://sdmitch.blogspot.com/
        SUFractal
        Excellent sdmitch!
        As you probably know, that is how grids are generally laid out (design and construction). 😄
        • guanjinG
          guanjin
          Hallo sdmitch
          Freedom to change the size is too important!
          But still quite useful
          • mitcorbM
            mitcorb
            Hi.
            Guanjin is suggesting what sounds like a Dynamic Component? Adjust the component with change in room size and the tool inserts additional tees as required, as well as stretches tees and angles. Seems pretty involved, but maybe not.
            • sdmitchS
              sdmitch
              @guanjin said:
              Hallo sdmitch
              If you have other standard sizes you would like to use, simply add them to the code. If you don't feel capable of doing that, tell me what you would like to have as size options.
              • sdmitchS
                sdmitch
                Yes, yet another update incorperating two suggested inhancements.
                • RonSR
                  RonS
                  Thank You Sam. Great plugin
                  Design is not just what it looks like and feels like. Design is how it works.
                  Steve Jobs
                  RonS
                  • massimoM
                    massimo Moderator
                    Thanks for the very useful plugin Sam. 👍
                    It would be even more useful if you could select an edge as orientation of the grid and maybe if you could have the possibility to choose the corner wich you want the grid to start from. Now it produces incorrect results with not conventional shapes.
                    • T
                      tomot
                      Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! 🎉
                      my plugins
                      tomot
                        SUFractal
                        Beautiful! Thanks sdmitch.
                        • sdmitchS
                          sdmitch
                          One last update I hope.
                          • mitcorbM
                            mitcorb
                            "Hope springs eternal"
                              SUFractal
                              tomot, since you appear to be savvy creating plugins, I'm guessing you might be able to add in the ceiling tiles as a component? 😄
                              • guanjinG
                                guanjin
                                Can realize the filling choice? 👍 in time of need
                                • T
                                  tomot
                                  With all due respect, I think sdmitch should do this, after all its his code, and he is much more Ruby skilled than I am.
                                  my plugins
                                  tomot
                                    SUFractal
                                    You're right ... that makes perfect sense tomot ... my bad.
                                    • sdmitchS
                                      sdmitch
                                      Other than tomot, anyone else interested in having the option to add the ceiling tiles?
                                        SUFractal
                                        Yes please.
                                        • RonSR
                                          RonS
                                          I would be interested. That would top off the plugin. This will be a big time saver.
                                          Steve Jobs
                                          RonS
                                          • gullfoG
                                            gullfo
                                            yes, please.
                                            Glenn
                                            http://www.runnel.com
                                            • 2 / 5
