    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 102.2k Views 23 Watching
      SUFractal
      @tomot said:
      Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! πŸŽ‰
      tomot, since you appear to be savvy creating plugins, I'm guessing you might be able to add in the ceiling tiles as a component? πŸ˜„
      • guanjinG Offline
        guanjin
        @sdmitch said:
        Yes, yet another update incorperating two suggested inhancements.
        Can realize the filling choice? πŸ‘ in time of need
          tomot
          With all due respect, I think sdmitch should do this, after all its his code, and he is much more Ruby skilled than I am.
          my plugins
          tomot
            SUFractal
            You're right ... that makes perfect sense tomot ... my bad.
            • sdmitchS Offline
              sdmitch
              Other than tomot, anyone else interested in having the option to add the ceiling tiles?
              http://sdmitch.blogspot.com/
                SUFractal
                Yes please.
                • RonSR Offline
                  RonS
                  I would be interested. That would top off the plugin. This will be a big time saver.
                  Design is not just what it looks like and feels like. Design is how it works.
                  Steve Jobs
                  RonS
                  • gullfoG Offline
                    gullfo
                    yes, please.
                    Glenn
                    http://www.runnel.com
                    • sdmitchS Offline
                      sdmitch
                      Yet another final update with the option to add tiles to the grid.
                      • massimoM Offline
                        massimo Moderator
                        Thanks Sam. πŸ‘
                        Two little things after a very quick test:
                        -the faces of the tiles pointing inside the room are back-faces. This could be a problem if you want to do a render;
                        -would be possible that the tiles were components? I mean in that way you could easily change the texture for example and the model would be lighter.
                        • sdmitchS Offline
                          sdmitch
                          I beg to differ. The faces pointing into the room are front faces. I only apply material to the front face so, if they were back faces, you would not be able to see it.
                          Making the tiles components is impractical. Yes, all the full tiles could be a single component, but any and all partials would have to be unique components. You could not edit one and affect them all.
                          • massimoM Offline
                            massimo Moderator
                            Then I'm probably doing something wrong. It's the same starting with a back or a front face.
                            That's why it would be really useful. πŸ˜‰
                            • guanjinG Offline
                              guanjin
                              Same face of the front are generally below, upside down is a problem
                              • sdmitchS Offline
                                sdmitch
                                Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
                                  Mra
                                  The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
                                  One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
                                  • sdmitchS Offline
                                    sdmitch
                                    mra, you are right. Don't know why I thought that actual tiles were necessary.
                                    massimo, It seems you were right also. It seems that the pushpull operation "flips" the face and apparently moves the texture to the back. How weird is that.
                                    • Z Offline
                                      ZFRPS
                                      Hi:
                                      Dear sdmitch,your plugin nice,maybe have little need to change:
                                      sketchup is bim
                                        SUFractal
                                        Sdmitch ... I was getting an odd result when I tried your latest update. Some of the tiles were positioned low, and some were high ... and faces were flipped too?
                                          tomot
                                          Hi:
                                          Please lets not get carried away here! whats ... next a request for the actual supporting hanger holes and hanger wires? πŸ‘Ž
                                          my plugins
                                          tomot
                                            SUFractal
                                            @tomot said:
                                            Hi:
                                            πŸ˜„
                                            • 2 / 5
