    Hide dimensions text
    14 Posts 4 Posters 6.4k Views 4 Watching
    • K
      KeeneAnderson
      Good day,
      I have been working on graphics for a guidebook and the editor has requested my images without text. Is there any way to 'hide' all the text including the dimension text without the dimension lines and leaders changing?
      KA
      • TIGT
        You could write some short code [one-liner pasted into the Ruby Console + <enter>] to replace all text using ' ' [space], that way all text in the model [use a copy please!] becomes ' ', you'll keep the leader, but the text is then 'invisible'.
        Sketchup.entities.each{|e|e.text=" " if e.class==Sketchup::Text}
        to process Text inside nested groups/components try
        Sketchup.definitions.each{|d|next if d.image?;d.entities.each{|e|e.text=" " if e.class==Sketchup::Text}}
        Unfortunately there's no equivalent code to do the same with a 'dimension'.
        If you want to have the dimension line/arrows without any text, then you must edit each one manually in turn ,and replace [paste] the text with ' '...
        πŸ€“
        • K
          KeeneAnderson
          Thanks for the quick response! Unfortunetely my code and ruby console experience falls into a catagory between zero and ziltch. 😞 However, the images that I am producing aren't that text and dimension extensive and manually editing each one shouldn't be a problem. What is the 'input' that I replace the text with in order to have it 'invisible'?
          ' '... = apostrophy, space, apostrophy, period, period, period ?
          Cheers
          KA
            If you are just editing the dimension text manually, just use a space. No apostrophes. That would be a catastrophe. πŸ˜„
            • K
              KeeneAnderson
              That works perfect! Saved me from a catastrophe. πŸ˜† Thanks again!
              • TIGT
                If I had put a space alone without the '' you wouldn't have seen it, and if I typed it as 'space' you'd have typed it πŸ˜’
                BTW IF you want to revert to the actual dimension add <>
                If you want to add text AND the actual dimension use TEXT <> and the <> part is auto-replaced with the dimension in current units.
                πŸ˜•
                • jgbJ
                  jgb
                  Simpler yet, just put all your text/dimension objects on a separate Documentation layer. That way you can turn them on or off at will.
                  jgb
                    How do you separate the dimension text from the arrows?
                    • jgbJ
                      jgb
                      Good point; I thought he meant all of the dim.
                      I will slink off now.... 😳
                      jgb
                      • TIGT
                        You can't layer a dim's geometry and text separately.
                        However, layering dims/text IS a very useful tool...
                        To 'hide' a dim's text, but leave its line/arrows you have to replace the dim's text with a space ' '...
                        OR make/find/install a custom ttf font where all the characters are 'blank' and then use that font for your [selected] dims [temporarily], so they are not visible [but retain their text, with not further editing needed].
                        Later on you can swap back to a standard font - say 'Arial' - which makes the dim's text visible again...
                        • jgbJ
                          jgb
                          I started to play with this, however limited that is.
                          One partial solution (sort of!) is to make the text 1 point or .001 in high. That effectively makes the text almost invisible (looks like a small line) πŸ‘ but, and a big but... the arrowheads also disappear. πŸ‘Ž πŸ˜’
                          jgb
                          • TIGT
                            Get a 'blank ttf' Font... This 'Invisble.ttf' is OK. The 'infinity' symbol is its visible character [tiny dot]...Invisible.zipCapture.PNG
                            • jgbJ
                              jgb
                              This would be ideal to hide copyright notices within the model.
                              See topic.....
                              http://forums.sketchucation.com/viewtopic.php?f=15&t=42399&p=379799#p379799
                              jgb
                                See topic.....
                                πŸ‘
