    Hide dimensions text
    14 Posts 4 Posters 6.4k Views 4 Watching
    • K
      KeeneAnderson
      That works perfect! Saved me from a catastrophe. πŸ˜† Thanks again!
        If I had put a space alone without the '' you wouldn't have seen it, and if I typed it as 'space' you'd have typed it πŸ˜’
        BTW IF you want to revert to the actual dimension add <>
        If you want to add text AND the actual dimension use TEXT <> and the <> part is auto-replaced with the dimension in current units.
        πŸ˜•
        • jgbJ
          jgb
          Simpler yet, just put all your text/dimension objects on a separate Documentation layer. That way you can turn them on or off at will.
          jgb
            How do you separate the dimension text from the arrows?
            • jgbJ
              jgb
              Good point; I thought he meant all of the dim.
              I will slink off now.... 😳
              jgb
                You can't layer a dim's geometry and text separately.
                However, layering dims/text IS a very useful tool...
                To 'hide' a dim's text, but leave its line/arrows you have to replace the dim's text with a space ' '...
                OR make/find/install a custom ttf font where all the characters are 'blank' and then use that font for your [selected] dims [temporarily], so they are not visible [but retain their text, with not further editing needed].
                Later on you can swap back to a standard font - say 'Arial' - which makes the dim's text visible again...
                • jgbJ
                  jgb
                  I started to play with this, however limited that is.
                  One partial solution (sort of!) is to make the text 1 point or .001 in high. That effectively makes the text almost invisible (looks like a small line) πŸ‘ but, and a big but... the arrowheads also disappear. πŸ‘Ž πŸ˜’
                  jgb
                    Get a 'blank ttf' Font... This 'Invisble.ttf' is OK. The 'infinity' symbol is its visible character [tiny dot]...Invisible.zipCapture.PNG
                    • jgbJ
                      jgb
                      This would be ideal to hide copyright notices within the model.
                      See topic.....
                      404 Not Found
                      (forums.sketchucation.com)
                      jgb
                        See topic.....
                        404 Not Found
                        πŸ‘
