    Hide dimensions text
    14 Posts 4 Posters 6.5k Views 4 Watching
      If you are just editing the dimension text manually, just use a space. No apostrophes. That would be a catastrophe. πŸ˜„
      • K
        KeeneAnderson
        That works perfect! Saved me from a catastrophe. πŸ˜† Thanks again!
          If I had put a space alone without the '' you wouldn't have seen it, and if I typed it as 'space' you'd have typed it πŸ˜’
          BTW IF you want to revert to the actual dimension add <>
          If you want to add text AND the actual dimension use TEXT <> and the <> part is auto-replaced with the dimension in current units.
          πŸ˜•
          • jgbJ
            jgb
            Simpler yet, just put all your text/dimension objects on a separate Documentation layer. That way you can turn them on or off at will.
            jgb
              How do you separate the dimension text from the arrows?
              • jgbJ
                jgb
                Good point; I thought he meant all of the dim.
                I will slink off now.... 😳
                jgb
                  You can't layer a dim's geometry and text separately.
                  However, layering dims/text IS a very useful tool...
                  To 'hide' a dim's text, but leave its line/arrows you have to replace the dim's text with a space ' '...
                  OR make/find/install a custom ttf font where all the characters are 'blank' and then use that font for your [selected] dims [temporarily], so they are not visible [but retain their text, with not further editing needed].
                  Later on you can swap back to a standard font - say 'Arial' - which makes the dim's text visible again...
                  • jgbJ
                    jgb
                    I started to play with this, however limited that is.
                    One partial solution (sort of!) is to make the text 1 point or .001 in high. That effectively makes the text almost invisible (looks like a small line) πŸ‘ but, and a big but... the arrowheads also disappear. πŸ‘Ž πŸ˜’
                    jgb
                      Get a 'blank ttf' Font... This 'Invisble.ttf' is OK. The 'infinity' symbol is its visible character [tiny dot]...Invisible.zipCapture.PNG
                      • jgbJ
                        jgb
                        This would be ideal to hide copyright notices within the model.
                        See topic.....
                        http://forums.sketchucation.com/viewtopic.php?f=15&t=42399&p=379799#p379799
                        jgb
                          See topic.....
                          πŸ‘
