    Hide dimensions text
    14 Posts 4 Posters 5.9k Views 4 Watching
      You could write some short code [one-liner pasted into the Ruby Console + <enter>] to replace all text using ' ' [space], that way all text in the model [use a copy please!] becomes ' ', you'll keep the leader, but the text is then 'invisible'.
      Sketchup.entities.each{|e|e.text=" " if e.class==Sketchup::Text}
      to process Text inside nested groups/components try
      Sketchup.definitions.each{|d|next if d.image?;d.entities.each{|e|e.text=" " if e.class==Sketchup::Text}}
      Unfortunately there's no equivalent code to do the same with a 'dimension'.
      If you want to have the dimension line/arrows without any text, then you must edit each one manually in turn ,and replace [paste] the text with ' '...
      πŸ€“
        KeeneAnderson
        Thanks for the quick response! Unfortunetely my code and ruby console experience falls into a catagory between zero and ziltch. 😞 However, the images that I am producing aren't that text and dimension extensive and manually editing each one shouldn't be a problem. What is the 'input' that I replace the text with in order to have it 'invisible'?
        ' '... = apostrophy, space, apostrophy, period, period, period ?
        Cheers
        KA
          If you are just editing the dimension text manually, just use a space. No apostrophes. That would be a catastrophe. πŸ˜„
            KeeneAnderson
            That works perfect! Saved me from a catastrophe. πŸ˜† Thanks again!
              If I had put a space alone without the '' you wouldn't have seen it, and if I typed it as 'space' you'd have typed it πŸ˜’
              BTW IF you want to revert to the actual dimension add <>
              If you want to add text AND the actual dimension use TEXT <> and the <> part is auto-replaced with the dimension in current units.
              πŸ˜•
              • jgbJ Offline
                jgb
                Simpler yet, just put all your text/dimension objects on a separate Documentation layer. That way you can turn them on or off at will.
                jgb
                  How do you separate the dimension text from the arrows?
                  • jgbJ Offline
                    jgb
                    Good point; I thought he meant all of the dim.
                    I will slink off now.... 😳
                    jgb
                      You can't layer a dim's geometry and text separately.
                      However, layering dims/text IS a very useful tool...
                      To 'hide' a dim's text, but leave its line/arrows you have to replace the dim's text with a space ' '...
                      OR make/find/install a custom ttf font where all the characters are 'blank' and then use that font for your [selected] dims [temporarily], so they are not visible [but retain their text, with not further editing needed].
                      Later on you can swap back to a standard font - say 'Arial' - which makes the dim's text visible again...
                      • jgbJ Offline
                        jgb
                        I started to play with this, however limited that is.
                        One partial solution (sort of!) is to make the text 1 point or .001 in high. That effectively makes the text almost invisible (looks like a small line) πŸ‘ but, and a big but... the arrowheads also disappear. πŸ‘Ž πŸ˜’
                        jgb
                          Get a 'blank ttf' Font... This 'Invisble.ttf' is OK. The 'infinity' symbol is its visible character [tiny dot]...Invisible.zipCapture.PNG
                          • jgbJ Offline
                            jgb
                            This would be ideal to hide copyright notices within the model.
                            See topic.....
                            http://forums.sketchucation.com/viewtopic.php?f=15&t=42399&p=379799#p379799
                            jgb
                              See topic.....
                              πŸ‘
