    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.1k Views 116 Watching
      What about my UV test tile? You don't like it?
      Yea I do. I gives a larger illustration of the UV flow.
      @tig said:
      Here are a couple I use.
      πŸ‘ πŸ‘
      • PixeroP Offline
        Pixero
        Hmm, for some reason I'm having trouble selecting the V direction.
        (Especially if I try to click on an outer edge.)
        Usually, selecting the U direction works.
        Then for V it doesnt select what I'm clicking on. πŸ˜•
        When I click the edge on the other side of the selected U edge, "mirrored from the first", it works more often, but the texture isn't applied as I would like. 😞
        I'm having this problem with every model I tried.
        SU 8, Windows 7 64.
        • dereiD Offline
          derei
          Hello, I noticed a error when opening a a second SU instance (if I have one already opened and I want a second one), you can see it here.
          Thank you.
          DESIGNER AND ARTIST DEREI.UK
            SU 8, Windows 7 64.
            Screenshots? Video?
              Thank you.
              Does that happen every time?
              After you've gotten such an error, what do you get if you open the Ruby Console and type load 'tt_quadface.rb'?
                Here's a little library of 10 UV maps.
                UV Map .skm Library
                Here's the pretty one you like...
                • dereiD Offline
                  derei
                  It does every time.
                  If I load it from console, it happens this:
                    Thanks - will look into it.
                    • cmeedC Offline
                      cmeed
                      great to see a video and what amazing work you put into this forum. really well done.
                      I'm trying this out for the first time and am having some trouble, the problem is that i can put a texture in but then cant change it to a new one
                      Its basically only works once and you can't map anything else to that shape. or i've missed something. - I'm on a mac
                      (suggestion - is there a roll over help pop up that can be used that when you leave the curser ove an icon a pop up help describes the function?)
                      • fredo6F Offline
                        fredo6
                        Tom,
                        Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                        Fredo
                        Quad mapping - Fred.skp
                          driven
                          fredo,
                          I painted your mesh first, using eye-dropper and bucket, then 'UV Map Selected' and it seems to work.
                          but I'm just starting as well...
                          john
                            jorge2011
                            thom thank you very much for this excellent tool.
                            I just noticed some problems to apply and modify materials, forms closed (loop)
                              Can you elaborate? Very vague description there..
                              • G Offline
                                gaonirico
                                Hi Thomthom
                                Thanks for the beautiful plugin that have created, very useful. Yesterday it was tasting very well and today when turn to start Sketchup 8 appears me the window with an error:
                                Error al cargar archivo C:/Program Files/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                                undefined method to_l' for nil:NilClassError al cargar archivo tt_quadface.rb undefined method to_l' for nil:NilClass
                                I have tasted by returning to install the plugin but appears me the same error
                                  tulacong
                                  very well
                                    @gaonirico said:
                                    Hi Thomthom
                                    I've gotten several reports on this. I'll try to get a patch out soon.
                                    • PixeroP Offline
                                      Pixero
                                      SU 8, Windows 7 64.
                                      Screenshots? Video?
                                      See PM.
                                        SU 8, Windows 7 64.
                                        Screenshots? Video?
                                        See PM.
                                        See reply. πŸ˜‰
                                        • charly2008C Offline
                                          charly2008
                                          Hi Fredo,
                                          I think you need before placing the texture on the face. Then you can scale the texture. Whether it is possible to be centered I do not know.
                                          The second example I have made with "UV Unwraps, copy and past UV"
                                            Need what? Selecting? If what you meant to say, then that is not needed. Selecting just limits the mapping to the selected mesh. Otherwise it maps the whole connected mesh.
                                            Pick the corner as starting point. The point where is axis cross is the origin of where the mapping is done.
                                            In a coming update I hope to add controls to adjust the starting point after picking the axis.
                                            • 6
                                            • 7
                                            • 33
                                            • 34
                                            • 5 / 34
