    [Plugin] QuadFaceTools
    680 Posts 116 Posters 744.9k Views 116 Watching
    • N
      notareal
      @thomthom said:
      Version 0.4.0
      Important!
      This version redefines what a QuadFace is. In order to use quad face meshes used by older versions you must update them.
      Tools > QuadFace Tools > Convert > Sandbox Quads to QuadFace Quads
      Stunning... You have done amazing work. I hope this will inspire others too. Thank you!
      • PixeroP
        Pixero
        Thanks soo much. Will study it.
          Has anyone gotten around to try the UV mapping feature?
          I know it has some issues and the UI needs improving.
          What worked and what didn't work? What's unclear and what is not?
            I did some quick tests.
            When using "Unwrap Picked Grid" it'd be nice if it used inferencing.
            Sometimes the texture reverses though I haven't reproduced this regularly.
            Other than that it's nomnomnomnomnomnomnomnomnomnomnom
              For placing the grid?
              O'RLY? o_O Let me know if you can reproduce it. And even if you can't, post the result?
              Btw, that UV test tile you got there... ?
                What about my UV test tile? You don't like it?
                  yes for placing the grid
                      Yea I do. I gives a larger illustration of the UV flow.
                      @tig said:
                      Here are a couple I use.
                      πŸ‘ πŸ‘
                      • PixeroP
                        Pixero
                        Hmm, for some reason I'm having trouble selecting the V direction.
                        (Especially if I try to click on an outer edge.)
                        Usually, selecting the U direction works.
                        Then for V it doesnt select what I'm clicking on. πŸ˜•
                        When I click the edge on the other side of the selected U edge, "mirrored from the first", it works more often, but the texture isn't applied as I would like. 😞
                        I'm having this problem with every model I tried.
                        SU 8, Windows 7 64.
                        • dereiD
                          derei
                          Hello, I noticed a error when opening a a second SU instance (if I have one already opened and I want a second one), you can see it here.
                          Thank you.
                          DESIGNER AND ARTIST DEREI.UK
                            SU 8, Windows 7 64.
                            Screenshots? Video?
                              Thank you.
                              Does that happen every time?
                              After you've gotten such an error, what do you get if you open the Ruby Console and type load 'tt_quadface.rb'?
                                Here's a little library of 10 UV maps.
                                UV Map .skm Library
                                Here's the pretty one you like...
                                • dereiD
                                  derei
                                  It does every time.
                                  If I load it from console, it happens this:
                                    Thanks - will look into it.
                                    • cmeedC
                                      cmeed
                                      great to see a video and what amazing work you put into this forum. really well done.
                                      I'm trying this out for the first time and am having some trouble, the problem is that i can put a texture in but then cant change it to a new one
                                      Its basically only works once and you can't map anything else to that shape. or i've missed something. - I'm on a mac
                                      (suggestion - is there a roll over help pop up that can be used that when you leave the curser ove an icon a pop up help describes the function?)
                                      • fredo6F
                                        Tom,
                                        Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                                        Quad mapping - Fred.skp
                                          driven
                                          fredo,
                                          I painted your mesh first, using eye-dropper and bucket, then 'UV Map Selected' and it seems to work.
                                          but I'm just starting as well...
                                            jorge2011
                                            thom thank you very much for this excellent tool.
                                            I just noticed some problems to apply and modify materials, forms closed (loop)
                                            • 33
                                            • 34
                                            • 5 / 34
