    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
      When using "Unwrap Picked Grid" it'd be nice if it used inferencing.
      For placing the grid?
      Sometimes the texture reverses though I haven't reproduced this regularly.
      O'RLY? o_O Let me know if you can reproduce it. And even if you can't, post the result?
      Btw, that UV test tile you got there... ?
        What about my UV test tile? You don't like it?
          yes for placing the grid
              Yea I do. I gives a larger illustration of the UV flow.
              @tig said:
              Here are a couple I use.
              πŸ‘ πŸ‘
              • PixeroP Offline
                Pixero
                Hmm, for some reason I'm having trouble selecting the V direction.
                (Especially if I try to click on an outer edge.)
                Usually, selecting the U direction works.
                Then for V it doesnt select what I'm clicking on. πŸ˜•
                When I click the edge on the other side of the selected U edge, "mirrored from the first", it works more often, but the texture isn't applied as I would like. 😞
                I'm having this problem with every model I tried.
                SU 8, Windows 7 64.
                • dereiD Offline
                  derei
                  Hello, I noticed a error when opening a a second SU instance (if I have one already opened and I want a second one), you can see it here.
                  Thank you.
                  DESIGNER AND ARTIST DEREI.UK
                    SU 8, Windows 7 64.
                    Screenshots? Video?
                      Thank you.
                      Does that happen every time?
                      After you've gotten such an error, what do you get if you open the Ruby Console and type load 'tt_quadface.rb'?
                        Here's a little library of 10 UV maps.
                        UV Map .skm Library
                        Here's the pretty one you like...
                        • dereiD Offline
                          derei
                          It does every time.
                          If I load it from console, it happens this:
                            Thanks - will look into it.
                            • cmeedC Offline
                              cmeed
                              great to see a video and what amazing work you put into this forum. really well done.
                              I'm trying this out for the first time and am having some trouble, the problem is that i can put a texture in but then cant change it to a new one
                              Its basically only works once and you can't map anything else to that shape. or i've missed something. - I'm on a mac
                              (suggestion - is there a roll over help pop up that can be used that when you leave the curser ove an icon a pop up help describes the function?)
                              • fredo6F Offline
                                Tom,
                                Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                                Quad mapping - Fred.skp
                                  driven
                                  fredo,
                                  I painted your mesh first, using eye-dropper and bucket, then 'UV Map Selected' and it seems to work.
                                  but I'm just starting as well...
                                    jorge2011
                                    thom thank you very much for this excellent tool.
                                    I just noticed some problems to apply and modify materials, forms closed (loop)
                                      Can you elaborate? Very vague description there..
                                        gaonirico
                                        Hi Thomthom
                                        Thanks for the beautiful plugin that have created, very useful. Yesterday it was tasting very well and today when turn to start Sketchup 8 appears me the window with an error:
                                        Error al cargar archivo C:/Program Files/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                                        undefined method to_l' for nil:NilClassError al cargar archivo tt_quadface.rb undefined method to_l' for nil:NilClass
                                        I have tasted by returning to install the plugin but appears me the same error
                                          tulacong
                                          very well
                                            @gaonirico said:
                                            Hi Thomthom
                                            I've gotten several reports on this. I'll try to get a patch out soon.
                                            • 33
                                            • 34
                                            • 5 / 34
