    [Plugin] View Parts (1.2) — Sept 13 2011
    35 Posts 24 Posters 39.7k Views 24 Watching
    • cmdC Offline
      cmd
      The View Parts ruby script will build a scene for every unique component and group in a selection set.
      The idea behind the ruby was to find a quick way to isolate and view each part of an assembly either for general viewing or to put into the SketchUp LayOut program for dimensioning and part arrangement.
      Here is a video to see it in action:
      UPDATE - 09-06-2011
      Changed code to reflect best practices mentioned by TIG.
      UPDATE - 09-13-2011
      Menu load correction
      Feel free to hack away at the ruby and improve it as you see fit.
      Enjoy !
      CMD
      version 1.2
      • CMD
      • Rich O BrienR Online
        Very useful. Thanks
        • EarthMoverE Offline
          EarthMover
          Very cool. This should be very handy for presentation work. ☀
          Content Creator at Skapeup
            Very interesting indeed. Thank you.
            • bazB Offline
              baz
              Useful, thanks.
              Baz
              • Chris FullmerC Offline
                Awesome, thanks for posting that Chris!
                All my Plugins I've written
                  Ben Ritter
                  Thank you.
                  • Bob JamesB Offline
                    Bob James
                    Thank you
                    • W Offline
                      wyatt
                      This is great. Thank you!
                      • spenceS Offline
                        spence
                        Oh this is fabulous, thanks Chris.
                        Spence
                        • Jean-FrancoJ Offline
                          Jean-Franco
                          Very useful, thank you !
                          Jean-Franco
                            studeag
                            Extremely usefull,
                            Thank you!
                              This is a very good idea. 😄
                              I have a few points...
                              Please remember to parenthesize you arguments, for future Ruby compatibility - e.g. it's best like
                              model.pages.add("Initial State")
                              and NOT
                              model.pages.add "Initial State"
                              I know the API is full of 'wrong' examples and they do work... BUT with changes to the way Ruby works across versions, then if they aren't inside () you will get issues...
                              You should protect you code inside a module - someone else might have also defined hideAll too in their 'unwrapped' code... which might mess up you [or them] !
                              So let's call it
                              ` module CMD
                              ALL code goes here
                              endThen recast your three methods with a leading self.like this def **self.**hideAll()
                              ...etc, Also ensure that any calls of those methods then appear as **self.**hideAll()etc The menu section also needs to use ...{**self.**viewParts()}if it's within the module, but if it's outside of the module then it becomes ...{**CMD.**viewParts()}`
                              Also you could replace the
                              if file_loaded?("viewparts.rb")
                              etc with
                              if file_loaded?(File.basename(__FILE__))
                              as __FILE__ returns the path to the script itself and doesn't rely on the file keeping a certain name.
                              Personally I'd also put this Tool under the 'View' menu rather than in 'Plugins'... but that's me...
                              Please don't take my comments as criticisms of a great idea, that's well executed - it's just that these minor tweaks would make it more 'robust'... 🤓
                              • MALAISEM Offline
                                MALAISE
                                Great tool for complex mechanisms
                                Thanks a lot
                                • fastech370F Offline
                                  fastech370
                                  Awesome Plugin. This saves a lot of time!!!!!
                                    driven
                                    hi,
                                    does anyone have this working on a mac... [EDIT-the examples on a mac!!!]
                                    I tried both standard and a version using TIG's mods, and although both create scenes, everything is hidden.
                                    the only way to see any content is to use 'edit>>unhide>>all' but then 'ALL' are unhidden in 'ALL' scenes.
                                    I tried using the hide 'other' feature to see the individual elements, but this gets zeroed when I switch pages[scenes].
                                    does the model need to have separate layers for each group/component?
                                    any ideas?
                                    john
                                    lovely model from 3d warehouse
                                      Jean-Franco
                                      I've the same situation under Windows XP 3.
                                      If I select components within a group and launch Viewparts, it creates all the needed scenes but all is hidden. And no way to unhide anything.
                                      Have a look at the attached file.
                                      Driven, If you don't mind, I'd like to have your updated script with TIG's modifications to do a test.
                                      I'm sorry but I'm really not a Ruby scripter.
                                      Thanks.
                                      cerificateur-scenes.skp
                                      Jean-Franco
                                      • yellow perilY Offline
                                        yellow peril
                                        Hi has anyone any idea why this script seams to lock up my files while using the arc tool, I have unstalled this excellent script and found that all is working fine, maybe its a mac issue, some help would be much appreciated........
                                        Thank You
                                          rjhorky
                                          for the life of me I cannot figure out why I cannot get this to work. I click on the link, save to the plugins folder within SU8. It does not show up anywhere but I can see it in the folder. Any ideas?
                                            Did you restart sketchUp after installing the file in the Plugins folder? Did it install with the .rb extension?
                                            • 1 / 2
