    [Plugin] View Parts (1.2) — Sept 13 2011
    35 Posts 24 Posters 41.5k Views 24 Watching
      Very useful. Thanks
      • EarthMoverE Offline
        EarthMover
        Very cool. This should be very handy for presentation work. ☀
        Content Creator at Skapeup
          Very interesting indeed. Thank you.
          • bazB Offline
            baz
            Useful, thanks.
            Baz
            • Chris FullmerC Offline
              Awesome, thanks for posting that Chris!
                Ben Ritter
                Thank you.
                • Bob JamesB Offline
                  Bob James
                  Thank you
                  • W Offline
                    wyatt
                    This is great. Thank you!
                    • spenceS Offline
                      spence
                      Oh this is fabulous, thanks Chris.
                      Spence
                      • Jean-FrancoJ Offline
                        Jean-Franco
                        Very useful, thank you !
                        Jean-Franco
                          studeag
                          Extremely usefull,
                          Thank you!
                            This is a very good idea. 😄
                            I have a few points...
                            Please remember to parenthesize you arguments, for future Ruby compatibility - e.g. it's best like
                            model.pages.add("Initial State")
                            and NOT
                            model.pages.add "Initial State"
                            I know the API is full of 'wrong' examples and they do work... BUT with changes to the way Ruby works across versions, then if they aren't inside () you will get issues...
                            You should protect you code inside a module - someone else might have also defined hideAll too in their 'unwrapped' code... which might mess up you [or them] !
                            So let's call it
                            ` module CMD
                            ALL code goes here
                            endThen recast your three methods with a leading self.like this def **self.**hideAll()
                            ...etc, Also ensure that any calls of those methods then appear as **self.**hideAll()etc The menu section also needs to use ...{**self.**viewParts()}if it's within the module, but if it's outside of the module then it becomes ...{**CMD.**viewParts()}`
                            Also you could replace the
                            if file_loaded?("viewparts.rb")
                            etc with
                            if file_loaded?(File.basename(__FILE__))
                            as __FILE__ returns the path to the script itself and doesn't rely on the file keeping a certain name.
                            Personally I'd also put this Tool under the 'View' menu rather than in 'Plugins'... but that's me...
                            Please don't take my comments as criticisms of a great idea, that's well executed - it's just that these minor tweaks would make it more 'robust'... 🤓
                            • MALAISEM Offline
                              MALAISE
                              Great tool for complex mechanisms
                              Thanks a lot
                              • fastech370F Offline
                                fastech370
                                Awesome Plugin. This saves a lot of time!!!!!
                                  driven
                                  hi,
                                  does anyone have this working on a mac... [EDIT-the examples on a mac!!!]
                                  I tried both standard and a version using TIG's mods, and although both create scenes, everything is hidden.
                                  the only way to see any content is to use 'edit>>unhide>>all' but then 'ALL' are unhidden in 'ALL' scenes.
                                  I tried using the hide 'other' feature to see the individual elements, but this gets zeroed when I switch pages[scenes].
                                  does the model need to have separate layers for each group/component?
                                  any ideas?
                                  lovely model from 3d warehouse
                                    Jean-Franco
                                    I've the same situation under Windows XP 3.
                                    If I select components within a group and launch Viewparts, it creates all the needed scenes but all is hidden. And no way to unhide anything.
                                    Have a look at the attached file.
                                    Driven, If you don't mind, I'd like to have your updated script with TIG's modifications to do a test.
                                    I'm sorry but I'm really not a Ruby scripter.
                                    Thanks.
                                    cerificateur-scenes.skp
                                    Jean-Franco
                                    • yellow perilY Offline
                                      yellow peril
                                      Hi has anyone any idea why this script seams to lock up my files while using the arc tool, I have unstalled this excellent script and found that all is working fine, maybe its a mac issue, some help would be much appreciated........
                                      Thank You
                                        rjhorky
                                        for the life of me I cannot figure out why I cannot get this to work. I click on the link, save to the plugins folder within SU8. It does not show up anywhere but I can see it in the folder. Any ideas?
                                          Did you restart sketchUp after installing the file in the Plugins folder? Did it install with the .rb extension?
                                            ksjoern
                                            The Plugin does not work with a Mac. I put it in the correct folder (Library/Application Support/Google SketchUp 8/SketchUp/plugins).
                                            The required 'sketchup.rb' is included in the TT_Lib2. But the plug-in window shows no entry "Exploded View"
                                            Any idea what I could change?
                                            Could it be a problem not working with an english system interface?
