    [Plugin] View Parts (1.2) — Sept 13 2011
    35 Posts 24 Posters 42.0k Views 24 Watching
    • spenceS
      spence
      Oh this is fabulous, thanks Chris.
      Spence
      • Jean-FrancoJ
        Jean-Franco
        Very useful, thank you !
        Jean-Franco
          studeag
          Extremely usefull,
          Thank you!
            This is a very good idea. 😄
            I have a few points...
            Please remember to parenthesize you arguments, for future Ruby compatibility - e.g. it's best like
            model.pages.add("Initial State")
            and NOT
            model.pages.add "Initial State"
            I know the API is full of 'wrong' examples and they do work... BUT with changes to the way Ruby works across versions, then if they aren't inside () you will get issues...
            You should protect you code inside a module - someone else might have also defined hideAll too in their 'unwrapped' code... which might mess up you [or them] !
            So let's call it
            ` module CMD
            ALL code goes here
            endThen recast your three methods with a leading self.like this def **self.**hideAll()
            ...etc, Also ensure that any calls of those methods then appear as **self.**hideAll()etc The menu section also needs to use ...{**self.**viewParts()}if it's within the module, but if it's outside of the module then it becomes ...{**CMD.**viewParts()}`
            Also you could replace the
            if file_loaded?("viewparts.rb")
            etc with
            if file_loaded?(File.basename(__FILE__))
            as __FILE__ returns the path to the script itself and doesn't rely on the file keeping a certain name.
            Personally I'd also put this Tool under the 'View' menu rather than in 'Plugins'... but that's me...
            Please don't take my comments as criticisms of a great idea, that's well executed - it's just that these minor tweaks would make it more 'robust'... 🤓
            • MALAISEM
              MALAISE
              Great tool for complex mechanisms
              Thanks a lot
              • fastech370F
                fastech370
                Awesome Plugin. This saves a lot of time!!!!!
                  driven
                  hi,
                  does anyone have this working on a mac... [EDIT-the examples on a mac!!!]
                  I tried both standard and a version using TIG's mods, and although both create scenes, everything is hidden.
                  the only way to see any content is to use 'edit>>unhide>>all' but then 'ALL' are unhidden in 'ALL' scenes.
                  I tried using the hide 'other' feature to see the individual elements, but this gets zeroed when I switch pages[scenes].
                  does the model need to have separate layers for each group/component?
                  any ideas?
                  lovely model from 3d warehouse
                  • Jean-FrancoJ
                    Jean-Franco
                    I've the same situation under Windows XP 3.
                    If I select components within a group and launch Viewparts, it creates all the needed scenes but all is hidden. And no way to unhide anything.
                    Have a look at the attached file.
                    Driven, If you don't mind, I'd like to have your updated script with TIG's modifications to do a test.
                    I'm sorry but I'm really not a Ruby scripter.
                    Thanks.
                    cerificateur-scenes.skp
                    Jean-Franco
                    • yellow perilY
                      yellow peril
                      Hi has anyone any idea why this script seams to lock up my files while using the arc tool, I have unstalled this excellent script and found that all is working fine, maybe its a mac issue, some help would be much appreciated........
                      Thank You
                        rjhorky
                        for the life of me I cannot figure out why I cannot get this to work. I click on the link, save to the plugins folder within SU8. It does not show up anywhere but I can see it in the folder. Any ideas?
                          Did you restart sketchUp after installing the file in the Plugins folder? Did it install with the .rb extension?
                          • K
                            ksjoern
                            The Plugin does not work with a Mac. I put it in the correct folder (Library/Application Support/Google SketchUp 8/SketchUp/plugins).
                            The required 'sketchup.rb' is included in the TT_Lib2. But the plug-in window shows no entry "Exploded View"
                            Any idea what I could change?
                            Could it be a problem not working with an english system interface?
                              No - this plugin has no dependance on TT_Lib2.
                              The required sketchup.rb is located in SketchUp's Tools folder. (Where it should stay.)
                                @driven said:
                                You need to have at least 1 group or component in your model,
                                you will then get a 'Parts>> views ' entry in the Plugin Menu,
                                Menus in the top level menus (File,Edit,View,Plugins,etc...) does not hide or show based on selection. They are fixed. Only context menus are dynamic like that.
                                  driven
                                  hi,
                                  you should have a 'Parts>> views ' entry in the Plugin Menu, [Edited following TT's comment..]
                                  click on that entry, choose your options and it will make the scenes.
                                  click on scene tabs to view.
                                  group a square, then try it out.
                                  if you open a drawing with lots of groups, it will make lots of scenes.
                                    driven
                                    edited my post, your are correct, I loaded it from console to test, so it wasn't there before , but was after... dohh
                                    • K
                                      ksjoern
                                      Great, now it works on my mac. - I've probably always have the downloaded previous (1.1) version.
                                        dannyver
                                        @jean-franco said:
                                        Thanks.
                                        [attachment=0:1k9cpp7m]<!-- ia0 -->cerificateur-scenes.skp<!-- ia0 -->[/attachment:1k9cpp7m]
                                        i have the same problem is ther any one ho has a answer or solution for this problem already ❓ ❓
                                          dannyver
                                          @dannyver said:
                                          @jean-franco said:
                                          Thanks.
                                          [attachment=0:3wnzrn5t]<!-- ia0 -->cerificateur-scenes.skp<!-- ia0 -->[/attachment:3wnzrn5t]
                                          is there no one ho has a solution for this problem 😢 . this can make this plugin very useful 😄
                                            driven
                                            hi dannyver,
                                            I don't use SU 6 and I'm on a mac so it's hard to know what issues your having.
                                            maybe you could re-cast your question to target your setup better.
                                            e.g. "I've tried this plugin using SU6 on this skp and it doesn't seem to function, can someone check if it's my skp?
                                            or "can someone post a skp that works with this plugin in SU6 so I can check my setup..."
                                            With the first example you'll likely find out if your skp works or with the second you'll eliminate a wrongly setup skp...
                                            sorry I can't be of more help. Personally I know it 'basically' works on mac using SU8, but I only tested the functionality for future use.
                                            other than that I suggest checking you've got the latest version, and re-read any instructions or posts.
                                            also, if you no longer use SU6 update your User Settings.
