    How to make this?
    24 Posts 9 Posters 2.8k Views 9 Watching
    • C
      cupko
      Hi to all,
      I want to make door handle and bed cloth. I have TIG's Extrude Tools, but i don't know how to do this? Pictures/workflow would be great.
      One more question: Is there any plugin that can add thickness to curved surface like bed cloth?
      http://i.i.imgur.com/wwtqx.jpg
      http://i.imgur.com/WzaTS.jpg
      • thomthomT
        Fredo's Tools on Surface. But do you really need/want thickness to the cloth? It'll add a lot of geometry - will it actually be noticed in any view?
        • D
          d12dozr
          Thomthom, you mean Joint Push Pull, right?
          http://goo.gl/f7ooYh
          • W
            wyatt
            There was a tutorial in the Organic Modeling subforum about modeling a bedspread with Artisan very recently.
              Here the video of the bed with Artisan by EarthMover πŸ˜‰
              • W
                wyatt
                Yep, that was it.
                • C
                  cupko
                  Bedspread problem solved, thanks πŸ‘ .
                  @thomthom: I think that is nice to have some thickness on the edges, but it's not must have πŸ˜„.
                  One solved...one to go.
                  • C
                    cupko
                    Here's results. Texturing is done with projected material. Not bad I think? Base for sampling is rounded box (pic #4).
                    How to map shapes like this?
                    #2
                    #3
                    #4
                    • G
                      gulcanocali
                      Hi cupko,
                      You can use Tgi3D SU Amorph's cross section tool to draw the handle quickly. The good news is cross section tool is available and unrestricted in the Free Training Edition of Tgi3D SU Amorph πŸ˜„
                      Below is a quick video to show how. I drew the initial shape with Follow Me and then used Tgi3D SU AMorph's cross section tool to re-shape it to the desired form.
                      [flash=600,480:15hmun5f]http://www.youtube.com/v/R_5uO99_kRU?fs=1&hl=en_US[/flash:15hmun5f]
                      Gulcan Ocali
                      Product Manager
                      http://www.Tgi3D.com
                      • C
                        cupko
                        Hi Gulcan,
                        That looks quite easy, I'll try it, thanks πŸ˜„ .
                        • C
                          cupko
                          Excellent tool for objects like this. You'll see some geometry distortion because I rotated few cross-sections πŸ˜’.
                          Sketchup is became very powerfull software 😍.
                          • G
                            gulcanocali
                            Glad you liked it. Cross-section tool is one of the most favorite among the many features of Tgi3D SU Amorph.
                            Nice renders. And your model looks way better than mine too πŸ˜„
                            Gulcan Ocali
                            Product Manager
                            • C
                              cupko
                              Heh, but you did it in 1 min. πŸ˜„.
                              Thanks again.
                              • G
                                gulcanocali
                                Oops, I forgot to mention that the video was sped up. 😳 It was more like 4+ mins. I sped up the video so that people would not get bored. That is how slow I model πŸ˜’
                                Gulcan Ocali
                                Product Manager
                                • GaieusG
                                  @gulcanocali said:
                                  ...It was more like 4+ mins... That is how slow I model πŸ˜’
                                  Still very impressive. I have had this tool for a while but still exploring and am amazed what one can do with it. πŸ‘
                                  • C
                                    cupko
                                    Ok, new challenge πŸ˜„.
                                    Is there any plugin which works like ChamferAlongPath, but to preserve original edges (I don't need bevel). I just want to add some geometry which will be parallel with original edges from both sides.
                                    • TIGT
                                      Try the native Offset tool - perhaps with some Move used on specific vertices/edges if required... πŸ˜•
                                      • C
                                        cupko
                                        Native Offset requires selected face. I have something like in attach, but much more complex.
                                        • TIGT
                                          Perhaps my ExtendEdgesByOffset ?
                                          Part of the Extrusion Tools zipped set - search for it...
                                          Although it only works on any set of coplanar edges... πŸ˜•
                                          • C
                                            cupko
                                            As you said, edges must be coplanar. One more thing, angles between faces aren't exactly 90Β°.
                                            TIG, can we expect some plugin maybe? πŸ˜„
                                            • 1 / 2
