    How to make this?
    24 Posts 9 Posters 2.5k Views 9 Watching
      d12dozr
      Thomthom, you mean Joint Push Pull, right?
      http://goo.gl/f7ooYh
      • W
        wyatt
        There was a tutorial in the Organic Modeling subforum about modeling a bedspread with Artisan very recently.
          Here the video of the bed with Artisan by EarthMover πŸ˜‰
          • W
            wyatt
            Yep, that was it.
            • C
              cupko
              Bedspread problem solved, thanks πŸ‘ .
              @thomthom: I think that is nice to have some thickness on the edges, but it's not must have πŸ˜„.
              One solved...one to go.
              • C
                cupko
                Here's results. Texturing is done with projected material. Not bad I think? Base for sampling is rounded box (pic #4).
                How to map shapes like this?
                #2
                #3
                #4
                • G
                  gulcanocali
                  Hi cupko,
                  You can use Tgi3D SU Amorph's cross section tool to draw the handle quickly. The good news is cross section tool is available and unrestricted in the Free Training Edition of Tgi3D SU Amorph πŸ˜„
                  Below is a quick video to show how. I drew the initial shape with Follow Me and then used Tgi3D SU AMorph's cross section tool to re-shape it to the desired form.
                  [flash=600,480:15hmun5f]http://www.youtube.com/v/R_5uO99_kRU?fs=1&hl=en_US[/flash:15hmun5f]
                  Gulcan Ocali
                  Product Manager
                  http://www.Tgi3D.com
                  • C
                    cupko
                    Hi Gulcan,
                    That looks quite easy, I'll try it, thanks πŸ˜„ .
                    • C
                      cupko
                      Excellent tool for objects like this. You'll see some geometry distortion because I rotated few cross-sections πŸ˜’.
                      Sketchup is became very powerfull software 😍.
                      • G
                        gulcanocali
                        Glad you liked it. Cross-section tool is one of the most favorite among the many features of Tgi3D SU Amorph.
                        Nice renders. And your model looks way better than mine too πŸ˜„
                        Gulcan Ocali
                        Product Manager
                        • C
                          cupko
                          Heh, but you did it in 1 min. πŸ˜„.
                          Thanks again.
                          • G
                            gulcanocali
                            Oops, I forgot to mention that the video was sped up. 😳 It was more like 4+ mins. I sped up the video so that people would not get bored. That is how slow I model πŸ˜’
                            Gulcan Ocali
                            Product Manager
                            • GaieusG
                              @gulcanocali said:
                              ...It was more like 4+ mins... That is how slow I model πŸ˜’
                              Still very impressive. I have had this tool for a while but still exploring and am amazed what one can do with it. πŸ‘
                              • C
                                cupko
                                Ok, new challenge πŸ˜„.
                                Is there any plugin which works like ChamferAlongPath, but to preserve original edges (I don't need bevel). I just want to add some geometry which will be parallel with original edges from both sides.
                                  Try the native Offset tool - perhaps with some Move used on specific vertices/edges if required... πŸ˜•
                                  • C
                                    cupko
                                    Native Offset requires selected face. I have something like in attach, but much more complex.
                                      Perhaps my ExtendEdgesByOffset ?
                                      Part of the Extrusion Tools zipped set - search for it...
                                      Although it only works on any set of coplanar edges... πŸ˜•
                                      • C
                                        cupko
                                        As you said, edges must be coplanar. One more thing, angles between faces aren't exactly 90Β°.
                                        TIG, can we expect some plugin maybe? πŸ˜„
                                          EEbyOffset will accommodate non-right-angle corners BUT all edges must be coplanar for it to work...
                                          A relatively easy way is using the native Offset tool on each face [double-click to repeat last use offset dim], with some subsequent Move tool use on edges/vertices IF the offset isn't needed to be 'all round'...Capture.PNG
                                          • C
                                            cupko
                                            I should emphases that geometry is complex. I am practicing making a car from blueprint and there's a lot of triangles.
                                            Easiest way to do this would be to select edges and then chamfer. This is not the only place where I need to do this 😞 .
