    Show Me Your SketchUp
    114 Posts 74 Posters 60.7k Views 74 Watching
      Builder Boy
      All my plugins
      • soloS Offline
        solo
        Michael, you have many toolbars I have never seen before. 😲
        http://www.solos-art.com
          Slimdog
          Its interesting to see how many people have the standard large tool set docked in the same place. I am kinda shocked to see the layers pallet closed on most peoples. I have entity info and layers open all the time.
          • EarthMoverE Offline
            EarthMover
            Here's mine. I try to organize toolbars by groupings. Drawing plugins together, mesh manipulation plugins together, render plugins together, etc. Since they tend to get scrambled so often, it's easier to remember the layout.
            Content Creator at Skapeup
            • Chris FullmerC Offline
              ok, here is mine. I use 2 monitorsat work. I keep all floating windows on my 2nd monitor.
              Like Gaieus I also use Sizer to get exact proportions to my SU window because I need to match image exports fairly often. My toolbars change a lot. I turn them on and off all the time. I uninstall plugins very often by moving them out of the plugins folder. Then put them back later when I need them again. I use my SU UI very dynamically, it would be awesome if it was built to be more flexible naturally instead of having to sort of run the show manually.
              Thanks for starting this thread John,
              Chris
              All my Plugins I've written
                oh yeah, and my current plugins I have installed.
                • cj_sniperC Offline
                  cj_sniper
                  here is mine...
                  http://i1118.photobucket.com/albums/k606/cj_sniper/Untitled-1-2.jpg
                  http://sketchup.google.com/3dwarehouse/search?viewer=0795900671129884296711450&scoring=m
                  I'm not a magician, I just learn
                  • MarianM Offline
                    Marian
                    My setup
                      @chris fullmer said:
                      ...My toolbars change a lot. I turn them on and off all the time. I uninstall plugins very often by moving them out of the plugins folder. Then put them back later when I need them again. I use my SU UI very dynamically, it would be awesome if it was built to be more flexible naturally instead of having to sort of run the show manually...
                      Ditto. I have many disabled toolbars and even disabled plugins which I use less frequently. Despite the very important and useful improvements with toolbar restore and such, I would also love to see some further development here.
                        ArCAD-UK
                        I love the simplicity of the SU toolset and like to focus on getting the best out it by not having a cluttered workspace. Had that on previous softs. I also run very few plugins...
                          Builder Boy
                          I made some of them myself 😉
                          All my plugins
                          • urgenU Offline
                            urgen
                            ............su5
                            .............su7
                            --pupil forever...------
                            • P Offline
                              Phil Rader AIA
                              KISS....Keep it simple Silly....I can't stand more than one row of Icons. I rarely have the floating dialog items up unless I need them. And then as soon as I no longer need them they get closed. I'm all about screen real estate and I want the work area to be the biggest possible area.
                              Screen Resolution 1920x1200
                              GUI
                              http://www.philrader.com
                                mozzie
                                I'm not an intensive user - a lot of terrain work, and measuring. Some point cloud and DXF/DWG import export for survey details, and some rendering. I use specifiic plugins (Put on Layer, Pipe along path, co-ords tag, points cloud) extensively.<p>
                                Screen shot and Plugins folder below.
                                  leminilab
                                  I know it must be redundant but is there a solution to save the settings of the menu bar? 😕
                                  • "Live every day as if it were your last and then some day you'll be right."
                                  • "ThomThom rules!!!"
                                    @leminilab said:
                                    Do you mean the toolbar positions? Yes, there is in version 8.
                                    • RonSR Offline
                                      RonS
                                      Here is mine.
                                      Design is not just what it looks like and feels like. Design is how it works.
                                      Steve Jobs
                                      RonS
                                      • halroachH Offline
                                        halroach
                                        I have dual screen setup at work.
                                        1. I put all the toolbars as crammed up as possible - trying to maintain their positions so I remember where everything is.
                                        2. the different windows I let float around on the second screen, because when they stick together, things get lost outside of the screen.
                                        3. I've got just about every key on the keyboard mapped to a function or plugin... If I've got something mapped I try to keep it's toolbar off.
                                        (I've got an idea for a separate thread for everybody's keyboard shortcuts, if that interests anyone)
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                        • Alan FraserA Offline
                                          Alan Fraser
                                          ... and mine.
                                          I really don't like to have the bars more than 2 icons wide/deep; I'd rather find them on the menus than take up any more real estate; and frankly, icons are harder to find the more rows and columns you have...and all those slight delays add up. However, the 3 palettes are open all the time. It would be nice if you could crush the Materials a little smaller, but there seems to be a limit beyond which it won't shrink any further.
                                          3D Figures
                                            bjornkn
                                            And here's mine - single screen.
                                            It has never been so crowded before, because I have used very few plugins in the past. Now I'm trying out a lot of them, and probably I'll remove those that I don't use. And I'll probably move that right side single bar to the left side and make it a 3-col? I use shortcuts for everything, including show/hide dialogs/panels, so it's quick to get a clean screen.
                                            • 6
                                            • 2 / 6
