    Show Me Your SketchUp
    114 Posts 74 Posters 67.3k Views 74 Watching
      Hoppefully I have a new monitor after some time with a 15" πŸ’š
      order of the tool bar is never the same due excentricity of the every start of SU! πŸ˜‰
        • KrisidiousK
          Krisidious
          I'm not allowed to post my desktop... the image is too wide for the forums. so here's a link.
          http://www.aboveallhouseplans.com/Capture.JPG
          http://www.aboveallhouseplans.com/Capture2.JPG
          and while we're discussing it, can you do something about the 4th wall above sketchup in monitor layouts? none of the toolbars or windows will go above sketchup into another monitor, only to the sides.
          By: Kristoff Rand
          • daleD
            dale
            Mine on this project...
            • B
              Builder Boy
              All my plugins
              • soloS
                Michael, you have many toolbars I have never seen before. 😲
                  Slimdog
                  Its interesting to see how many people have the standard large tool set docked in the same place. I am kinda shocked to see the layers pallet closed on most peoples. I have entity info and layers open all the time.
                  • EarthMoverE
                    EarthMover
                    Here's mine. I try to organize toolbars by groupings. Drawing plugins together, mesh manipulation plugins together, render plugins together, etc. Since they tend to get scrambled so often, it's easier to remember the layout.
                    Content Creator at Skapeup
                    • Chris FullmerC
                      ok, here is mine. I use 2 monitorsat work. I keep all floating windows on my 2nd monitor.
                      Like Gaieus I also use Sizer to get exact proportions to my SU window because I need to match image exports fairly often. My toolbars change a lot. I turn them on and off all the time. I uninstall plugins very often by moving them out of the plugins folder. Then put them back later when I need them again. I use my SU UI very dynamically, it would be awesome if it was built to be more flexible naturally instead of having to sort of run the show manually.
                      Thanks for starting this thread John,
                      • Chris FullmerC
                        oh yeah, and my current plugins I have installed.
                        • cj_sniperC
                          cj_sniper
                          here is mine...
                          http://i1118.photobucket.com/albums/k606/cj_sniper/Untitled-1-2.jpg
                          http://sketchup.google.com/3dwarehouse/search?viewer=0795900671129884296711450&scoring=m
                          I'm not a magician, I just learn
                          • MarianM
                            Marian
                            My setup
                            • GaieusG
                              @chris fullmer said:
                              ...My toolbars change a lot. I turn them on and off all the time. I uninstall plugins very often by moving them out of the plugins folder. Then put them back later when I need them again. I use my SU UI very dynamically, it would be awesome if it was built to be more flexible naturally instead of having to sort of run the show manually...
                              Ditto. I have many disabled toolbars and even disabled plugins which I use less frequently. Despite the very important and useful improvements with toolbar restore and such, I would also love to see some further development here.
                                ArCAD-UK
                                I love the simplicity of the SU toolset and like to focus on getting the best out it by not having a cluttered workspace. Had that on previous softs. I also run very few plugins...
                                • B
                                  Builder Boy
                                  I made some of them myself πŸ˜‰
                                  All my plugins
                                  • urgenU
                                    urgen
                                    ............su5
                                    .............su7
                                    --pupil forever...------
                                    • P
                                      Phil Rader AIA
                                      KISS....Keep it simple Silly....I can't stand more than one row of Icons. I rarely have the floating dialog items up unless I need them. And then as soon as I no longer need them they get closed. I'm all about screen real estate and I want the work area to be the biggest possible area.
                                      Screen Resolution 1920x1200
                                      GUI
                                      http://www.philrader.com
                                        mozzie
                                        I'm not an intensive user - a lot of terrain work, and measuring. Some point cloud and DXF/DWG import export for survey details, and some rendering. I use specifiic plugins (Put on Layer, Pipe along path, co-ords tag, points cloud) extensively.<p>
                                        Screen shot and Plugins folder below.
                                        • L
                                          leminilab
                                          I know it must be redundant but is there a solution to save the settings of the menu bar? πŸ˜•
                                          • "Live every day as if it were your last and then some day you'll be right."
                                          • "ThomThom rules!!!"
                                            @leminilab said:
                                            Do you mean the toolbar positions? Yes, there is in version 8.
                                            • 2 / 6
