    Show Me Your SketchUp
    114 Posts 74 Posters 60.9k Views 74 Watching
    • KrisidiousK Offline
      Krisidious
      I'm not allowed to post my desktop... the image is too wide for the forums. so here's a link.
      (www.aboveallhouseplans.com)
      and while we're discussing it, can you do something about the 4th wall above sketchup in monitor layouts? none of the toolbars or windows will go above sketchup into another monitor, only to the sides.
      By: Kristoff Rand
      • daleD Offline
        dale
        Mine on this project...
          Builder Boy
          All my plugins
          • soloS Offline
            Michael, you have many toolbars I have never seen before. 😲
              Slimdog
              Its interesting to see how many people have the standard large tool set docked in the same place. I am kinda shocked to see the layers pallet closed on most peoples. I have entity info and layers open all the time.
              • EarthMoverE Offline
                EarthMover
                Here's mine. I try to organize toolbars by groupings. Drawing plugins together, mesh manipulation plugins together, render plugins together, etc. Since they tend to get scrambled so often, it's easier to remember the layout.
                Content Creator at Skapeup
                • Chris FullmerC Offline
                  ok, here is mine. I use 2 monitorsat work. I keep all floating windows on my 2nd monitor.
                  Like Gaieus I also use Sizer to get exact proportions to my SU window because I need to match image exports fairly often. My toolbars change a lot. I turn them on and off all the time. I uninstall plugins very often by moving them out of the plugins folder. Then put them back later when I need them again. I use my SU UI very dynamically, it would be awesome if it was built to be more flexible naturally instead of having to sort of run the show manually.
                  Thanks for starting this thread John,
                    oh yeah, and my current plugins I have installed.
                    • cj_sniperC Offline
                      cj_sniper
                      here is mine...
                      http://i1118.photobucket.com/albums/k606/cj_sniper/Untitled-1-2.jpg
                      http://sketchup.google.com/3dwarehouse/search?viewer=0795900671129884296711450&scoring=m
                      I'm not a magician, I just learn
                      • MarianM Offline
                        Marian
                        My setup
                          @chris fullmer said:
                          ...My toolbars change a lot. I turn them on and off all the time. I uninstall plugins very often by moving them out of the plugins folder. Then put them back later when I need them again. I use my SU UI very dynamically, it would be awesome if it was built to be more flexible naturally instead of having to sort of run the show manually...
                          Ditto. I have many disabled toolbars and even disabled plugins which I use less frequently. Despite the very important and useful improvements with toolbar restore and such, I would also love to see some further development here.
                            ArCAD-UK
                            I love the simplicity of the SU toolset and like to focus on getting the best out it by not having a cluttered workspace. Had that on previous softs. I also run very few plugins...
                              Builder Boy
                              I made some of them myself 😉
                              All my plugins
                              • urgenU Offline
                                urgen
                                ............su5
                                .............su7
                                --pupil forever...------
                                  Phil Rader AIA
                                  KISS....Keep it simple Silly....I can't stand more than one row of Icons. I rarely have the floating dialog items up unless I need them. And then as soon as I no longer need them they get closed. I'm all about screen real estate and I want the work area to be the biggest possible area.
                                  Screen Resolution 1920x1200
                                  GUI
                                  http://www.philrader.com
                                    mozzie
                                    I'm not an intensive user - a lot of terrain work, and measuring. Some point cloud and DXF/DWG import export for survey details, and some rendering. I use specifiic plugins (Put on Layer, Pipe along path, co-ords tag, points cloud) extensively.<p>
                                    Screen shot and Plugins folder below.
                                      leminilab
                                      I know it must be redundant but is there a solution to save the settings of the menu bar? 😕
                                      • "Live every day as if it were your last and then some day you'll be right."
                                      • "ThomThom rules!!!"
                                        @leminilab said:
                                        Do you mean the toolbar positions? Yes, there is in version 8.
                                        • RonSR Offline
                                          RonS
                                          Here is mine.
                                          Design is not just what it looks like and feels like. Design is how it works.
                                          Steve Jobs
                                          RonS
                                          • halroachH Offline
                                            halroach
                                            I have dual screen setup at work.
                                            1. I put all the toolbars as crammed up as possible - trying to maintain their positions so I remember where everything is.
                                            2. the different windows I let float around on the second screen, because when they stick together, things get lost outside of the screen.
                                            3. I've got just about every key on the keyboard mapped to a function or plugin... If I've got something mapped I try to keep it's toolbar off.
                                            (I've got an idea for a separate thread for everybody's keyboard shortcuts, if that interests anyone)
                                            FlexTools - Super Quick Windows, Doors, Slats...
                                            • 2 / 6
