    How would you model this?
    47 Posts 19 Posters 6.0k Views 19 Watching
    • utilerU Offline
      utiler
      Hi guys, I've toyed with the idea of someday when i get a freetime I'd build a library of models I use commonly on projects. I thought I'd start with a slophopper, simple cleaner sink.
      But do you think I can get it to look anything like the acual DWG files I was sent? πŸ˜•
      Can anyone be so kind as to give me a kick along. I've started using Fredo's Curviloft tools but not really sure if it is the best way to go....
      slophopper.skp
      Just Curious...
        mac1
        Check this link http://forums.sketchucation.com/viewtopic.php?f=179&t=36049&p=317412#p317412
        • utilerU Offline
          utiler
          thanks mac1, I was hoping to stick with SU rather than use another program.....
          Just Curious...
          • KrisidiousK Offline
            Krisidious
            I don't think he's pointing to the other program, more so pointing to Tig's answer of using Boolean Tools.
            I would suggest section modeling but I'm not one to give advice on organic modeling.
            By: Kristoff Rand
            • H Offline
              Howard leslie
              Andrew,
              See attached.
              Should get you started.
              Extrude your CAD sections and use Bool Tools or new SU8 Solid Tools.
              Use Intesect or Difference Tool
              Hope this Helps
              Howard L'
              slophopper2.skp
                Don Burns
                Push profiles, 2 at a time. Use Intersect Faces. Get rid of parts you do not want.
                Good luck.
                  Those drawings are missing an element in the design...i think?
                  The transition from the bowl to the back. I'd imagine it would curve inwards? Have you a real photo?
                    Booman
                    Its hard to tell you all the steps to modeling a sink, but honestly, I found that you can model anything with Sketchup.
                    Even an animal or person.
                    I would suggest doing one piece at a time.
                    Try the "revolve" tool and the "follow-me" tool to create organic shapes.
                    I usually create a geometric shape first and then use the "M" tool and "S" tool to tweak it into an organic one.
                    Also, sandbox has a lot of capabilities to create organic meshes. Its harder to use, but I created a Grotto (Pool cave with waterfall/slide) with the sandbox tools and it came out pretty good.
                    Takes a lot of patience but once you learn all the advanced capabilities of Sketchup... anything is possible
                    Brian McCracken
                    In The Red Website Design
                    • utilerU Offline
                      utiler
                      Thanks to you all taking the time and chiming in. πŸ‘
                      Kris - I see what you mean... sorry for the misunderstanding, mac1! πŸ‘
                      Don & Howard - Both methods were how I tried at first however the look is not the same.... [see attached photo image] you'll see that the underside of the rim is moulded consistent with the top rather than squared. I was thinking it may be an ExtrudeBy____ process or curviloft.
                      What do you think?
                      πŸ˜‰
                      Just Curious...
                      • utilerU Offline
                        utiler
                        you read my mind, Rich! see above... πŸ‘
                        Just Curious...
                          Here's the start.....
                          Andrew_Shitter.skp
                            Rich
                            It's a sluice for washing away 'dirty stuff' - NOT for 'number twos' directly produced over it... 😲
                            BUT the principle of its modeling remains the same........
                              Don't invite me round for a party then
                              • utilerU Offline
                                utiler
                                That's pretty close, Rich! πŸ‘ so what did you do to get it?
                                And yes TIG's right; that stainless steel rack on it's lid might make for an iteresting experience.... πŸ˜†
                                Just Curious...
                                • utilerU Offline
                                  utiler
                                  Here's a play.
                                  When you look closely the profiles of front to side are not the same as well as the side walls deminish as it moves to the back. I tried EEByRails but the bottom curve is a questions which you'll see in the plan view....
                                  I just copied the CAD lines so segments are high and hence many facets so I would need to cut them down. How would I do that considering the welded profile may be made up of differing lines lengths?
                                  πŸ‘
                                  RichsFridayNightPillow.skp
                                  Just Curious...
                                    Booman
                                    Very nice, looking good
                                    Brian McCracken
                                    • chippwaltersC Offline
                                      chippwalters
                                      Late to this party, but I'd use Artisan and these video tutes:
                                      http://forums.sketchucation.com/viewtopic.php?f=335&t=35730
                                      Currently working with Cross-Reality technologies
                                      • boofredlayB Offline
                                        boofredlay
                                        @tig said:
                                        Rich
                                        Andrew, sorry I did not see this earlier.
                                        There are obviously many different ways to go about it, here is my starting stab...
                                        (I find it useful to use Subdivide & Smooth to create a profile that will later be Subdivided & Smoothed, wait, what? πŸ˜† )
                                        [flash=853,505:5722dj61]http://www.youtube.com/v/C3g_oktqBiY&fs=1[/flash:5722dj61]
                                          Krisidious
                                          nice Boo...
                                          By: Kristoff Rand
                                          • HumpmetwiceH Offline
                                            Humpmetwice
                                            Some people here make things seem so easy!
                                            • 1 / 3
