    How would you model this?
    47 Posts 19 Posters 6.1k Views 19 Watching
      Those drawings are missing an element in the design...i think?
      The transition from the bowl to the back. I'd imagine it would curve inwards? Have you a real photo?
        Booman
        Its hard to tell you all the steps to modeling a sink, but honestly, I found that you can model anything with Sketchup.
        Even an animal or person.
        I would suggest doing one piece at a time.
        Try the "revolve" tool and the "follow-me" tool to create organic shapes.
        I usually create a geometric shape first and then use the "M" tool and "S" tool to tweak it into an organic one.
        Also, sandbox has a lot of capabilities to create organic meshes. Its harder to use, but I created a Grotto (Pool cave with waterfall/slide) with the sandbox tools and it came out pretty good.
        Takes a lot of patience but once you learn all the advanced capabilities of Sketchup... anything is possible
        Brian McCracken
        In The Red Website Design
        • utilerU Offline
          utiler
          Thanks to you all taking the time and chiming in. πŸ‘
          Kris - I see what you mean... sorry for the misunderstanding, mac1! πŸ‘
          Don & Howard - Both methods were how I tried at first however the look is not the same.... [see attached photo image] you'll see that the underside of the rim is moulded consistent with the top rather than squared. I was thinking it may be an ExtrudeBy____ process or curviloft.
          What do you think?
          πŸ˜‰
          Just Curious...
          • utilerU Offline
            utiler
            you read my mind, Rich! see above... πŸ‘
            Just Curious...
              Here's the start.....
              Andrew_Shitter.skp
                Rich
                It's a sluice for washing away 'dirty stuff' - NOT for 'number twos' directly produced over it... 😲
                BUT the principle of its modeling remains the same........
                  Don't invite me round for a party then
                  • utilerU Offline
                    utiler
                    That's pretty close, Rich! πŸ‘ so what did you do to get it?
                    And yes TIG's right; that stainless steel rack on it's lid might make for an iteresting experience.... πŸ˜†
                    Just Curious...
                    • utilerU Offline
                      utiler
                      Here's a play.
                      When you look closely the profiles of front to side are not the same as well as the side walls deminish as it moves to the back. I tried EEByRails but the bottom curve is a questions which you'll see in the plan view....
                      I just copied the CAD lines so segments are high and hence many facets so I would need to cut them down. How would I do that considering the welded profile may be made up of differing lines lengths?
                      πŸ‘
                      RichsFridayNightPillow.skp
                      Just Curious...
                        Booman
                        Very nice, looking good
                        Brian McCracken
                        • chippwaltersC Offline
                          chippwalters
                          Late to this party, but I'd use Artisan and these video tutes:
                          http://forums.sketchucation.com/viewtopic.php?f=335&t=35730
                          Currently working with Cross-Reality technologies
                          • boofredlayB Offline
                            boofredlay
                            @tig said:
                            Rich
                            Andrew, sorry I did not see this earlier.
                            There are obviously many different ways to go about it, here is my starting stab...
                            (I find it useful to use Subdivide & Smooth to create a profile that will later be Subdivided & Smoothed, wait, what? πŸ˜† )
                            [flash=853,505:5722dj61]http://www.youtube.com/v/C3g_oktqBiY&fs=1[/flash:5722dj61]
                            • KrisidiousK Offline
                              Krisidious
                              nice Boo...
                              By: Kristoff Rand
                              • HumpmetwiceH Offline
                                Humpmetwice
                                Some people here make things seem so easy!
                                • mitcorbM Offline
                                  mitcorb
                                  It's a damned lavatory with an identity problem. A sink with delusions of grandeur. An egotripping spitoon
                                  A bidet down on its luck
                                    chippwalters
                                    Here's a quick version I created in about 30 minutes with Artisan using a more traditional box modeling technique which has just about all the detail. I captured the video and it's posting to YouTube now-- I'll put a link here when it's done.
                                    A real advantage of box modeling is you can go back in easily and tweak proportions and add detail as you go.
                                    Here's the skp file:
                                    http://www.widgetgadget.com/stuff/slophopper.skp
                                    http://www.widgetgadget.com/stuff/untitled.74.jpg
                                    http://www.widgetgadget.com/stuff/slophopper1.jpg
                                    http://www.widgetgadget.com/stuff/slophopper2.jpg
                                    http://www.widgetgadget.com/stuff/slophopper3.jpg
                                      Ok, here's my video since we're all gone crazy screen recording!
                                      I didn't see Chipp's until I replied. Nice proxy and tutorial
                                      [flash=800,600:38lsvifv]http://www.youtube.com/v/YwQF1H7ldq0[/flash:38lsvifv]
                                        chippwalters
                                        We're certainly showing more than one way to skin a cat! Nice videos everyone. πŸ˜„
                                        Rich, how are you able to embed a YouTube vid? Is it something only moderators can do?
                                          here' the link....
                                          [flash=800,600]http://www.youtube.com/v=YwQF1H7ldq0[/flash]
                                          Use the flash button
                                          Insert dimensions of video after '='
                                          Paste link
                                          delete 'watch?' and the '=' after 'v'
                                          So you get /v/YwQF1H7ldq0
                                          Does that even make sense?
                                          I know Jim has a tool here somewhere that automatically does this? Anyone?
                                            chippwalters
                                            Here's the YouTube Vid:
                                            [flash=800,600:3lnspuma]http://www.youtube.com/v/HrjWHZw__3g[/flash:3lnspuma]
                                            And if you wait a couple hours, YouTube will automatically convert to 720p so you can see it at hi-rez! Pretty cool πŸ˜„
                                            • 1 / 3
