    How would you model this?
    47 Posts 19 Posters 9.1k Views 19 Watching
    • B
      Booman
      Its hard to tell you all the steps to modeling a sink, but honestly, I found that you can model anything with Sketchup.
      Even an animal or person.
      I would suggest doing one piece at a time.
      Try the "revolve" tool and the "follow-me" tool to create organic shapes.
      I usually create a geometric shape first and then use the "M" tool and "S" tool to tweak it into an organic one.
      Also, sandbox has a lot of capabilities to create organic meshes. Its harder to use, but I created a Grotto (Pool cave with waterfall/slide) with the sandbox tools and it came out pretty good.
      Takes a lot of patience but once you learn all the advanced capabilities of Sketchup... anything is possible
      Brian McCracken
      In The Red Website Design
      • utilerU
        utiler
        Thanks to you all taking the time and chiming in. πŸ‘
        Kris - I see what you mean... sorry for the misunderstanding, mac1! πŸ‘
        Don & Howard - Both methods were how I tried at first however the look is not the same.... [see attached photo image] you'll see that the underside of the rim is moulded consistent with the top rather than squared. I was thinking it may be an ExtrudeBy____ process or curviloft.
        What do you think?
        πŸ˜‰
        Just Curious...
        • utilerU
          utiler
          Those drawings are missing an element in the design...i think?
          The transition from the bowl to the back. I'd imagine it would curve inwards? Have you a real photo?
          you read my mind, Rich! see above... πŸ‘
          Just Curious...
            Here's the start.....
            Andrew_Shitter.skp
              Rich
              It's a sluice for washing away 'dirty stuff' - NOT for 'number twos' directly produced over it... 😲
              BUT the principle of its modeling remains the same........
                Don't invite me round for a party then
                • utilerU
                  utiler
                  That's pretty close, Rich! πŸ‘ so what did you do to get it?
                  And yes TIG's right; that stainless steel rack on it's lid might make for an iteresting experience.... πŸ˜†
                  Just Curious...
                  • utilerU
                    utiler
                    Here's a play.
                    When you look closely the profiles of front to side are not the same as well as the side walls deminish as it moves to the back. I tried EEByRails but the bottom curve is a questions which you'll see in the plan view....
                    I just copied the CAD lines so segments are high and hence many facets so I would need to cut them down. How would I do that considering the welded profile may be made up of differing lines lengths?
                    πŸ‘
                    RichsFridayNightPillow.skp
                    Just Curious...
                    • B
                      Booman
                      Very nice, looking good
                      Brian McCracken
                      • chippwaltersC
                        chippwalters
                        Late to this party, but I'd use Artisan and these video tutes:
                        http://forums.sketchucation.com/viewtopic.php?f=335&t=35730
                        Currently working with Cross-Reality technologies
                        • boofredlayB
                          boofredlay
                          @tig said:
                          Rich
                          Andrew, sorry I did not see this earlier.
                          There are obviously many different ways to go about it, here is my starting stab...
                          (I find it useful to use Subdivide & Smooth to create a profile that will later be Subdivided & Smoothed, wait, what? πŸ˜† )
                          [flash=853,505:5722dj61]http://www.youtube.com/v/C3g_oktqBiY&fs=1[/flash:5722dj61]
                          • KrisidiousK
                            Krisidious
                            nice Boo...
                            By: Kristoff Rand
                            • HumpmetwiceH
                              Humpmetwice
                              Some people here make things seem so easy!
                              • mitcorbM
                                mitcorb
                                It's a damned lavatory with an identity problem. A sink with delusions of grandeur. An egotripping spitoon
                                A bidet down on its luck
                                • chippwaltersC
                                  chippwalters
                                  Here's a quick version I created in about 30 minutes with Artisan using a more traditional box modeling technique which has just about all the detail. I captured the video and it's posting to YouTube now-- I'll put a link here when it's done.
                                  A real advantage of box modeling is you can go back in easily and tweak proportions and add detail as you go.
                                  Here's the skp file:
                                  http://www.widgetgadget.com/stuff/slophopper.skp
                                  http://www.widgetgadget.com/stuff/untitled.74.jpg
                                  http://www.widgetgadget.com/stuff/slophopper1.jpg
                                  http://www.widgetgadget.com/stuff/slophopper2.jpg
                                  http://www.widgetgadget.com/stuff/slophopper3.jpg
                                    Ok, here's my video since we're all gone crazy screen recording!
                                    I didn't see Chipp's until I replied. Nice proxy and tutorial
                                    [flash=800,600:38lsvifv]http://www.youtube.com/v/YwQF1H7ldq0[/flash:38lsvifv]
                                    • chippwaltersC
                                      chippwalters
                                      We're certainly showing more than one way to skin a cat! Nice videos everyone. πŸ˜„
                                      Rich, how are you able to embed a YouTube vid? Is it something only moderators can do?
                                        here' the link....
                                        [flash=800,600]http://www.youtube.com/v=YwQF1H7ldq0[/flash]
                                        Use the flash button
                                        Insert dimensions of video after '='
                                        Paste link
                                        delete 'watch?' and the '=' after 'v'
                                        So you get /v/YwQF1H7ldq0
                                        Does that even make sense?
                                        I know Jim has a tool here somewhere that automatically does this? Anyone?
                                        • chippwaltersC
                                          chippwalters
                                          Here's the YouTube Vid:
                                          [flash=800,600:3lnspuma]http://www.youtube.com/v/HrjWHZw__3g[/flash:3lnspuma]
                                          And if you wait a couple hours, YouTube will automatically convert to 720p so you can see it at hi-rez! Pretty cool πŸ˜„
                                          • chippwaltersC
                                            chippwalters
                                            Thanks a bunch, Rich. Works like a charm!
                                            • 1 / 3
