    How would you model this?
    47 Posts 19 Posters 8.3k Views 19 Watching
    • KrisidiousK
      Krisidious
      I don't think he's pointing to the other program, more so pointing to Tig's answer of using Boolean Tools.
      I would suggest section modeling but I'm not one to give advice on organic modeling.
      By: Kristoff Rand
      • H
        Howard leslie
        Andrew,
        See attached.
        Should get you started.
        Extrude your CAD sections and use Bool Tools or new SU8 Solid Tools.
        Use Intesect or Difference Tool
        Hope this Helps
        Howard L'
        slophopper2.skp
          Don Burns
          Push profiles, 2 at a time. Use Intersect Faces. Get rid of parts you do not want.
          Good luck.
            Those drawings are missing an element in the design...i think?
            The transition from the bowl to the back. I'd imagine it would curve inwards? Have you a real photo?
            • B
              Booman
              Its hard to tell you all the steps to modeling a sink, but honestly, I found that you can model anything with Sketchup.
              Even an animal or person.
              I would suggest doing one piece at a time.
              Try the "revolve" tool and the "follow-me" tool to create organic shapes.
              I usually create a geometric shape first and then use the "M" tool and "S" tool to tweak it into an organic one.
              Also, sandbox has a lot of capabilities to create organic meshes. Its harder to use, but I created a Grotto (Pool cave with waterfall/slide) with the sandbox tools and it came out pretty good.
              Takes a lot of patience but once you learn all the advanced capabilities of Sketchup... anything is possible
              Brian McCracken
              In The Red Website Design
              • utilerU
                utiler
                Thanks to you all taking the time and chiming in. πŸ‘
                Kris - I see what you mean... sorry for the misunderstanding, mac1! πŸ‘
                Don & Howard - Both methods were how I tried at first however the look is not the same.... [see attached photo image] you'll see that the underside of the rim is moulded consistent with the top rather than squared. I was thinking it may be an ExtrudeBy____ process or curviloft.
                What do you think?
                πŸ˜‰
                Just Curious...
                • utilerU
                  utiler
                  you read my mind, Rich! see above... πŸ‘
                  Just Curious...
                    Here's the start.....
                    Andrew_Shitter.skp
                      Rich
                      It's a sluice for washing away 'dirty stuff' - NOT for 'number twos' directly produced over it... 😲
                      BUT the principle of its modeling remains the same........
                        Don't invite me round for a party then
                        • utilerU
                          utiler
                          That's pretty close, Rich! πŸ‘ so what did you do to get it?
                          And yes TIG's right; that stainless steel rack on it's lid might make for an iteresting experience.... πŸ˜†
                          Just Curious...
                          • utilerU
                            utiler
                            Here's a play.
                            When you look closely the profiles of front to side are not the same as well as the side walls deminish as it moves to the back. I tried EEByRails but the bottom curve is a questions which you'll see in the plan view....
                            I just copied the CAD lines so segments are high and hence many facets so I would need to cut them down. How would I do that considering the welded profile may be made up of differing lines lengths?
                            πŸ‘
                            RichsFridayNightPillow.skp
                            Just Curious...
                            • B
                              Booman
                              Very nice, looking good
                              Brian McCracken
                              • chippwaltersC
                                chippwalters
                                Late to this party, but I'd use Artisan and these video tutes:
                                404 Not Found
                                (forums.sketchucation.com)
                                Currently working with Cross-Reality technologies
                                • boofredlayB
                                  boofredlay
                                  @tig said:
                                  Rich
                                  Andrew, sorry I did not see this earlier.
                                  There are obviously many different ways to go about it, here is my starting stab...
                                  (I find it useful to use Subdivide & Smooth to create a profile that will later be Subdivided & Smoothed, wait, what? πŸ˜† )
                                  [flash=853,505:5722dj61]http://www.youtube.com/v/C3g_oktqBiY&fs=1[/flash:5722dj61]
                                  • KrisidiousK
                                    Krisidious
                                    nice Boo...
                                    By: Kristoff Rand
                                    • HumpmetwiceH
                                      Humpmetwice
                                      Some people here make things seem so easy!
                                      • mitcorbM
                                        mitcorb
                                        It's a damned lavatory with an identity problem. A sink with delusions of grandeur. An egotripping spitoon
                                        A bidet down on its luck
                                        • chippwaltersC
                                          chippwalters
                                          Here's a quick version I created in about 30 minutes with Artisan using a more traditional box modeling technique which has just about all the detail. I captured the video and it's posting to YouTube now-- I'll put a link here when it's done.
                                          A real advantage of box modeling is you can go back in easily and tweak proportions and add detail as you go.
                                          Here's the skp file:
                                          http://www.widgetgadget.com/stuff/slophopper.skp
                                          http://www.widgetgadget.com/stuff/untitled.74.jpg
                                          http://www.widgetgadget.com/stuff/slophopper1.jpg
                                          http://www.widgetgadget.com/stuff/slophopper2.jpg
                                          http://www.widgetgadget.com/stuff/slophopper3.jpg
                                            Ok, here's my video since we're all gone crazy screen recording!
                                            I didn't see Chipp's until I replied. Nice proxy and tutorial
                                            [flash=800,600:38lsvifv]http://www.youtube.com/v/YwQF1H7ldq0[/flash:38lsvifv]
                                            • 1 / 3
