    Cello
    20 Posts 9 Posters 7.4k Views 9 Watching
    • massimoM Offline
      massimo Moderator
      The models are from 3dwarehouse, but were a bit modified, beveled and also added some detail. Completely textured in SU taking textures from a set of a cello's photos and rendered in Thea. Trying out some motion blur+subtle DOF. CRF, vignetting and a very slight glare directly in Thea. Only a little desaturation in post pro. 😄
      • K Offline
        KarinaGM
        Wow! I love it. You are a master
        The most remarcable thing in every render I've seen from you are your textures. You make the objects look so natural!
        Just the bridge (don't know the name) looks rare. Is it ivory?
        **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
        -Benjamín Franklin.**
        • tridemT Offline
          tridem
          👍 Excellent work...as always 😉
          • TIGT Online
            👍 It's getting to the point now when you could post an actual photograph of a cello and it'd be less convincing 😲
            • massimoM Offline
              massimo Moderator
              Thanks everybody, much appreciated. 😄
              Normally the bridge is made with a natural, not varnished maple or platan wood. Here i've used a basswood texture...maybe a bit faint. 😄
              • utilerU Offline
                utiler
                Absolutely incredible, Massimo!!
                Just Curious...
                • massimoM Offline
                  massimo Moderator
                  Thank you Andrew. Cheers. 😄
                  • mitcorbM Offline
                    mitcorb
                    Sweet. I can hear the overtones and harmonics and that bow action is excellent. The bridge almost looks like ivory.
                    • F Offline
                      Fletch
                      Excellent work, as always, Massimo. 😄
                      Fletch
                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                      • massimoM Offline
                        massimo Moderator
                        Glad you like it mitcorb and Fletch. ☀
                        Here you have the entire textured instrument in a SU's screenshot.
                        • K Offline
                          KarinaGM
                          May I ask how did you model the head?
                          Or could we see the wire?
                          I tried to make one but with lame results 😕
                          You gurus always come with a great solution
                          • massimoM Offline
                            massimo Moderator
                            Sorry Karina I didn't model it. As I said the models were taken from 3d warehouse. I've only made some changes, bevels, details addition and fully textured the models.
                            You can find the original model here.
                            • mitcorbM Offline
                              mitcorb
                              Not to pick at nits, but is that a reflection artifact in the "f"-port? (And, I am not inventing any obscene terms here)
                              • massimoM Offline
                                massimo Moderator
                                Well you're spying through the keyhole mitcorb... 😆 The interior material is the same of the exterior, a bit reflective as you can see (I was a bit lazy to apply different mats), so perhaps a normal reflection?
                                • Rich O BrienR Online
                                  That's stunning!
                                  • massimoM Offline
                                    massimo Moderator
                                    Thank you Rich! 😄
                                    • olisheaO Offline
                                      olishea
                                      just amazing work 😮 is the motion blur straight from thea? OMG lol
                                      is there a guide to CRFs anywhere? I've been playing all day but still none the wiser 😄
                                      oli
                                      • massimoM Offline
                                        massimo Moderator
                                        Yeah. 😉
                                        Set an animation (you can watch this tutorial: animating a car) then choose a frame and render it. Play a bit with "frame rate" in the render-->animation panel and with "shutter speed" in camera properties, they both control the motion blur effect. Here I've used 10 frames for the animation with frame rate=20 and shutter speed=10. 😄
                                        Just tick the CRF box in the darkroom panel or in the left panel under display properties-->exposure before, after or during the render and choose a film type you like. 😄
                                        • olisheaO Offline
                                          olishea
                                          I know but there's so many!!! 😆
                                          oli
                                          • massimoM Offline
                                            massimo Moderator
                                            😆 I'm afraid you have to try them all... but, seriously, you have many variations of the same film depending of the sensitivity, so start trying the first one of each group because the others have quite similar effects on your image with the exception of the exposure of course. Also you could try this free program called "Motiva real camera", which has the previews of the CRF. The developers cooperate with Giannis and the Thea team. 😄
