    Cello
    20 Posts 9 Posters 7.7k Views 9 Watching
    • FletchF Offline
      Fletch
      Excellent work, as always, Massimo. ๐Ÿ˜„
      Fletch
      • massimoM Offline
        massimo Moderator
        Glad you like it mitcorb and Fletch. โ˜€
        Here you have the entire textured instrument in a SU's screenshot.
          KarinaGM
          May I ask how did you model the head?
          Or could we see the wire?
          I tried to make one but with lame results ๐Ÿ˜•
          You gurus always come with a great solution
          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarรก perdiendo ambas"
          -Benjamรญn Franklin.**
          • massimoM Offline
            massimo Moderator
            Sorry Karina I didn't model it. As I said the models were taken from 3d warehouse. I've only made some changes, bevels, details addition and fully textured the models.
            You can find the original model here.
            • mitcorbM Offline
              mitcorb
              Not to pick at nits, but is that a reflection artifact in the "f"-port? (And, I am not inventing any obscene terms here)
              • massimoM Offline
                massimo Moderator
                Well you're spying through the keyhole mitcorb... ๐Ÿ˜† The interior material is the same of the exterior, a bit reflective as you can see (I was a bit lazy to apply different mats), so perhaps a normal reflection?
                  That's stunning!
                  • massimoM Offline
                    massimo Moderator
                    Thank you Rich! ๐Ÿ˜„
                    • olisheaO Offline
                      olishea
                      just amazing work ๐Ÿ˜ฎ is the motion blur straight from thea? OMG lol
                      is there a guide to CRFs anywhere? I've been playing all day but still none the wiser ๐Ÿ˜„
                      oli
                      • massimoM Offline
                        massimo Moderator
                        Yeah. ๐Ÿ˜‰
                        Set an animation (you can watch this tutorial: animating a car) then choose a frame and render it. Play a bit with "frame rate" in the render-->animation panel and with "shutter speed" in camera properties, they both control the motion blur effect. Here I've used 10 frames for the animation with frame rate=20 and shutter speed=10. ๐Ÿ˜„
                        Just tick the CRF box in the darkroom panel or in the left panel under display properties-->exposure before, after or during the render and choose a film type you like. ๐Ÿ˜„
                        • olisheaO Offline
                          olishea
                          I know but there's so many!!! ๐Ÿ˜†
                          oli
                          • massimoM Offline
                            massimo Moderator
                            ๐Ÿ˜† I'm afraid you have to try them all... but, seriously, you have many variations of the same film depending of the sensitivity, so start trying the first one of each group because the others have quite similar effects on your image with the exception of the exposure of course. Also you could try this free program called "Motiva real camera", which has the previews of the CRF. The developers cooperate with Giannis and the Thea team. ๐Ÿ˜„
