    Cello
    20 Posts 9 Posters 7.7k Views 9 Watching
      KarinaGM
      Wow! I love it. You are a master
      The most remarcable thing in every render I've seen from you are your textures. You make the objects look so natural!
      Just the bridge (don't know the name) looks rare. Is it ivory?
      **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
      -Benjamín Franklin.**
      • tridemT Offline
        tridem
        👍 Excellent work...as always 😉
          👍 It's getting to the point now when you could post an actual photograph of a cello and it'd be less convincing 😲
          • massimoM Offline
            massimo Moderator
            Thanks everybody, much appreciated. 😄
            Normally the bridge is made with a natural, not varnished maple or platan wood. Here i've used a basswood texture...maybe a bit faint. 😄
            • utilerU Offline
              utiler
              Absolutely incredible, Massimo!!
              Just Curious...
              • massimoM Offline
                massimo Moderator
                Thank you Andrew. Cheers. 😄
                • mitcorbM Offline
                  mitcorb
                  Sweet. I can hear the overtones and harmonics and that bow action is excellent. The bridge almost looks like ivory.
                  • FletchF Offline
                    Fletch
                    Excellent work, as always, Massimo. 😄
                    Fletch
                    • massimoM Offline
                      massimo Moderator
                      Glad you like it mitcorb and Fletch. ☀
                      Here you have the entire textured instrument in a SU's screenshot.
                        KarinaGM
                        May I ask how did you model the head?
                        Or could we see the wire?
                        I tried to make one but with lame results 😕
                        You gurus always come with a great solution
                        • massimoM Offline
                          massimo Moderator
                          Sorry Karina I didn't model it. As I said the models were taken from 3d warehouse. I've only made some changes, bevels, details addition and fully textured the models.
                          You can find the original model here.
                          • mitcorbM Offline
                            mitcorb
                            Not to pick at nits, but is that a reflection artifact in the "f"-port? (And, I am not inventing any obscene terms here)
                            • massimoM Offline
                              massimo Moderator
                              Well you're spying through the keyhole mitcorb... 😆 The interior material is the same of the exterior, a bit reflective as you can see (I was a bit lazy to apply different mats), so perhaps a normal reflection?
                                That's stunning!
                                • massimoM Offline
                                  massimo Moderator
                                  Thank you Rich! 😄
                                  • olisheaO Offline
                                    olishea
                                    just amazing work 😮 is the motion blur straight from thea? OMG lol
                                    is there a guide to CRFs anywhere? I've been playing all day but still none the wiser 😄
                                    oli
                                    • massimoM Offline
                                      massimo Moderator
                                      Yeah. 😉
                                      Set an animation (you can watch this tutorial: animating a car) then choose a frame and render it. Play a bit with "frame rate" in the render-->animation panel and with "shutter speed" in camera properties, they both control the motion blur effect. Here I've used 10 frames for the animation with frame rate=20 and shutter speed=10. 😄
                                      Just tick the CRF box in the darkroom panel or in the left panel under display properties-->exposure before, after or during the render and choose a film type you like. 😄
                                      • olisheaO Offline
                                        olishea
                                        I know but there's so many!!! 😆
                                        oli
                                        • massimoM Offline
                                          massimo Moderator
                                          😆 I'm afraid you have to try them all... but, seriously, you have many variations of the same film depending of the sensitivity, so start trying the first one of each group because the others have quite similar effects on your image with the exception of the exposure of course. Also you could try this free program called "Motiva real camera", which has the previews of the CRF. The developers cooperate with Giannis and the Thea team. 😄
