    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 140.5k Views 95 Watching
    • massimoM Offline
      massimo Moderator
      Thanks for the update Dale. πŸ‘
      how can you find out what version is currently installed?
      You should have a file called "artisan_loader" in the plugins folder which reports the installed version of the plugin.
      • W Offline
        Whaat
        @pbacot said:
        Thank you Dale. I have this DL'd already. I should remember, but how can you find out what version is currently installed?
        Go to Windows->Preferences->Extensions->Artisan
        • pbacotP Offline
          Thanks Dale. Got it! So there's a good use of the extensions Tab after all. Now if they'd just make that window fully expandable and regularize its use...
          • Mistro11M Offline
            Mistro11
            I am now a proud Artisan License Owner! Thanks for this great plugin! 😎
            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
            Structural Integrity is Not Just Physical...It's in the Design and Purpose
            • pbacotP Offline
              Sometimes I get no results from the sculpt tool at all. However this can change when I close the model or SU and reopen. What might be the things that make this tool work better, or worse?
              Also: I'd request some lock on vertical movement in the future, so we don't have to hold the shift key down all the time (this is the way I use almost always use it when it works).
              Version 1.2
              Thanks, Peter
              • guanjinG Offline
                guanjin
                Why do I install the free 15-day version of the display icon gray, can not be used.
                If I buy genuine worry about will not be displayed? ?
                I come from China, is to learn
                • W Offline
                  Whaat
                  Hi Peter,
                  Maybe you have a mask active? If you have any edge or face selected, the sculpt tool will only affect those selected entities. I am not sure why else you would experience this.
                  Dale
                  • W Offline
                    Whaat
                    Unless Artisan was installed previously on your computer, the icons should not be gray until 15 days have expired.
                    Once you purchase and register, the icons will no longer be grayed.
                    If you have problems with the plugin after purchase, I can provide you a refund.
                    Dale
                      matsuo_lano
                      I'm getting a bug splat after using subdivide on a single rectangle...
                      You try to rearrange me 'till I'm sane
                        Can you share the file?
                          matsuo_lano
                          Well, it's a fresh new file I've started, that's the weird thing.
                          edit
                          SketchUpUndo1.log says the following:
                          File New
                          File New
                          ======== Starting GL ========
                          CBaseGLView::OnInitialUpdate
                          InitializeOpenGL
                          GetActivePixelFormat
                          Got PF= 15 from registry
                          IsValidPixelFormatInfo
                          requestedpf.accel=1
                          ARB functions NOT available.
                          nPfds=66
                          Pixel format 1 does not do a swap copy.
                          Pixel format 4 does not do a swap copy.
                          Pixel format 7 does not do a swap copy.
                          Pixel format 10 does not do a swap copy.
                          Pixel format 13 does not do a swap copy.
                          Pixel format 16 does not do a swap copy.
                          Pixel format 19 does not do a swap copy.
                          Pixel format 22 does not do a swap copy.
                          Pixel format 25 does not do a swap copy.
                          Pixel format 28 does not do a swap copy.
                          Pixel format 15 is valid
                          GLConfigUtils::GetActivePixelFormat ... returning specified format 15
                          Make a context ... pf=15
                          Got context @3d9e020 error=0
                          GL initialization succeeded
                          ***** First UI thread = 5236
                          Tool(SketchTool)
                          Tool(SketchTool)
                          UseHWAccelerationFirstTime
                          Not first time ... returning true
                          Tool(SketchTool)
                          Tool(SketchTool)
                          Tool(RectangleTool)
                          Tool(RectangleTool)
                          Tool(RectangleTool)
                          Start(Rectangle)Commit(1)
                          Tool(RectangleTool)
                          Tool(SelectionTool)
                          Start(Reverse Face)Commit(2)
                          Start(Open)Commit(3)
                          Start(Change Axes)Commit(4)
                          Start(Macro)
                          • pbacotP Offline
                            @whaat said:
                            Hi Peter,
                            Dale
                            Thank you, Dale, I'll keep that in mind!
                            BTW is is mathematically impossible to have smooth work in vertical lock mode (like sculpt and flatten)? What do you think about a lock down setting instead of the shift key?
                            Great tool. Still learning, I guess.
                            Peter
                            • W Offline
                              Whaat
                              @pbacot said:
                              @whaat said:
                              Hi Peter,
                              Dale
                              Peter
                              Good suggestions, thanks! I will add them to the wishlist.
                              • W Offline
                                Whaat
                                matsuo:
                                It might help if you post the file. Also, what other plugins do you have installed?
                                Try temporarily putting all other plugins in a backup folder so they don't get loaded by SU to see if that fixes things. Then, try to use process of elimination to see if one particular plugin is contributing to the bug-splat.
                                Thanks.
                                Dale
                                  matsuo_lano
                                  Well, I'm using a new file, so there's nothing in there that could cause problems
                                  Edit: I've removed all the plugins, and no more bugsplats!
                                  Edit 2: Reinstalled SketchUp + replaced all the outdated plugins = problem solved!
                                  • guanjinG Offline
                                    guanjin
                                    Normal installation, but can not find the tool。
                                    I did something wrong
                                      Have you activated it in Preferences > Extensions ?
                                      Have you then activated its Toolbar ??
                                      • guanjinG Offline
                                        guanjin
                                        The toolbar nor any option
                                          Have you 'activated' its Extension ??
                                          You have not said anything about this...
                                          • guanjinG Offline
                                            guanjin
                                            Expansion which has also activated the 😳
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
