    [Plugin] Normal Map Maker
    43 Posts 21 Posters 61.0k Views 21 Watching
      @thomthom said:
      ah... 😳
      But a skewed texture only needs tree co-ordinates - why are these troublesome for triangles?
      Maybe I use the wrong wording... it's textures that are somehow rotated/skewed/sheared that need four UVs ?
        Only distorted textures needs four points.
        Normal size (based on material width and height): 1 point
        Uniformly scaled: 2 points
        Non-uniformly scaled: 3 points
        Skewed - sheared: 3 points
        Distorted: 4 points
          It's distorted then - do you mean that we CAN export these already using a TW and the material's actual face front-material?
          If so, how do we 'know' a face has a 'distorted' texture as opposed to a 'skewed' or 'rotated' one ?
          Let's say I have a face with a material that has its texture distorted and some other faces use that material 'undistorted'.
          The material is exported 'undistorted' and used with most faces with the simple 3-point UV-mapping...
          I need to know how to find which face has which type of texture, then if it's distorted then export that texture as a 'variant' using the TW with the very face, and then use that image-file for that face in the exported data.
          Is this what the built-in OBJ-Exporter does when it makes distorted texture files for some faces...
          The main issue is how do I tell if a face's material's texture is 'distorted' and needs this extra step... πŸ˜•
          It would greatly improve my OBJexporter and some 3rd party tools I am involved with...
            AcesHigh
            sorry for the stupid question but...
            1 - whats the advantage of normal map over bump and displacement maps (both of which can use the same grayscale bitmap)?
            2 - VRAY doesnt use normal maps, does it?
              http://www.spinquad.com/forums/showthread.php?4478-Normal-maps-vs.-Bump-maps&s=157424c55a8e268f44d84e57618a04cb&p=54371&viewfull=1#post54371
              http://i192.photobucket.com/albums/z232/Z-trooper/Modelling/mappings.png
              a) is a bump map
              b) is a parallax/normal map
              c) is a relief map (normal map with self shadowing)
              Not sure what V-Ray 2 does - but the version V-Ray for SketchUp currently use doesn't.
                tomasz
                http://forums.sketchucation.com/viewtopic.php?f=180&t=23947&hilit=distorted&start=60#p204899
                • PixeroP Offline
                  Pixero
                  A bumpmap is like: Hey, change your normal (surface direction) by this grayscale amount!
                  A normal map is more like: Yo, use this normal instead of your old one!
                    tspco
                    I just downloaded and installed this plugin, but it doesn't seem to work, I am sure I missed something, nothing shows up in the plugins menu. Anybody have a step by step?
                    SU make 2017, /Twilight Render Hobby
                    Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                      RepulsiveBoy
                      It doesn't work for me either 😒
                        driven
                        hi, did you look in the right place?
                        UI.menu("File").add_item("Export normal map")
                        john
                          Didier's version says this quite clearly
                          You'll find the command under the **File** menu -> Export normal map
                          πŸ˜’
                            Tuttlet
                            Great to find this Normal Map script. Thanks.
                            I found that slows down if you have the Materials Windows open to "In Model" textures. So remember to have that closed.
                            Was there any way to get a bump map from this ruby? I found some threads relating to bump mapping in Sketchup, but nothing conclusive, unless I missed it
                            http://forums.sketchucation.com/viewtopic.php?f=180&t=18024&start=15
                            http://forums.sketchucation.com/viewtopic.php?f=180&t=16660&hilit=plugin
                              You can quite easily create bump maps from (raw) geometry if you project a greyscale image from one side and then export an image from the other side.
                              • Bob JamesB Offline
                                Bob James
                                Just browsing through, got interested, and don't understand your reply.
                                project (from what onto to what?) a greyscale image from one side (of what?)
                                export an image from the other side (of what?)
                                  Tuttlet
                                  I believe this is the procedure:
                                  1. Make a rectangle with a greyscale texture in the z direction, scale it to 1.001 to ensure the top face is white
                                  2. Make the texture a projection
                                  3. Select and apply the texture to the model
                                  4. Set the time to noon, date to 3/21, location to near the equator (in File, Geo-location). Set light & dark to 100
                                  5. With a parallel projection and no edges, the top view is your bump map
                                    You can do the same without a texture, use white Fog on black geometry.
                                      Tuttlet
                                      Hey, that's even easier. Thanks.
                                      But aren't white areas usually interpreted as higher than black. I seem to get the right result with black fog on white geometry.
                                        Ah, yea - my logic is inverted this morning! πŸ˜„ 😳
                                        • sicksickisckS Offline
                                          sicksickisck
                                          great plugin and real deserves to update :]
                                          ideas ;]
                                          -read well smoothing groups!
                                          -Z-grab [without the need of the selection of the polygons; works with components and groups]
                                          • AO version hehe [dream:p]
                                          • V Offline
                                            v66995
                                            May i ask if this works on Sketchup 2015(i am using window 10)?
                                            I'm a total noob to sketchup , I've tried putting the rb file into sketchup tool folder, and it shows some error when i start up my sketchup ,so i downloaded the rbz file at extension warehouse.
                                            Then i select everything?->extension->Normal map maker-> export
                                            After its done , i went check the file , it only shows a purple square cube without the depths of other colors like the youtube tutorial shown.
                                            I did everything i can , things like : changing to parallel view/ top view first before activiating the normal map maker or applying material and then try again.
                                            It didn't work. did i do anything wrong or ?
                                            Please help /_\ ....
                                            Thanks all..
                                            Vic.
                                            • 2 / 3
