    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 467.6k Views 75 Watching
    • TaffGochT Offline
      TaffGoch
      I can attest to the "recommendation" to keep the image/bitmap SMALL!
      You would, generally, think that 512x512 pixels is "small." It is NOT !
      It will take many hours, or (if you don't have enough memory) it will choke SketchUp.
      Pay heed to the advice. This 512x512 DEM image, for example, is NOT SMALL:
      "Information is not knowledge." -- Albert Einstein
        Yea, I did the same thing while I wrote this plugin. Tested with what I thought a was a small sample. x_X
        Got some ideas for warnings for large bitmaps. And options to sample only portion of the map - like taking a max number of rows for x and y.
        • Mistro11M Offline
          Mistro11
          Just want to share my first serious experiment with this plugin here. I love working with greyscale height maps.
          I'm experimenting with terrain and water. Both the terrain and the water meshes were done with this plugin. Please excuse the terrain as I didn't smooth them, but this is mainly a water test anyway.
          Details of this experiment can be read in a thread I started in the newbie section
          http://sketchucation.com/forums/viewtopic.php?f=79&t=49668&p=447473#p447473
          Thanks again ThomThom!!! You rock with this great plugin.
          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
          Structural Integrity is Not Just Physical...It's in the Design and Purpose
            The water is a mesh as well? o_O wow! that must be a heavy model! :s
            Why not do the water as a bump map or displacement map? (since you're rendering...)
            • Mistro11M Offline
              Mistro11
              It's not as bad as it looks. I try to stay at 50-100 pixels. In the more turbulent render, I splurged and went up to 150 pixels and it only took a few more seconds to compute. It only took seconds for these meshes to compute and the model is just fine. The water mesh is actually 1 component x2 with the second mesh component flipped so the waves line up and I don't see a seam in the render. My rig is a 4 year old Q6600 running XP. There is no performance hit at all, the export to Kerky was not long especially if the mesh is made with a 50 pixel bitmap. I just make sure I put those Xfrog trees in Kerkythea and not in Sketchup.
              Why not bump or displacement map? I'm a firm believer in modeling for lighting and shadow effects as much as possible before faking with bump and displacement maps for the sake of authenticity. I did try the bump map way and was not satisfied with the results in Kerky because the shore line was just flat and not showing the waviness of the water. Not saying I don't use bump maps, I love playing with them. Just thought this plugin would take it to the next level as long as my rig can handle it. At 50 pixels, I'm surprised at how much detail we can still achieve. I'm getting a real kick out of making bump maps to make geometry.
              • panixiaP Offline
                panixia
                I 100% agree with you.. this plug-in is really nice.. and the combination between those heavy meshes and vertex tools is amazing.. i used them combined for this quite heavy old sofa.. used heightmap for tuft and golden decorations, then tweaked and welded them using vertex tools.. pretty much faster and effective results than any bump/displacement/subdivision modeling approach i can think of..
                i took some sceenshoot and i'm planning to do a tutorial in the next days about how to model this sofa using such approach..
                your water looks pretty heavy-poly too.. 😲
                http://sketchucation.com/forums/download/file.php?id=98478&mode=view/rokbox.jpg
                • Mistro11M Offline
                  Mistro11
                  Panixia, that couch looks awesome! I look forward to that tutorial. Really. πŸŽ‰
                  I just bought Vertex tools myself earlier this month. I have more practicing to do. Artisan is also a great companion to this plugin.
                  Yeah it's pretty heavy but not so bad. I just checked the file size of the water scenes. The one that's 50 pixels is 11mb and the 150 pixels is at 19mb. I'm gonna see what I can do about reducing poly count without losing quality. I consider a model to be really heavy when Sketchup begins to lag badly. The water mesh had a slight lag when I was moving the first copy. Other than that no lag at all.
                  • greenskpG Offline
                    greenskp
                    Hi guys!
                    This is a awesome plugin but i don't know how to convert into a image with grayscale.
                    For example, this image below.
                    http://i49.tinypic.com/1zx6zck.jpg
                    Anybody help me?
                      Image editor maybe?
                        If all you do is desaturating a colour image to grayscale then the plugin does this automatically while processing.
                        However, as I've been trying to stress before - converting an image to greyscale doesn't give you a height map. The light and dark areas doesn't properly represent high and low points of the geometry. Shadows, reflection and light direction will give incorrect result.
                          AndrΓ© asked for a grey scale image so I gave him one. I didn't think it would be all that useful for creating the mesh since it doesn't suit the requirements of a height map.
                            Free Heightmap editor
                              tacokid
                              First, let me apologize because I have no idea where this is going. I have never posted on any forum, so it's all new to me. What I am trying to find out is how do you download the bitmap to mesh plugin and the tt_lib that goes with it? I have been clicking on links for a while, but I'm just going in circles. I hope this plugin does what shows on the video as it could solve my problem.
                              Thanks,
                              tacokid
                              • massimoM Offline
                                massimo Moderator
                                Look at the very first post of the thread.
                                  And you can use this to aid the installation process: http://sketchucation.com/forums/viewtopic.php?t=42315#p375454
                                    tacokid
                                    You're not going to believe this, but I was having the same trouble. You would think I'm just learning to use computer too !! I did find my problem. For some reason, when I disabled my pop up blocker and re-started my browser, the pop up blocker re-enabled. So I was chasing my own tail. Did get it downloaded and will try it soon.
                                    Thanks a lot
                                      πŸ‘ πŸ‘
                                      • F Offline
                                        frankleng
                                        thanks. very nice.
                                          Soyphrenn
                                          Just one question : no working with Sketchup MacOS ?
                                            Works just fine on my Mac (OSX 10.8.4)
                                            I did this a few minutes ago.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
