    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 508.1k Views 75 Watching
      Image editor maybe?
        If all you do is desaturating a colour image to grayscale then the plugin does this automatically while processing.
        However, as I've been trying to stress before - converting an image to greyscale doesn't give you a height map. The light and dark areas doesn't properly represent high and low points of the geometry. Shadows, reflection and light direction will give incorrect result.
          AndrΓ© asked for a grey scale image so I gave him one. I didn't think it would be all that useful for creating the mesh since it doesn't suit the requirements of a height map.
            Free Heightmap editor
              tacokid
              First, let me apologize because I have no idea where this is going. I have never posted on any forum, so it's all new to me. What I am trying to find out is how do you download the bitmap to mesh plugin and the tt_lib that goes with it? I have been clicking on links for a while, but I'm just going in circles. I hope this plugin does what shows on the video as it could solve my problem.
              Thanks,
              tacokid
              • massimoM Offline
                massimo Moderator
                Look at the very first post of the thread.
                  And you can use this to aid the installation process: http://sketchucation.com/forums/viewtopic.php?t=42315#p375454
                    tacokid
                    You're not going to believe this, but I was having the same trouble. You would think I'm just learning to use computer too !! I did find my problem. For some reason, when I disabled my pop up blocker and re-started my browser, the pop up blocker re-enabled. So I was chasing my own tail. Did get it downloaded and will try it soon.
                    Thanks a lot
                      πŸ‘ πŸ‘
                      • F Offline
                        frankleng
                        thanks. very nice.
                          Soyphrenn
                          Just one question : no working with Sketchup MacOS ?
                            Works just fine on my Mac (OSX 10.8.4)
                            I did this a few minutes ago.
                              Yea, should work on OSX. Are you getting errors?
                              Did you install TT_Lib2 as well? (it's a required dependency.)
                                jjduncs
                                256x256 bmp taking 45 minutes to finish. Activity monitor shows Sketchup only using 5% while this is processing.
                                • tt_suT Offline
                                  tt_su
                                  How many cores do you have? Quad core hyper-threaded? SketchUp and Ruby 1.8 only makes use of a single core.
                                  256x256 pixels would produce 131072 triangles - so you'd have quite a dense mesh. Ruby is quite slow by itself, but the bottleneck here is SketchUp's speed of adding geometry. The more geometry already in the group you add to the slower it gets.
                                    jjduncs
                                    Yeah quad core, not sure on the hyper-threading.
                                    Ended up just scaling down to 100 x 100 in PS. Still took 20 minutes though. CPU usage only spikes higher for the last maybe 20 seconds after it finishes the generating mesh task.
                                    Thanks though.
                                    100x100 turned out fine anyway.
                                      khancyrus
                                      Hello,
                                      I had a question. I have tried this plugin and it works brilliant, but I feel I could only make it work for rectangular or planes curved in one plane only. I just wanted to know if it is possible with more organic or bulbous or more bulging surfaces in all x,y,z planes. Please forgive me if I'm using wrong terms or doing it wrong.
                                      Btw thanks for all the plugins thomthom!
                                      CSK
                                      • tt_suT Offline
                                        tt_su
                                        You mean take a surface mapped with a texture and generate new mesh - like a displacement map would?
                                          khancyrus
                                          Its sth like that if Im understanding what it is, for example I wish to create a mesh a bulging surface that would have holes in it, taken from Half tone bitmaps.
                                          For example, the facades of BIG's Tam Art Cross, but in this case a bulbous one! Im wondering, is it possible in sketchup?
                                          http://www.big.dk/#projects-tam
                                            cuttingedge
                                            Hi everyone, just installed bitmap to mesh. Can anyone show me where I can locate the tool?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
