    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 469.6k Views 92 Watching
    • BoxB Offline
      So true, I didn't mean anything by it. Just noting that we all tend to read what's in front then scroll on rather than following the story.
      • algorad88A Offline
        algorad88
        Hi Thomas,
        Thank you so much for the great plugin.
        Is there a chance to add some features to VT:
        1st: to extrude with scale similar to the move tool by holding the Ctrl key?
        2nd: Furthermore moving only in one direction at a time is time consuming, I've seen you've got another type of gizmo which has three planes which you can move in two direction by clicking on each of them?
        3rd: Also, the soft selection selects vertices in a sphere shape, could you add a feature to firstly choose which vertices to select and then continue to soft select?
          Yes - in fact, it's already added to the upcoming v2.
          Also coming in v2. πŸ˜„
          Can elaborate on this? Screenshots? Example model?
            algorad88
            Thanks for the great news πŸ‘ πŸ‘ πŸ‘
            This is how Vertex Tools selects vertices if I type 30 for soft selection:
            https://i.ibb.co/p2mLKcC/image.png
            But I only want the bottom quads selected. So, firstly I have to group those quads and then modify the vertices:
            https://i.ibb.co/wBWq7H4/image.png
            But this method has some deficiencies:
            first, we will have separated quads by modifying vertices.
            second, to join them again, we need to move those vertices which both takes much time and may not be accurate
            third, we need to explode the group to join the parts again.
            But if there were an option just like grouping which let you choose which vertices to affect the soft selection, then we could eliminate those steps
            https://i.ibb.co/h7d1Z9H/image.png
              I see now. I got plans for that as well - to add an option to apply soft selection by connected edge distance.
                SpookyChick1013
                Thom, I love the plugin, but there is a problem I keep running into, and I'm not sure if it's just a missing feature, or if it's a PEBKAC error. Is it possible to scale things unidirectionally?
                For example, select group of vertices, and then scale with gizmo tool only in the positive direction on the chosen axis, instead of what it currently does, which is scale in both positive and negative on the chosen axis?
                If there is a way to do this, it would make me very happy, πŸ˜„ as currently, this is not as useful to me as it could be for shaping terrain, which is my main use for VT.
                In order to avoid this being a Pebkac error, I havealready looked over the manual, and read back through the thread. So far, I haven't found a way to do this. Basically, I just want hte scale function to work the same way SU's native scale tool does, or Fredo's scale tool. As it is right now, it acts like Fredo's scale tool after you press CTRL, with no way to turn that off.
                Arigato!
                https://kuromatsudriveyards.com
                Fo-su to tomo ni aran koto o...
                  You can scale in the choose axis by holding down Shift. But it doesn't stop at 0. (But v2 will stop at 0 so it's easier to scale to zero.)
                    SpookyChick1013
                    Hmm. I guess I didn't do a very good job of explaining the problem. πŸ˜• The Scale tool in VT seems to scale both up and down on whatever axis, from the centerpoint of the tool, or the selected geometry. It's not a matter of trying to scale to 0. πŸ˜„ Maybe if I put it this way; If I have a mesa in a piece of flat ground, and I select only the pillar portion of the mesa, and try to scale it upward in height by a factor of three, I should only have vertices moving upward. Instead, I get some vertices moving upward, and some moving downward, leaving the pillar of the mesa, now sitting in a narrow crater. 😲 How do I alter settings so it only scales upward from the lowest point of the selected geometry? I keep thinking I remember it working this way once upon a time... πŸ˜•
                    I'll try to post some illustrations of the problem soon.
                    THanks
                    Ok. Pics. 😎 THis is what I'm trying to do is scale the selected portion to be 3 times the current height.
                    And this is what I get. 😲 Note the geometry around the pillar is scaled downward. I need to know how to turn that off, if it's possible. I hope the pictures help. πŸ˜„
                      I see.
                      I don't recall if Gizmo scale uses the Gizmo origin as scaling origin. If so then setting a custom position for the gizmo might help. (from the context menu on the Gizmo).
                      But that's probably somewhat awkward workflow. The Vertex Tools Scale tool might be the better choice with the current version.
                      I logged an issue to look into better scaling control for future versions.
                        SpookyChick1013
                        I thought that was the VT scale tool...? I'm confused now...Maybe there's something I'm missing? If there is something I'm missing, I do apolgise for being an ID10T error. Apparently that's a sin to some people around here, (not talking about you by the way,Thom) as I've found in the past.
                        I do appreciate you logging this though. A solution that would make it work more like Fredo's scale tool would be awesome.
                          There are two ways of scaling in Vertex Tools, via the Gizmo;
                          and via the Vertex Tools scale tool:
                          Which one of these were you referring to?
                            SpookyChick1013
                            The Gizmo, because that was the only thing I had ever seen in VT. I found out why I thought that was the only method of scaling. I apparently had settings tweaked so the Gizmo would show up anytime I clicked on scale. Even so, neither the Gizmo, nor the scale tool does what I need at the moment. The scale tool keeps tapering things for some reason...
                            I guess I'll just have to find some other way to do things. A shame really, because in many other ways VT is great for Terrain forming.
                            Thanks!
                            • BoxB Offline
                              Have you considered using soft select and just pulling up.
                                AndreaFryett
                                FYI. I can't purchase.
                                I tried both through sketch-up extensions warehouse and now through this website.
                                The error I get on this site is "nothing to see here" when I try to follow the purchase link
                                in sketch-up extensions I can not submit a payment, and If I go back and try again, it keeps adding quantity but I can't undo that.
                                Andy
                                  SpookyChick1013
                                  @ Box: Hai, I use that methosd in some circumstances, but it doesn' work so well when trying to scale a mountain range, or something of that nature. I appreciate the suggestion though! 😎
                                    Andy
                                    The only place to purchase Vertex Tools is at its website: https://evilsoftwareempire.com/vertex-tools
                                    It cannot be bought from Extension Warehouse.
                                    If you are having problems from https://evilsoftwareempire.com/vertex-tools - can you send me a screenshot of what you see?
                                    • PixeroP Offline
                                      Pixero
                                      @Thomthom
                                      Why can't SketchUp incorporate the way your vertex tools don't destroy texture UVs when moving vertices?
                                        @pixero said:
                                        @Thomthom
                                        It's a matter of priorities of infinite amount of improvement requests vs a finite amount of time.
                                        • O Offline
                                          optimaforever
                                          Vertex tools is really a must have in my toolset, it's so handy to have when dealing with complex geometry...
                                          Is V2 allowing easier placement of gizmo for scaling/rotating/moving? By default, the scale/rotate uses a gizmo position centered on the selection. But sometimes I'd like to manually move the gizmo to define another center for the scaling/rotating, like on a vertex or the edge of the selection.
                                          A quick and dirty way, like Ctrl + move along the axis would move the gizmo without altering the geometry... or something like that.
                                          And what about a 'smart' offset of a loop/ring? Kind of SU offset tool but that works in 3d space too.
                                          Imagine a curved road (in XY but also in Z too) and you'd need to quickly offset the rim edges to add the shoulder, curbing, drainage, walkway, etc.
                                          In 2d space it's easy as SU offset tool works but if the site is not flat it's another story...
                                          I suppose it's similar to the extrude with scaling demand I saw earlier in the thread...?
                                          If the selection is planar I usually create a face and use FREDO JointPushpull's Follow pushpull which takes into account the connected faces, but it would be handy to be able to do that with a non coplanar edge selection.
                                          smart offset edges
                                            turbodizayn
                                            Hi, I think feature to get softselection within preselected choice of objects will be most important thing of all other vertex tool features. I wrote about it many times ago. https://sketchucation.com/forums/viewtopic.php?f=323&t=70985
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 33
                                            • 34
                                            • 28 / 34
