    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 438.4k Views 92 Watching
    • X Offline
      xrok1
      it would be like the smoove tool works when nothing is preselected. ๐Ÿ˜‰
      also a weld tool would be nice too with distance setting like in MAX. ๐Ÿ’š
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        Yup! Already on my list.
        ... I should probably make a list of the features I am planning...
        Other features are:
        Jitter - randomly offset the vertices
        Gizmos - Move,Rotate and Scale gizmos for better control
        And some other stuff ๐Ÿ˜‰
        • X Offline
          xrok1
          love the jitter idea. i already use the jitter ruby (modified a little ๐Ÿ˜‰ ) to add a little age or just mellow out the CG look sometimes.
          • honoluludesktopH Offline
            honoluludesktop
            Wow, it that a mesh, or linked surfaces?
              What is?
                honoluludesktop
                The plane, or cylinder, etc. Hmm..... maybe I don't know how to ask my question. If still unclear, attached is a sample. Can I change its shape? What happens to the textures? Btw, thats a very slick menu.
                Temp00.skp
                  Yes - here's your model after I selected a part of it, with soft selection and moved it. Looks like the wind pushes the curtains.
                  As for the UV mapping, that will unfortunately be messed up - as normally happens in SketchUp when you modify UV mapped geometry.
                  However, this is another feature I am looking into. If I can get it working I will probably also make a standalone "preserve UV mapping" plugin.
                  I hope that answered your question? ๐Ÿ˜•
                    Btw, here is your sample file after I modified it. The UV mapping didn't seem to bad.
                    Temp00_TT.skp
                      honoluludesktop
                      Thanks, where were you when I needed it ๐Ÿ™‚ the texture was a SU floor covering that I scaled and changed the color of.
                        Coding into the night ๐Ÿ˜‰
                        • shuraS Offline
                          shura
                          Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
                          btw, nice to hear your voice again ๐Ÿ˜‰
                          best
                          alex
                          • X Offline
                            xrok1
                            Thom, what address do you send your email from? maybe the domain name is in my blocked sender list for some reason. i still havn't recieved. ๐Ÿ˜ž
                              honoluludesktop
                              Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
                              • X Offline
                                xrok1
                                are you talking about a cage or proxy mesh? or opposite of subdivision?
                                  honoluludesktop
                                  What is a cage or a proxy mesh?
                                  • X Offline
                                    xrok1
                                    like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
                                    here is an example: you manipulate the outer mesh to effect the inner one.
                                    • X Offline
                                      xrok1
                                      ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
                                      SDS WITH SOFT SELECTION!
                                      http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
                                      • ArcA Offline
                                        Arc
                                        I made a little video tut, but I don'n know how to instert ping video in post?
                                        http://www.screencast.com/t/OTlkZWRjMT
                                        [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
                                          honoluludesktop
                                          Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                                            best
                                            alex
                                            Hi Alex! Thank you very much!
                                            Hope you are doing well. Give me a shout if you should find yourself in Trondheim again! ๐Ÿ˜„
                                            • 33
                                            • 34
                                            • 2 / 34
