    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 392.9k Views 92 Watching
      Yea - that sounds familiar. The work on SUbD made me forget some of the details of existing Vertex Tools issues. Seeing how VT2 is taking longer to complete, I may have to do a bug patch to v1.2.
      • N Offline
        numerobis
        As i said earlier i would prefer a simple edge constraint toggle like in max instead of having to align the gizmo first every time i want to move a vertex along an edge...
          MichaelSiggers
          Hi @thomthom
          This is a genius plugin!
          Purchased a couple of days ago and I love it.
          Only thing is, I second the comment about being able to type in a distance when moving a selection with the Gizmo.
          Brilliant work though. Thankyou.
          Kind regards
          Mike
            Version 1.2.11
            Improvements
            • Added Serbian translations.
            • Added Albanian translations.
            • Updated Spanish translations.
            Fixes
            • Fixed Gizmo VCB adjustments not working.
              MichaelSiggers
              Thank you Thomas πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
              Mike
              • O Offline
                optimaforever
                Great!
                To be sure:
                1. select vertices
                2. use VT's select mode (gizmo) and begin moving the vertices along red, green or blue axis.
                3. WHILE keeping left mouse button down, type desired value in VCB. type enter.
                4. the vertices gets moved along axis
                5. RELEASE left mouse button.
                Once you release the LMB, VCB awaits for soft select radius value, so it doesn't work like the move tool of Sketchup, where you can change your mind afterwards and tweak the move value.
                Is it correct?
                PS I realized that this behaviour works also for scale and rotate. Type value in VCB while keeping LMB pressed down. Once you press enter, the vertices gets modified according to the value.
                It's just tricky for cases where I need to press Shift with my left hand while keeping the LMB pressed down. I noticed that you can release Shift after you began the scale movement and type a value in the VCB but you can't move the mouse otherwise the Shift indication gets lost.
                  With 1.2.11 you should be able to adjust after releasing LMB.
                  • O Offline
                    optimaforever
                    Thanks Thomas.
                    It works indeed as you said.
                    However I think I have a problem with the latest VT as it hangs SU at launch.
                    And second, when I try to Ctrl+move an edge AND type a value in the VCB afterwards, it bugs.
                    • Bob JamesB Offline
                      Bob James
                      Should I assume that "Make Planar to a custom plane" won't happen until V2?
                        SU freeze? Permanently? I see no reason for any change in startup. Minimal code was touched...
                        Is this a new bug?
                        • O Offline
                          optimaforever
                          I don't know if this is a new bug but it happens right after typing the value in the VCB. Your bug window appears and I have already sent the bug message to you.
                            I'm able to reproduce. I think I have a fix, but I need to test if it breaks other stuff.
                              Version 1.2.12
                              Fixes
                              • Fixes VCB adjustments for Gizmo Ctrl+Move.
                              • O Offline
                                optimaforever
                                Cool. that was fast.
                                • O Offline
                                  optimaforever
                                  About the hanging issue, it's very strange.
                                  It takes around 5-10 min after launching SU to be actually available (move in the viewport).
                                  Where can I check the launching log of SU?
                                    There is none...
                                    The lag goes away if you disable or remove VT?
                                    • O Offline
                                      optimaforever
                                      I've tried this, but that doesn't change anything.
                                      I'm busy trying to reinstall SU 2017.
                                        Have you tried removing all files related to Vertex Tools? After using uninstall from Extension Manager there might be files left. Could you check your Plugins folder?
                                          sofie9536
                                          works fine,thanks
                                            jzar_kobi
                                            I can't seem to connect to the license server, yes I have unblocked with my firewall still no luck
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
