    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 480.8k Views 92 Watching
      SpookyChick1013
      Hmm. I guess I didn't do a very good job of explaining the problem. πŸ˜• The Scale tool in VT seems to scale both up and down on whatever axis, from the centerpoint of the tool, or the selected geometry. It's not a matter of trying to scale to 0. πŸ˜„ Maybe if I put it this way; If I have a mesa in a piece of flat ground, and I select only the pillar portion of the mesa, and try to scale it upward in height by a factor of three, I should only have vertices moving upward. Instead, I get some vertices moving upward, and some moving downward, leaving the pillar of the mesa, now sitting in a narrow crater. 😲 How do I alter settings so it only scales upward from the lowest point of the selected geometry? I keep thinking I remember it working this way once upon a time... πŸ˜•
      I'll try to post some illustrations of the problem soon.
      THanks
      Ok. Pics. 😎 THis is what I'm trying to do is scale the selected portion to be 3 times the current height.
      And this is what I get. 😲 Note the geometry around the pillar is scaled downward. I need to know how to turn that off, if it's possible. I hope the pictures help. πŸ˜„
      https://kuromatsudriveyards.com
      Fo-su to tomo ni aran koto o...
        I see.
        I don't recall if Gizmo scale uses the Gizmo origin as scaling origin. If so then setting a custom position for the gizmo might help. (from the context menu on the Gizmo).
        But that's probably somewhat awkward workflow. The Vertex Tools Scale tool might be the better choice with the current version.
        I logged an issue to look into better scaling control for future versions.
          SpookyChick1013
          I thought that was the VT scale tool...? I'm confused now...Maybe there's something I'm missing? If there is something I'm missing, I do apolgise for being an ID10T error. Apparently that's a sin to some people around here, (not talking about you by the way,Thom) as I've found in the past.
          I do appreciate you logging this though. A solution that would make it work more like Fredo's scale tool would be awesome.
            There are two ways of scaling in Vertex Tools, via the Gizmo;
            and via the Vertex Tools scale tool:
            Which one of these were you referring to?
              SpookyChick1013
              The Gizmo, because that was the only thing I had ever seen in VT. I found out why I thought that was the only method of scaling. I apparently had settings tweaked so the Gizmo would show up anytime I clicked on scale. Even so, neither the Gizmo, nor the scale tool does what I need at the moment. The scale tool keeps tapering things for some reason...
              I guess I'll just have to find some other way to do things. A shame really, because in many other ways VT is great for Terrain forming.
              • BoxB Offline
                Have you considered using soft select and just pulling up.
                  AndreaFryett
                  FYI. I can't purchase.
                  I tried both through sketch-up extensions warehouse and now through this website.
                  The error I get on this site is "nothing to see here" when I try to follow the purchase link
                  in sketch-up extensions I can not submit a payment, and If I go back and try again, it keeps adding quantity but I can't undo that.
                  Andy
                    SpookyChick1013
                    @ Box: Hai, I use that methosd in some circumstances, but it doesn' work so well when trying to scale a mountain range, or something of that nature. I appreciate the suggestion though! 😎
                      Andy
                      The only place to purchase Vertex Tools is at its website: https://evilsoftwareempire.com/vertex-tools
                      It cannot be bought from Extension Warehouse.
                      If you are having problems from https://evilsoftwareempire.com/vertex-tools - can you send me a screenshot of what you see?
                      • PixeroP Offline
                        Pixero
                        @Thomthom
                        Why can't SketchUp incorporate the way your vertex tools don't destroy texture UVs when moving vertices?
                          @pixero said:
                          @Thomthom
                          It's a matter of priorities of infinite amount of improvement requests vs a finite amount of time.
                          • O Offline
                            optimaforever
                            Vertex tools is really a must have in my toolset, it's so handy to have when dealing with complex geometry...
                            Is V2 allowing easier placement of gizmo for scaling/rotating/moving? By default, the scale/rotate uses a gizmo position centered on the selection. But sometimes I'd like to manually move the gizmo to define another center for the scaling/rotating, like on a vertex or the edge of the selection.
                            A quick and dirty way, like Ctrl + move along the axis would move the gizmo without altering the geometry... or something like that.
                            And what about a 'smart' offset of a loop/ring? Kind of SU offset tool but that works in 3d space too.
                            Imagine a curved road (in XY but also in Z too) and you'd need to quickly offset the rim edges to add the shoulder, curbing, drainage, walkway, etc.
                            In 2d space it's easy as SU offset tool works but if the site is not flat it's another story...
                            I suppose it's similar to the extrude with scaling demand I saw earlier in the thread...?
                            If the selection is planar I usually create a face and use FREDO JointPushpull's Follow pushpull which takes into account the connected faces, but it would be handy to be able to do that with a non coplanar edge selection.
                            smart offset edges
                              turbodizayn
                              Hi, I think feature to get softselection within preselected choice of objects will be most important thing of all other vertex tool features. I wrote about it many times ago. https://sketchucation.com/forums/viewtopic.php?f=323&t=70985
                              @algorad88 said:
                              @thomthom said:
                              Yes - in fact, it's already added to the upcoming v2.
                              Also coming in v2. πŸ˜„
                              Thanks for the great news πŸ‘ πŸ‘ πŸ‘
                              @thomthom said:
                              Can elaborate on this? Screenshots? Example model?
                              This is how Vertex Tools selects vertices if I type 30 for soft selection:
                              https://i.ibb.co/p2mLKcC/image.png
                              But I only want the bottom quads selected. So, firstly I have to group those quads and then modify the vertices:
                              https://i.ibb.co/wBWq7H4/image.png
                              But this method has some deficiencies:
                              first, we will have separated quads by modifying vertices.
                              second, to join them again, we need to move those vertices which both takes much time and may not be accurate
                              third, we need to explode the group to join the parts again.
                              But if there were an option just like grouping which let you choose which vertices to affect the soft selection, then we could eliminate those steps
                              https://i.ibb.co/h7d1Z9H/image.png
                              • O Offline
                                optimaforever
                                Hi Thom!
                                One thing that annoys me is the fact that I need to quit Vertextools mode to select quad loops or rings with QFT... Is it not possible to get loop/ring selections while in Vertex tool ?
                                Just wondering... πŸ˜‰
                                • summerson1990S Offline
                                  summerson1990
                                  Can’t activate my license. Suppose the problem with site’s server (evilsoftwareempire.com) it doesn’t work. Please fix it
                                    turbodizayn
                                    Here is how soft editing realized in Rhino
                                    http://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/softmove.htm
                                    If tt_vertex tool has this feature ...!!!
                                      jukkoo
                                      @thomthom said:
                                      @algorad88 said:
                                      1st: to extrude with scale similar to the move tool by holding the Ctrl key?
                                      Is this in the picture what you were talking about?
                                      scale with CTRL?
                                      I just got vertex tools and was hoping this was already an option. IT is actually an extremely useful tool when modeling with quad geometry.
                                      When do you plan to complete v2? πŸ˜„
                                      Don't get me wrong, I am extremely grateful for your efforts. Sketchup without your plugins would be half the program it is.
                                        pipinek
                                        Greetings,
                                        Is there any possibility to have the toolbar kept on the screen instead of activated it each time one clicks on the empty screen?
                                        Thank you in advance.
                                        • E Offline
                                          Einstein
                                          Hi!
                                          It seems that among Vertex Tools' shortcuts there's no one to call the general toolbar. There are only hotkeys for particular operations but I'd like to press V and activate the plugin toolbar. It would be cool to add such an option I think. Just a suggestion πŸ˜„
                                            pipinek
                                            @einstein said:
                                            Hi!
                                            Thank you for the suggestion.
                                            I have been using a shortcut to activate the toolbar.
                                            I find it annoying to have to recall it every time using a single tool.
                                            I wish it could be an option to keep the toolbar permanently on the screen.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 33
                                            • 34
                                            • 28 / 34
