    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 297 Posters 2.4m Views 296 Watching
      bekans
      Yes,that's what I did: all up to date versions auto-installed via the plugin store, no moving or copying. Same procedure for each machine separately. On the new win 8.1 machine everything has been installed for the first time. Besides Total Commander it's only application πŸ˜‰
      • fredo6F Offline
        fredo6
        @bekans
        Do you have any problem like this with my other plugins (if you installed some).
        Is it just with Curviloft?
        Also
        • is it will all 3 Tools of Curviloft?
        • if you start a Curviloft tool on a pre-selection, do you get the freeze too?
        Fredo
          bekans
          Hello Fredo,
          I'll stick to the win 8.1 machine because less chance I messed something up with whatever....
          Yes, all three
          I tested that too: with pre-selection, without pre-selection.
          Maybe it's my model: I tried with very basic shapes, no problems. But I dont think my shape is that compliclated. I recall having skinned more complex models. Anyway, maybe I'm overlooking something. I'll include my model.
          Many thanks for having a look.
          Bekans
          test-curviloft.skp
          • fredo6F Offline
            fredo6
            I tried with your model on SU14 (but Win7).
            No issue with loft
            But do you mean it happens with some models only, not all of them
            Fred
            • alvisA Offline
              alvis
              Three almost identical contours, three different results. Why ?
              curvyskin.skp
                Interesting. I get similar results. How did you draw them? What did you do differently from one to the next?
                • alvisA Offline
                  alvis
                  I've used all the means and methods. I drew the curves with ARC tool. Then I tried to with BZ plugin. But the result is the same.
                    davidbierman2003
                    I have the plug in working in Sketchup. Is there anyway to not include certain portions of what the surface will form? For example, I am working on creating a surface for roads. The roads cover a large surface, and the program creates a large surface covering everything. I just want a surface to cover the roads.
                    Thanks,
                    David
                    • jgbJ Offline
                      jgb
                      @davidbierman2003 said:
                      Thanks,
                      David
                      Pre-select only the perimeter lines of what you want surfaced. You can include any lines within the perimeter, if you want. Then click the skinning icon.
                      jgb
                      • N Offline
                        Negatee
                        thx !!!
                          robmoors
                          Amazing plugin, incredible amount of control. Thank you!
                          Rob Moors
                          Architecture Student
                            jumpjack
                            I can't understand how (if) I can use this plugin to fill the many holes in this model:
                            http://img22.imageshack.us/img22/7514/zar8.jpg
                            I select the contour of a hole, but none of the three buttons of the plugin is able to fill the hole for me.
                              Why can't you attach the image ?
                              It's a bit much to ask someone to download and then view it...
                              You could even attach part of the SKP so we could look at it πŸ˜•
                              Anyway what makes you think CurviLoft 'heals' holes ?
                                jumpjack
                                You've just to click the above,link, anyway here it is:
                                Because it does in one case: "skinning" works fine in filling holes on a flat surface; I thought it could also do it for a generic contour.
                                Anyway I'm not sure it actually can for any contour: that's why the "if" in parenthesis.
                                Do I need a different plugin?
                                  It might be that Curviloft could close up the holes. Maybe there's a different plugin that would do it. Without the model, it's not possible to give you a definitive answer.
                                  BTW, please complete your profile with SU version and operating system.
                                  • BoxB Offline
                                    'Clicking the link above' only takes you to the page to download it. You still then have to download it to view it.
                                    • fredo6F Offline
                                      fredo6
                                      NEW RELEASE: Curviloft v1.4a - 19 Oct 14
                                      Curviloft 1.4a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                      See main post of this thread for Download.
                                      Fredo
                                        jumpjack
                                        Clicking THIS link takes to a download page?!?
                                        Anyway, it looks the plugin can actually fill the holes, although for most irregular contours it gives weird results. I wonder if it is tunable to get the "filling" as flat as possible.
                                        Additionally, how could I get this selection
                                        http://sketchucation.com/forums/download/file.php?id=124359
                                        from this manual selection?
                                        http://sketchucation.com/forums/download/file.php?id=124358
                                        • BoxB Offline
                                          As mentioned in the other thread where you asked, By smoothing the lines surrounding the edges of the hole you can create one surface that is easy to select.
                                            jumpjack
                                            I have dozens of such holes in my model, each one delimited by a contour made of several dozens of segments: doing it by hand would take years... 😒 That's why I'm looking for some kind of automation. Maybe I need some kind of "simplify polyline" plugin, but don't know if it even exists or CAN exist.
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 65
                                            • 66
                                            • 50 / 66
