    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • alvisA
      alvis
      @dave r said:
      Interesting. I get similar results. How did you draw them? What did you do differently from one to the next?
      I've used all the means and methods. I drew the curves with ARC tool. Then I tried to with BZ plugin. But the result is the same.
        davidbierman2003
        I have the plug in working in Sketchup. Is there anyway to not include certain portions of what the surface will form? For example, I am working on creating a surface for roads. The roads cover a large surface, and the program creates a large surface covering everything. I just want a surface to cover the roads.
        Thanks,
        David
        • jgbJ
          jgb
          @davidbierman2003 said:
          Thanks,
          David
          Pre-select only the perimeter lines of what you want surfaced. You can include any lines within the perimeter, if you want. Then click the skinning icon.
          jgb
          • N
            Negatee
            thx !!!
              robmoors
              Amazing plugin, incredible amount of control. Thank you!
              Rob Moors
              Architecture Student
                jumpjack
                I can't understand how (if) I can use this plugin to fill the many holes in this model:
                http://img22.imageshack.us/img22/7514/zar8.jpg
                I select the contour of a hole, but none of the three buttons of the plugin is able to fill the hole for me.
                  Why can't you attach the image ?
                  It's a bit much to ask someone to download and then view it...
                  You could even attach part of the SKP so we could look at it πŸ˜•
                  Anyway what makes you think CurviLoft 'heals' holes ?
                    jumpjack
                    You've just to click the above,link, anyway here it is:
                    Because it does in one case: "skinning" works fine in filling holes on a flat surface; I thought it could also do it for a generic contour.
                    Anyway I'm not sure it actually can for any contour: that's why the "if" in parenthesis.
                    Do I need a different plugin?
                      It might be that Curviloft could close up the holes. Maybe there's a different plugin that would do it. Without the model, it's not possible to give you a definitive answer.
                      BTW, please complete your profile with SU version and operating system.
                      • BoxB
                        'Clicking the link above' only takes you to the page to download it. You still then have to download it to view it.
                        • fredo6F
                          NEW RELEASE: Curviloft v1.4a - 19 Oct 14
                          Curviloft 1.4a is required for the support of usernames with non-ascii characters in Sketchup 2014
                            jumpjack
                            Clicking THIS link takes to a download page?!?
                            Anyway, it looks the plugin can actually fill the holes, although for most irregular contours it gives weird results. I wonder if it is tunable to get the "filling" as flat as possible.
                            Additionally, how could I get this selection
                            http://sketchucation.com/forums/download/file.php?id=124359
                            from this manual selection?
                            http://sketchucation.com/forums/download/file.php?id=124358
                            • BoxB
                              As mentioned in the other thread where you asked, By smoothing the lines surrounding the edges of the hole you can create one surface that is easy to select.
                                jumpjack
                                I have dozens of such holes in my model, each one delimited by a contour made of several dozens of segments: doing it by hand would take years... 😒 That's why I'm looking for some kind of automation. Maybe I need some kind of "simplify polyline" plugin, but don't know if it even exists or CAN exist.
                                • BoxB
                                  I think you'd have more luck repairing you mesh in Meshlabs or similar.
                                  Sketchup isn't really designed to do what you want whereas software like Meshlab, Nettfab etc are .
                                    jumpjack
                                    No, they try to fix whole model in a single pass, it's too complex and they fail.
                                    Using sketchup I could "fine tune" the model sub-region by sub-region.
                                    • BoxB
                                      There is no one way to fix it. At a guess looking at the picture with seeing the actual model, one way would be to select sections and smooth them so you have clearly defined holes within selectable surfaces. Then select a hole and use soapskin bubble to skin it. Continue until all holes are skinned and put all the sections back together.
                                        jumpjack
                                        How?
                                        • BoxB
                                          How? What? Which part isn't clear?
                                          You have yourself listed in your profile as Advanced, it is assumed therefore that you know the basics. Could you clarify your sketchup level so we know how to answer your questions.
                                            jumpjack
                                            Nevermind, I'll ask somebody else.
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 65
                                            • 66
                                            • 50 / 66
