    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 299 Posters 2.5m Views 297 Watching
      Have you also downloaded and correctly installed the required helper file-set LibFredo6 ?
      http://sketchucation.com/forums/viewtopic.php?p=144178#p144178
        Ralphxyz
        Yup!!
        I have the Curviloft toolbar and the Tools/Fredo6 Collection menu Curviloft menu item.
        They do "work" in my limited testing.
        Ralph
          Have you checked that you have FULL security permissions to the Plugins folder and its contents?
          Right-click context-menu on its icon, Properties > Security > Edit...
          It might be that your rights are limited ??
          Also is there a 'Compatibilities Files...' link button on the Explorer window for the Plugins folder, which might means some things are not installed as it appears... [Windows πŸ˜’ ]
            Ralphxyz
            TIG I can not follow what you are asking. "its icon"??
            Here is my Plugin menu.
            http://gettheworkdone.net/3Dprinting/SketchUp/Plugins.png
            There is no 'Compatibilities Files...' in the Plugins menu.
            Ralph
              Ralph, TIG is referring to the icon for the Plugins folder (or its name ) in Windows Explorer. Not in SketchUp. You need to make sure that you have full read and write permissions for the Plugins folder and any folders within that folder. The plugin needs to be able to write information to a file in the Plugins folder which it can't do without full read and write permissions.
                Ralphxyz
                Thanks Dave, but nope All Users and Administrator have "Full Control".
                Ralph
                  Ralph, you're making my head hurt. πŸ˜„
                  So you are still getting this error? And you have LibFredo installed correctly, too? Something isn't installed right.
                  • gillesG Offline
                    gilles
                    @ Tig and Dave,
                    Your patience seems to have no limits, I don't remember how much time I read the same answers to the same problems. πŸ˜‰
                      Ralphxyz
                      Well Dave that's good as least you do not think of me as a pain int A..
                      and gilles the answer is??
                      Ralph
                        Thank you, Gilles.
                        Ralph. not yet. πŸ˜‰
                        So how about giving us a screenshot of your Plugins folder and another showing the contents of the LibFredo folder? If that doesn't show us anything I'm going to remote into your computer and see if I can fix it. πŸ˜„
                        • gillesG Offline
                          gilles
                          Ralph
                            Ralphxyz
                            I have a lot of Plugins.
                            http://gettheworkdone.net/3Dprinting/SketchUp/Plugins2.png
                            Here is Fredo
                            http://gettheworkdone.net/3Dprinting/SketchUp/Fredo.png
                            You guys absolutely are headed for sainthood.
                            Ralph
                              Ralph! Don't make me come over there! 😑 🀣
                              Your Plugins folder contains all those files that are supposed to be in the Curviloft folder. You must have tried installing them twice. Clear out every file from the Plugins folder that should be in the Curviloft folder. Make sure you also delete _loader.rb, too.
                                Ralphxyz
                                Hot Dog!! That did it plus a bootstrap_Curviloft.rb.
                                Yeah I probable did a number of installs.
                                I tried to load the 10 must have plugins.
                                Ralph
                                  Excellent! I knew we'd figure it out. We just needed the right clue.
                                    Ralph, you can try to use either one of these utilities to assist you installing correctly:
                                    http://sketchucation.com/forums/viewtopic.php?t=42315
                                    http://sketchucation.com/forums/viewtopic.php?f=51330
                                    They are RBZ packages so you use the Install Extension feature in SketchUp to install them. Then they will assist you in correctly install RB, RBS, RBZ or ZIP packaged plugins.
                                    General guide on installing: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                      Ralphxyz
                                      Hi thomthom, I found those helpers after I had done the installs. I didn't think to just delete everything I had done and use the install helpers.
                                      Could those links be made sticky at the start of the Forum.
                                      Maybe there could be a Plugins Getting Started sticky header.
                                      Ralph
                                        There is a "Zipped Plugins -- A Guide to Installing Them" sticky - but unfortunately it's not visibly that distinguishable. πŸ˜•
                                          It's a good idea Ralph. In my experience, though, most people won't take the time to read that sort of thing anyway. It's just easier to ask the question even in cases where it's been asked dozens of time before.
                                          • jgbJ Offline
                                            jgb
                                            When I was working an on-line/phone tech-help site, we got so many "asked & answered many times" we setup a list of "FAQs" and their answers as a set of clippable notes.
                                            Then it was just cut&paste for about 65% of the time. Anything "new" was added to the list at the end of the call or email answer.
                                            When I was monitoring the old Google Sketchup (before SketchUcation) I found myself doing a quick search, cut&paste for many of the same FAQs as well, especially the near field clipping solution.
                                            Even providing an extensive published and promoted list of FAQ's, almost nobody would take the time to look up their problem first. Like Dave R said, easier to ask..........
                                            But, part of the problem are folks that have difficulty forming the question/problem so that they can best use a FAQ's list. We see that here many times where the post "I got a problem......" sometimes does not say what the problem is on first go-round. Language barriers are only a small part of it.
                                            jgb
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 65
                                            • 66
                                            • 44 / 66
