    1.3k Posts 300 Posters 3.1m Views 298 Watching
      Ralphxyz
      Thanks Dave, but nope All Users and Administrator have "Full Control".
      Ralph
        Ralph, you're making my head hurt. πŸ˜„
        So you are still getting this error? And you have LibFredo installed correctly, too? Something isn't installed right.
        • gillesG
          gilles
          @ Tig and Dave,
          Your patience seems to have no limits, I don't remember how much time I read the same answers to the same problems. πŸ˜‰
            Ralphxyz
            Well Dave that's good as least you do not think of me as a pain int A..
            and gilles the answer is??
            Ralph
              Thank you, Gilles.
              Ralph. not yet. πŸ˜‰
              So how about giving us a screenshot of your Plugins folder and another showing the contents of the LibFredo folder? If that doesn't show us anything I'm going to remote into your computer and see if I can fix it. πŸ˜„
              • gillesG
                gilles
                Ralph
                  Ralphxyz
                  I have a lot of Plugins.
                  http://gettheworkdone.net/3Dprinting/SketchUp/Plugins2.png
                  Here is Fredo
                  http://gettheworkdone.net/3Dprinting/SketchUp/Fredo.png
                  You guys absolutely are headed for sainthood.
                  Ralph
                    Ralph! Don't make me come over there! 😑 🀣
                    Your Plugins folder contains all those files that are supposed to be in the Curviloft folder. You must have tried installing them twice. Clear out every file from the Plugins folder that should be in the Curviloft folder. Make sure you also delete _loader.rb, too.
                      Ralphxyz
                      Hot Dog!! That did it plus a bootstrap_Curviloft.rb.
                      Yeah I probable did a number of installs.
                      I tried to load the 10 must have plugins.
                      Ralph
                        Excellent! I knew we'd figure it out. We just needed the right clue.
                          Ralph, you can try to use either one of these utilities to assist you installing correctly:
                          http://sketchucation.com/forums/viewtopic.php?t=42315
                          http://sketchucation.com/forums/viewtopic.php?f=51330
                          They are RBZ packages so you use the Install Extension feature in SketchUp to install them. Then they will assist you in correctly install RB, RBS, RBZ or ZIP packaged plugins.
                          General guide on installing: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                            Ralphxyz
                            Hi thomthom, I found those helpers after I had done the installs. I didn't think to just delete everything I had done and use the install helpers.
                            Could those links be made sticky at the start of the Forum.
                            Maybe there could be a Plugins Getting Started sticky header.
                            Ralph
                              There is a "Zipped Plugins -- A Guide to Installing Them" sticky - but unfortunately it's not visibly that distinguishable. πŸ˜•
                                It's a good idea Ralph. In my experience, though, most people won't take the time to read that sort of thing anyway. It's just easier to ask the question even in cases where it's been asked dozens of time before.
                                • jgbJ
                                  jgb
                                  When I was working an on-line/phone tech-help site, we got so many "asked & answered many times" we setup a list of "FAQs" and their answers as a set of clippable notes.
                                  Then it was just cut&paste for about 65% of the time. Anything "new" was added to the list at the end of the call or email answer.
                                  When I was monitoring the old Google Sketchup (before SketchUcation) I found myself doing a quick search, cut&paste for many of the same FAQs as well, especially the near field clipping solution.
                                  Even providing an extensive published and promoted list of FAQ's, almost nobody would take the time to look up their problem first. Like Dave R said, easier to ask..........
                                  But, part of the problem are folks that have difficulty forming the question/problem so that they can best use a FAQ's list. We see that here many times where the post "I got a problem......" sometimes does not say what the problem is on first go-round. Language barriers are only a small part of it.
                                  jgb
                                  • H
                                    hygicell
                                    Hi Fredo,
                                    I am working on a project for an aquaponics farm of which the building consists of shipping containers, with a greenhiouse on the south side
                                    this building then has to be covered by a moat on the north side which includes two terrasses
                                    to draw the moat landscape,
                                    I drew the outlines, then tried to use Curviloft skinning
                                    it didn't work in one piece
                                    I then added some lines, tried again, no success
                                    then I tried in segments, that worked for some, not for all
                                    I had to further split them up
                                    finally I succeeded, exploded all groups, smoothed the edges, painted all surfaces with grass
                                    you can see my trials in the file attached
                                    ooops, that didn't work: file too large
                                    compressed it with 7-zip, more than halved the file size
                                    http://download.cnet.com/7-Zip-64-bit/3000-2250_4-75133313.html?tag=dre
                                    hope you appreciate the feedback
                                    greetings
                                    Frank
                                    container farmhouse with moat.7z
                                    • fredo6F
                                      Franck,
                                      I cannot open the file, even if I replace the extension .7z by .zip
                                      • H
                                        hygicell
                                        container farmhouse with moat.zip
                                        • fredo6F
                                          @hygicell,
                                          Looking at your model, I found many unconnected contours.
                                          I think there is a plugin to connect segments which have their extre,ities very close.
                                          This explains why you have problems with the Skinning.
                                          Also, in some portions of the shapes, the contours look very shaky, with sharp angles. I am afraid that Curviloft won't give a very good result on these ones.
                                          • K
                                            Kanastrous
                                            This plugin looks like just the thing for what I need to do in Sketchup Pro 8 (version 8.0.11752, running under Windows XP Pro ) but when I install it and then start sketchup I get the following message:
                                            Error Loading File bootstrap_Curviloft.rb
                                            uninitialized constant Curviloft::T6
                                            Sketchup then opens and appears to run normally, but the curviloft plugin does not appear.
                                            Any thoughts on how to get this install to work? Curviloft looks like a real life-saver, if only I can get it working...
                                            thanks,
                                            karl
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 65
                                            • 66
                                            • 44 / 66
