    1.3k Posts 300 Posters 3.3m Views 298 Watching
      mikeypals23
      I cant seem to get Curviloft to appear in SketchUp. As far as I can tell, I installed that and LibFredo6 correctly. Any help would be appreciated! Thank you for your time.
        But you haven't installed Curviloft correctly. You've not maintained the file structure as described in the first post of this thread.
        All of the files in the red box as well as the folder called IMAGES_Standard should be in a folder called CURVILOFT_Dir_12.
          mikeypals23
          Thank you for the help! Working now, sorry for the careless oversight!
            Ralphxyz
            I am getting this error when trying to run Curviloft.
            http://gettheworkdone.net/3Dprinting/SketchUp/Curviloft.png
            Ralph
              Where is the file called bootstrap_Curviloft.rb? It should be in a folder called CURVILOFT_Dir_12 but I'm guessing it isn't.
              In fact you should have all these files in that folder.
                Ralphxyz
                Yup, I have them:
                http://gettheworkdone.net/3Dprinting/SketchUp/curviloftbootstrap.png
                Ralph
                  Have you also downloaded and correctly installed the required helper file-set LibFredo6 ?
                  http://sketchucation.com/forums/viewtopic.php?p=144178#p144178
                    Ralphxyz
                    Yup!!
                    I have the Curviloft toolbar and the Tools/Fredo6 Collection menu Curviloft menu item.
                    They do "work" in my limited testing.
                    Ralph
                      Have you checked that you have FULL security permissions to the Plugins folder and its contents?
                      Right-click context-menu on its icon, Properties > Security > Edit...
                      It might be that your rights are limited ??
                      Also is there a 'Compatibilities Files...' link button on the Explorer window for the Plugins folder, which might means some things are not installed as it appears... [Windows πŸ˜’ ]
                        Ralphxyz
                        TIG I can not follow what you are asking. "its icon"??
                        Here is my Plugin menu.
                        http://gettheworkdone.net/3Dprinting/SketchUp/Plugins.png
                        There is no 'Compatibilities Files...' in the Plugins menu.
                        Ralph
                          Ralph, TIG is referring to the icon for the Plugins folder (or its name ) in Windows Explorer. Not in SketchUp. You need to make sure that you have full read and write permissions for the Plugins folder and any folders within that folder. The plugin needs to be able to write information to a file in the Plugins folder which it can't do without full read and write permissions.
                            Ralphxyz
                            Thanks Dave, but nope All Users and Administrator have "Full Control".
                            Ralph
                              Ralph, you're making my head hurt. πŸ˜„
                              So you are still getting this error? And you have LibFredo installed correctly, too? Something isn't installed right.
                              • gillesG
                                gilles
                                @ Tig and Dave,
                                Your patience seems to have no limits, I don't remember how much time I read the same answers to the same problems. πŸ˜‰
                                  Ralphxyz
                                  Well Dave that's good as least you do not think of me as a pain int A..
                                  and gilles the answer is??
                                  Ralph
                                    Thank you, Gilles.
                                    Ralph. not yet. πŸ˜‰
                                    So how about giving us a screenshot of your Plugins folder and another showing the contents of the LibFredo folder? If that doesn't show us anything I'm going to remote into your computer and see if I can fix it. πŸ˜„
                                    • gillesG
                                      gilles
                                      Ralph
                                        Ralphxyz
                                        I have a lot of Plugins.
                                        http://gettheworkdone.net/3Dprinting/SketchUp/Plugins2.png
                                        Here is Fredo
                                        http://gettheworkdone.net/3Dprinting/SketchUp/Fredo.png
                                        You guys absolutely are headed for sainthood.
                                        Ralph
                                          Ralph! Don't make me come over there! 😑 🀣
                                          Your Plugins folder contains all those files that are supposed to be in the Curviloft folder. You must have tried installing them twice. Clear out every file from the Plugins folder that should be in the Curviloft folder. Make sure you also delete _loader.rb, too.
                                            Ralphxyz
                                            Hot Dog!! That did it plus a bootstrap_Curviloft.rb.
                                            Yeah I probable did a number of installs.
                                            I tried to load the 10 must have plugins.
                                            Ralph
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 65
                                            • 66
                                            • 44 / 66
