    1.3k Posts 300 Posters 3.2m Views 298 Watching
      Ralphxyz
      I am getting this error when trying to run Curviloft.
      http://gettheworkdone.net/3Dprinting/SketchUp/Curviloft.png
      Ralph
        Where is the file called bootstrap_Curviloft.rb? It should be in a folder called CURVILOFT_Dir_12 but I'm guessing it isn't.
        In fact you should have all these files in that folder.
          Ralphxyz
          Yup, I have them:
          http://gettheworkdone.net/3Dprinting/SketchUp/curviloftbootstrap.png
          Ralph
            Have you also downloaded and correctly installed the required helper file-set LibFredo6 ?
            http://sketchucation.com/forums/viewtopic.php?p=144178#p144178
              Ralphxyz
              Yup!!
              I have the Curviloft toolbar and the Tools/Fredo6 Collection menu Curviloft menu item.
              They do "work" in my limited testing.
              Ralph
                Have you checked that you have FULL security permissions to the Plugins folder and its contents?
                Right-click context-menu on its icon, Properties > Security > Edit...
                It might be that your rights are limited ??
                Also is there a 'Compatibilities Files...' link button on the Explorer window for the Plugins folder, which might means some things are not installed as it appears... [Windows πŸ˜’ ]
                  Ralphxyz
                  TIG I can not follow what you are asking. "its icon"??
                  Here is my Plugin menu.
                  http://gettheworkdone.net/3Dprinting/SketchUp/Plugins.png
                  There is no 'Compatibilities Files...' in the Plugins menu.
                  Ralph
                    Ralph, TIG is referring to the icon for the Plugins folder (or its name ) in Windows Explorer. Not in SketchUp. You need to make sure that you have full read and write permissions for the Plugins folder and any folders within that folder. The plugin needs to be able to write information to a file in the Plugins folder which it can't do without full read and write permissions.
                      Ralphxyz
                      Thanks Dave, but nope All Users and Administrator have "Full Control".
                      Ralph
                        Ralph, you're making my head hurt. πŸ˜„
                        So you are still getting this error? And you have LibFredo installed correctly, too? Something isn't installed right.
                        • gillesG
                          gilles
                          @ Tig and Dave,
                          Your patience seems to have no limits, I don't remember how much time I read the same answers to the same problems. πŸ˜‰
                            Ralphxyz
                            Well Dave that's good as least you do not think of me as a pain int A..
                            and gilles the answer is??
                            Ralph
                              Thank you, Gilles.
                              Ralph. not yet. πŸ˜‰
                              So how about giving us a screenshot of your Plugins folder and another showing the contents of the LibFredo folder? If that doesn't show us anything I'm going to remote into your computer and see if I can fix it. πŸ˜„
                              • gillesG
                                gilles
                                Ralph
                                  Ralphxyz
                                  I have a lot of Plugins.
                                  http://gettheworkdone.net/3Dprinting/SketchUp/Plugins2.png
                                  Here is Fredo
                                  http://gettheworkdone.net/3Dprinting/SketchUp/Fredo.png
                                  You guys absolutely are headed for sainthood.
                                  Ralph
                                    Ralph! Don't make me come over there! 😑 🀣
                                    Your Plugins folder contains all those files that are supposed to be in the Curviloft folder. You must have tried installing them twice. Clear out every file from the Plugins folder that should be in the Curviloft folder. Make sure you also delete _loader.rb, too.
                                      Ralphxyz
                                      Hot Dog!! That did it plus a bootstrap_Curviloft.rb.
                                      Yeah I probable did a number of installs.
                                      I tried to load the 10 must have plugins.
                                      Ralph
                                        Excellent! I knew we'd figure it out. We just needed the right clue.
                                          Ralph, you can try to use either one of these utilities to assist you installing correctly:
                                          http://sketchucation.com/forums/viewtopic.php?t=42315
                                          http://sketchucation.com/forums/viewtopic.php?f=51330
                                          They are RBZ packages so you use the Install Extension feature in SketchUp to install them. Then they will assist you in correctly install RB, RBS, RBZ or ZIP packaged plugins.
                                          General guide on installing: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                            Ralphxyz
                                            Hi thomthom, I found those helpers after I had done the installs. I didn't think to just delete everything I had done and use the install helpers.
                                            Could those links be made sticky at the start of the Forum.
                                            Maybe there could be a Plugins Getting Started sticky header.
                                            Ralph
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 65
                                            • 66
                                            • 44 / 66
