    [Plugin] Pivot Around Axis
    32 Posts 15 Posters 29.1k Views 15 Watching
      Overview
      Quickly wrote a tool to rotate components around their axis.
      Access
      Tools -> Pivot around Axis
      (Supports ThomThom's Menu)
      Usage
      • Select an Component
      • Activate the tool
      • Click an axis and drag up/down to rotate about that axis
      http://sketchucation.com/pluginstore?pln=tt_axis_pivot
        Jim
        Awesome, Thomas! Simple to use and extremely useful for positioning. (Thinking positionable figures and lego.)
          I'm not happy about the controls, up and down. I want the position of the cursor in 3D space to affect the rotation.
          But it's one for later, this one was a quicky.
          • honoluludesktopH Offline
            honoluludesktop
            Thomas, Nice. Having wrote a very limited "point a component" plugin (limited to pointing the zaxis), I am amazed at what you consider a "quickie". Thanks!!!
              Thanks Thom 👍
              Very useful
              At this rate you turn into.........
              http://brokenman.files.wordpress.com/2008/07/cookiemonster.jpg
                So add a move, & scale function and you will have an universal manipulator 😉 👍
                No possible to adapt the mouse movement after the axe clicked with the arrow keys?
                • mitcorbM Offline
                  mitcorb
                  Yeah--what Pilou says--universal manipulator.
                  • Chris FullmerC Offline
                    I started that plugin once, but ended stopping because I don't like to use the universal tool. Is that something that people all really want? Thom is on his way there with this one!
                    Chris
                    All my Plugins I've written
                    • bagateloB Offline
                      bagatelo
                      Why we cannot enter number for rotation by keyboard?
                      The files above make me very happy too, because I set
                      keyboard keys... but "Pivot Around Axis" may be useful.
                      rot1.rb
                      rot45.rb
                        This plugin does that: http://forums.sketchucation.com/viewtopic.php?f=323&t=20346
                        But it does not default to the component axis unfortunately. (which was what I needed)
                        Good idea.
                        Another good idea.
                        I might just come back to this plugin and improve it. Though currently VertexEdit is my top priority. This pivot plugin was one I needed at the office.
                        Me for instance. 😄 I like universal gizmos. They are present in many 3d modelling packages.
                        But the object of this plugin was to manipulate components while anchored to their axis, something I really miss in SU.
                          I wanted to test what happened if I tried to pivot a 2d cutout component...
                          SU just accepted it. And the face it was stuck to appeared to deform as well, without any edges appearing.
                          But of course when you run Fix Problems: 😉
                            snowflake
                            Nice work, mate.
                            All those cookies, you might seriously consider a dental plan coverage.
                              @snowflake said:
                              Nice work, mate.
                              No need! This book is all I need:
                              http://ecx.images-amazon.com/images/I/51ysLwPesOL._SS500_.jpg
                              Besides, virtual cookies are low on sugar. 😞
                                Jim
                                It's just very natural to want to enter the exact angle in the VCB after rotating the component.
                                  Yup. I added a couple of things today, like being able to rotate groups. And click on other instances to adjust another object without existing the tool. Will hook up the VCB shortly.
                                  • H Offline
                                    hsjzyangbin
                                    It'S pity it Can not enter values
                                    • bagateloB Offline
                                      bagatelo
                                      I was thinking about a new possibility for this tool. It would be like this: we selected the object, we activated the tool, and they appear in the screen a circular menu around the object with possibilities of we can rotate the object in predefine angles , as for instance, in 45 degrees. In the image example, only the dog house is geometry, the rest is the menu. For rotate the object, we chose desired arrow.
                                        Have you installed "ThomThom's Menu" ? If you did - then the location is different than the default Tools menu.
                                          alfort
                                          I new to installing plug-ins to sketchup. I've installed your script into the plugins folder but nothing is showing up in the tools menu after restarting sketchup. I'm using SU 7.1.
                                          • jason_marantoJ Offline
                                            jason_maranto
                                            Thank-you -- fits a need I've had perfectly.
                                            Best,
                                            Jason.
                                            • 1 / 2
