    [Plugin] Pivot Around Axis
    32 Posts 15 Posters 29.3k Views 15 Watching
      Jim
      Awesome, Thomas! Simple to use and extremely useful for positioning. (Thinking positionable figures and lego.)
        I'm not happy about the controls, up and down. I want the position of the cursor in 3D space to affect the rotation.
        But it's one for later, this one was a quicky.
        • honoluludesktopH
          honoluludesktop
          Thomas, Nice. Having wrote a very limited "point a component" plugin (limited to pointing the zaxis), I am amazed at what you consider a "quickie". Thanks!!!
            Thanks Thom 👍
            Very useful
            At this rate you turn into.........
            http://brokenman.files.wordpress.com/2008/07/cookiemonster.jpg
              So add a move, & scale function and you will have an universal manipulator 😉 👍
              No possible to adapt the mouse movement after the axe clicked with the arrow keys?
              • mitcorbM
                mitcorb
                Yeah--what Pilou says--universal manipulator.
                • Chris FullmerC
                  I started that plugin once, but ended stopping because I don't like to use the universal tool. Is that something that people all really want? Thom is on his way there with this one!
                  • bagateloB
                    bagatelo
                    Why we cannot enter number for rotation by keyboard?
                    The files above make me very happy too, because I set
                    keyboard keys... but "Pivot Around Axis" may be useful.
                    rot1.rb
                    rot45.rb
                      This plugin does that: http://forums.sketchucation.com/viewtopic.php?f=323&t=20346
                      But it does not default to the component axis unfortunately. (which was what I needed)
                      Good idea.
                      Another good idea.
                      I might just come back to this plugin and improve it. Though currently VertexEdit is my top priority. This pivot plugin was one I needed at the office.
                      Me for instance. 😄 I like universal gizmos. They are present in many 3d modelling packages.
                      But the object of this plugin was to manipulate components while anchored to their axis, something I really miss in SU.
                        I wanted to test what happened if I tried to pivot a 2d cutout component...
                        SU just accepted it. And the face it was stuck to appeared to deform as well, without any edges appearing.
                        But of course when you run Fix Problems: 😉
                          snowflake
                          Nice work, mate.
                          All those cookies, you might seriously consider a dental plan coverage.
                            @snowflake said:
                            Nice work, mate.
                            No need! This book is all I need:
                            http://ecx.images-amazon.com/images/I/51ysLwPesOL._SS500_.jpg
                            Besides, virtual cookies are low on sugar. 😞
                              Jim
                              It's just very natural to want to enter the exact angle in the VCB after rotating the component.
                                Yup. I added a couple of things today, like being able to rotate groups. And click on other instances to adjust another object without existing the tool. Will hook up the VCB shortly.
                                • H
                                  hsjzyangbin
                                  It'S pity it Can not enter values
                                  • bagateloB
                                    bagatelo
                                    I was thinking about a new possibility for this tool. It would be like this: we selected the object, we activated the tool, and they appear in the screen a circular menu around the object with possibilities of we can rotate the object in predefine angles , as for instance, in 45 degrees. In the image example, only the dog house is geometry, the rest is the menu. For rotate the object, we chose desired arrow.
                                      Have you installed "ThomThom's Menu" ? If you did - then the location is different than the default Tools menu.
                                        alfort
                                        I new to installing plug-ins to sketchup. I've installed your script into the plugins folder but nothing is showing up in the tools menu after restarting sketchup. I'm using SU 7.1.
                                        • jason_marantoJ
                                          jason_maranto
                                          Thank-you -- fits a need I've had perfectly.
                                          Best,
                                          Jason.
                                          • xiombargX
                                            xiombarg
                                            This is massively helpful for me. I wish I would have noticed it earlier.
                                            Cookie sent! 😄
